Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 05-05-2009, 10:48 AM   #241
SwiftDeath's Avatar
SwiftDeath will become famous soon enoughSwiftDeath will become famous soon enough
I still don't understand why you can't just connect the touchscreens to a usb hub connected to your computer and assign them virtually. Maybe I missed something that your attempting to do? If you wanted to, you could put an automatic or manual usb switch between the touchscreen and the hub so it switches to a different connection.
-SwiftDeath
SwiftDeath is offline   Reply With Quote
Old 05-05-2009, 11:16 AM   #242
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
The problem with assigning them virtually is that say for example your in shared mode, it will work fine, but when you switch to single mode, the touchscreen will still continue to control only the host PC. Now thankfully NComputing has excellent customer support, these people really know their $h!+. We literally had almost an hour long conversation. One thing that was brought up is that their statement about only supporting flash drives, is the safe statement. Alot of their customers have got lots of different devices to work. He would not tell me how though, lol. He also mentioned that the USB port is not powered, this means if I use a wireless keyboard, I have to make sure it is powered via a USB hub. What I may do is actually buy a 15W PSU for each terminal. This would allow me to power the L230 Terminals and a 4 port USB hub. If this method works, it means I can simply use a USB KVM switch. He also told me about a 30 day trial and that I should buy a unit, see if my devices work, and if they do, I'm good to go. I may take them up on that offer.
In all what I am trying to do is have each user be able to control 2 sides of the PC, their single PC experience and a combined user experience. Basically the L230 cant handle high multimedia stuff. It can only handle basic stuff. So say they want to watch SatTV they switch over to combined mode to control the channels and what not. Then if they want to browse the internet or go on a messenger, they just switch over to single mode.
On a side note, my hinges have been sent out from Esela USA Corp. I will be able to work on my screens soon.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 05-05-2009, 11:32 AM   #243
SwiftDeath's Avatar
Ah good I was worried that it was in some way my fault that you were having such trouble, but in reality it's because you want so much fre@kin' control and options.
My hat was off to you when I first read your worklog. It's somewhere in the basement now......
Edit: I was also worried for my own skin because the way I mentioned was how I was planning to do it, but I think it should work fine for me.
-SwiftDeath
Last edited by SwiftDeath; 05-05-2009 at 11:33 AM. Reason: Forgot to Say something
Old 05-05-2009, 11:39 AM   #244
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Quote: Originally Posted by HiJackZX1 View Post
Ive decided to strip my car later today and start wiring the Cat5 cable. and other electrical cables. Thankfully I had a box of 1000ft of it, I just need someone to attach the connectors on the end. The stereo wire will also be run through the top, to avoid any EMI.
You could do your own connectors. The Cat5/Cat5e tool is available at Radio Shack (about $40), but here's a link to the AntOnline page where the crimper and tester kit shown below is $38.13, including shipping. That's a good deal. Add 50 connectors for $9.
Putting the ends on is not at all difficult. It takes some care, but you have lots of ends to put on, so you'll still come out ahead.
There are two systems for wiring Cat5 cables, called "A" and "B", and you can use either one, as long as you use it on both ends of the cable; "B" is the one most commonly used. If you use "A" on one end and "B" on the other, you get a crossover cable.
Here's a link to information on putting the ends on, and here's another. With a little practice, you'll zoom through the job, you won't have to pay anyone, and you'll have the tool and tester to keep.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 05-05-2009, 12:31 PM   #245
HiJackZX1's Avatar
LMFAO, no its cool the way you explained it. From my work log though, you should have got that I like to complicate everything, LMFAO. The Ncomputing guy thought I made it complicated too.....
I have the crimper, but not the meter to test if I did it right. Maybe its because im not patient.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-05-2009, 01:50 PM   #246
Sheepdog
rdholtz's Avatar
Get the tester. You'll really appreciate it the first time you screw up a cable and the tester tells you; without it, you could chase the problem for a long time.
Old 05-05-2009, 02:26 PM   #247
HiJackZX1's Avatar
i agree, im going to go ahead and get it. Im also going to redo the factory harness and basically remove it. I need the space for all the new cables. My biggest challenge is running the VGA cables...... Any suggestions on that? I dont want to have to drill huge holes in the frame and door to run them.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-05-2009, 03:14 PM   #248
Sheepdog
rdholtz's Avatar
The tiny VGA plug on the side of the Lilliput tells me there are smaller cable ends you could use. Maybe those ends are available at Mouser or some comparable place; it's possible that using them would let you run smaller adapters, and therefore drill smaller holes.
But there's an alternative: in the electrical department, you can find a clamping adapter that holds Romex as it goes through the side of a wiring box. They're available for several hole and cable sizes. That would be one way to cover the holes you make using regular VGA cables.
You could also cover the holes with a cover plate held on with screws. It would make a much cleaner installation than the Romex adapter. You could attach the covers with sheet metal screws, but, if you put rivet nuts in the door panel, you could use machine screws so there would be no pointy end on the fasteners.
Old 05-05-2009, 07:34 PM   #249
HiJackZX1's Avatar
You lost me... lol.... The Lilliput is not problem because you can unscrew it and then reattach once in the hole. I also have to run extension cables for the KVM switch. I think if I cut the end off, like the part with screw holders, it will fit easily.
I got the hinges and connected them, they are awesome. Just hate what I had to pay for them.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-05-2009, 08:00 PM   #250
Sheepdog
rdholtz's Avatar
I was suggesting you might be able to (1) adapt the VGA to a smaller plug like the Lilliput or (2) use the full-size VGA plugs, but cover the holes for them pretty nicely.
Old 05-05-2009, 08:15 PM   #251
HiJackZX1's Avatar
LMAO, I thought that was what you said.
I am now trying to figure out how to make the sides and what not for the top screens. I think it will be easier then I thought. I guess it took me having the hinges to image what I need to do. I now have to get Nexson to see my vision and make it a reality.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-05-2009, 08:31 PM   #252
SwiftDeath's Avatar
Have you figured out whether the touch screen USB can be adapted to ps2 to allow you to set this up? Also did you settle on a KVM Switch?
Also the hinges make that screen setup awesome. So although they cost a lot... I think it will be worth it in the end.
-SwiftDeath
Old 05-05-2009, 09:45 PM   #253
HiJackZX1's Avatar
At this point I don't know what to think. Only way is to try it. I am hoping that a USB hub on the L230 will allow me to use the touchscreen that way. I know the keyboard will work, but touchscreen is still up in the air. I have to get my hands on a L230 to play with it. With the tech saying that their "only flash drives work on the USB port" is a safe statement may mean it may work. I also tried to contact a USB KVM manufacturer and he claims that a USB touch screen cannot be used on a USB KVM. I don't know who to trust! I am also out of ideas if this is true.
Yes they do... I am p!$$ed that I ordered a different type of hinge that didn't work at all. I ordered 4 of those at $10.00 a hinge. Oh well Ive wasted more money in the past, lol. That is also why I am treading very carefully with this Ncomputing solution, it will be a huge blow to me and my wallet if this fails. I have started to research other thin client companies, they all have full USB support, so I don't know why NComputing doesn't do the same thing. I read their forums and some techs claim, having full USB support will cause LAG, but all they have to add is support for low devices like Touchscreens, USB Keyboards and mice. To force people to use a outdated PS2 port is so stupid. Who the f%c* still uses that?????????????? I have heard also that I may be stuck with PS2 because each L230 has its own BIOS. If it doesn't detect a keyboard and mouse in BIOS, it wont boot. I hope that isn't true. Only way to tell is to get the L230 and play with it.
Also another thing to mention is that the PS2 adapter may or may not work, the good thing is, that my EBY701 screens, power the USB controllers, they are not powered by the USB port. So they may work.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-07-2009, 12:52 PM   #254
HiJackZX1's Avatar
Well looks like the NComputing idea may be dead . There are to many limitations that I just could not deal with. Now I am still interested in the idea, but I want to change it a bit. Rather then go with NComputing, i can go with a real thin client. Basically I would create Virtual disks that would hold the OS I want per user, including software, and run everything that way. I would also have full USB support and be able to use a USB touchscreen and keyboard. The pricing is actually about the same as the NComputing L230 device. I have contacted several companies so they can tell me how it works, so lets see.....
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-07-2009, 03:05 PM   #255
HiJackZX1's Avatar
I see that on Ebay, I can buy a thin client for about $35.00. Most come with Windows CE and are about 800MHZ. This should be enough right? Only thing is I dont know how to set them up.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Project 2003 Dodge Dakota Eternalodyssey Worklogs 75 10-29-2009 09:35 PM
2003 Mazda 6 project Brunation Show off your project 28 06-15-2009 09:51 AM
Mitsubishi Outlander 2003 Project angelito46 Newbie 2 05-23-2007 09:05 AM
New 2003 Saturn L200 In-Dash Project snoslicer8 Newbie 5 08-20-2006 11:06 PM
New carputer project started - 350z (56k beware) StutterinJ Fabrication 11 05-22-2005 08:45 AM
