Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 05-28-2009, 08:05 PM   #301
Bxsteez will become famous soon enough
Quote: Originally Posted by HiJackZX1 View Post
7) 2 Alpine PDX-4.100 at $550.00 ea. ($1100.00)
Sonicelectronix has that amp for 329. I've been contemplating getting it
~The Build Process Begins~
http://www.mp3car.com/vbulletin/newb...you-think.html
~The Build Process Ends~
http://www.mp3car.com/vbulletin/show...completed.html
Bxsteez is offline   Reply With Quote
Old 05-28-2009, 09:37 PM   #302
freeflashstuff's Avatar
freeflashstuff will become famous soon enoughfreeflashstuff will become famous soon enough
Quote: Originally Posted by colin View Post
I think you may be insane.
I agree, but D@MN will it be nice when its all said and done!
Geek, Hacker, and EcoModder!
Project Turtle
[☺☺☺☺☺☺☺☺☺☺] Install 95%
Finalizing Fan Bay
Re-hiding wires: 25%
Please help me build my REP!
freeflashstuff is offline   Reply With Quote
Old 05-28-2009, 09:52 PM   #303
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
Yea the pricing isn't set in stone for the speakers and amps. I am going by what Alpine lists them at. I like the PDX series amps because they don't generate as much heat as regular amps. Also they are alot smaller too. I am hoping to have the amps near the computers so I can make a single cover to cover the amps and computers to make it look like one piece. I am starting to reconsider a 500 RMS amp for the sub because I dont want the sub to take up alot of space, since the amps will take up boot space. I want a 12', maybe if I have a very tiny sub box made.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 05-28-2009, 09:53 PM   #304
HiJackZX1's Avatar
Insanity usually accompanies a great mind, LMFAO.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-28-2009, 09:57 PM   #305
I'm cheap i went the cheap route lol.. I bought a Pioneer 6400F
Old 05-29-2009, 01:14 AM   #306
HiJackZX1's Avatar
LMFAO. I tried the cheap route, but after I heard Kimota's system and was blown away, I had to upgrade. I also wanted to go with a high up amp to eliminate EMI. I am in the process of redoing the audio, I am taking out the interior, running the audio straight back and the wire that goes to the speakers will be run through the top ceiling to avoid any electrical cables. I basically want to do away with Ground Loop Isolators. The only GLI i want to use is for the headphone amp, which is one of my older motorcycle amps. Thats for the headphone jacks I am adding. I know that as more headphone are plugged in, the audio will start to get lower for every pair plugged in. With the motorcycle amp, this issue should be killed. Funds for this project are almost nonexistent, but I will get as much small fabing done since it isn't pricey to do. Once I get money rolling in again, I will start on purchasing and major mods which will be done by Nexson.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-29-2009, 08:40 AM   #307
Damn you Hijack!!! You are making wanna upgrade my amp lol..
Old 05-29-2009, 09:16 AM   #308
HiJackZX1's Avatar
LOL, my bad, but it really unlocks the power of the PC's sound. I mean you dont have to go over board like me, but I needed something small. I dont have a trunk and I have 4 dogs. My biggest dog is so spoiled so if to much stuff is in the way he cries the whole way home. With the PDX series I can stack them up and put them as far to the side. Now with the sub, what I will do is make a quick disconnect system so I can take the sub out when they are in the car. I use to have two 12s' OMG he would just cry and cry and cry. I decided to give it to my brother since I couldnt lift that $h!+ in and out my car all the time. My brother promptly blew those speakers, lol, they were kinda cheap though anyways.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-29-2009, 09:54 PM   #309
HiJackZX1's Avatar
The mega case!
Well I finally decided to start making the case for the six computers. I went to Home Depot and bought tough metal strips. I then used a dremel and cut groves in the strips. Then used strews with nuts to fasten them to the grooves. I had an issue were I could still move the cases because they are in a triangle shape. I decided to simply cut a plastic piece out and fasten it to the holes that originaly heald the cases up right. Only thing I have to do is cut the access metal from the top, add a special mount for the bottom to bolt to the car. I may also add 5 small fans to the plastic piece which will draw any hot air out. Pix below.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-29-2009, 11:42 PM   #310
HiJackZX1's Avatar
Instead of cutting the metal sticking out of the top, I bent it to the sides so I can use it as a fastener for two brackets to connect the top to the car frame. So it will be supported on the top and bottom.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-30-2009, 08:55 PM   #311
HiJackZX1's Avatar
Got the case all together and installed it. It took me a while to figure out how to secure it without making new holes in the car. I decided to use one bolt for one of the windows and another that connected to a seatbelt bolt. Even though I haven't tied down the legs it is in solid. I am not going to tie the legs yet because I want to wait for the amps, if they fit under the case then that will support it. I couldn't push the case back as pictured before, I guess its bigger put together, lol. I left a gap behind the case, which will be beneficial. I can stack all the KVMs in the gap and not take up space in the cubby. Only thing that will are the PSUs, Ehternet switch, VGA splitters, DVI-D to VGA converter, small amp for headphones and wiring. That should give me alot of room, if the KVMs go in the cubby they take up most of the space. Also if the amps can not fit under the PC case, then I am making a special shelf to hold the PSUs there. So for now I am done with this project, it all has to do with the size of the amps at this point.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 05-31-2009, 11:25 AM   #312
HiJackZX1's Avatar
I changed the case a bit, I took off the legs at the bottom and added a bracket at the back. Now its stable, and I don't have to worry about the legs blocking anything. Its looking good, now I need to get the measurements for the amps.
I also took a look at the screen idea, and I realize it may not work. For the front its good that they are in the dash because they wont be put through shock. The third row is OK for the pillar screens because they are stationary all the time. The issue is the second row. If they are mounted on the doors, the constant opening and closing will eventually kill them. The only other idea is to put it in the pillar, but I am worried that if the front passenger lean back, they will hit the screen. It may also look like an eye sore. Only other solution is to add them to the seats, something I didn't want to do. I'll play around some more and see what I come up with.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 06-01-2009, 11:42 AM   #313
HiJackZX1's Avatar
OK, I actually had a dream (hopefully a preminition) of the setup.... I am basically trying to get everything into one area so I can have some type of room. Here are pix with details on what I am doing. I think this will work.
I am trying to avoid as much EMI as possible, lets see if this configuration will work. Please comment on placement!
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 06-01-2009, 01:12 PM   #314
vincenttor's Avatar
vincenttor is on a distinguished road
looking good hijack nice plans
go to my website:
http://opelcorsac.19division.nl
vincenttor is offline   Reply With Quote
Old 06-01-2009, 03:49 PM   #315
HiJackZX1's Avatar
Lets hope they work out though.
I was bored at work so I went hunting for the measurements. According to Alpine, the measuremnets for one unit is 257mm x 192mm x 62mm (WxHxD). When I made the card board box version, I took the 62mm and multiplied it by 3. That would simulate 3 amps stacked together. Here is what I came up with.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Project 2003 Dodge Dakota Eternalodyssey Worklogs 75 10-29-2009 09:35 PM
2003 Mazda 6 project Brunation Show off your project 28 06-15-2009 09:51 AM
Mitsubishi Outlander 2003 Project angelito46 Newbie 2 05-23-2007 09:05 AM
New 2003 Saturn L200 In-Dash Project snoslicer8 Newbie 5 08-20-2006 11:06 PM
New carputer project started - 350z (56k beware) StutterinJ Fabrication 11 05-22-2005 08:45 AM
