Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 07-03-2008, 12:54 PM   #1
Kalenth's Avatar
Kalenth is infamous around these parts
2005 Ford F150 MAGNUS Truckputer - project and pics
2005 F150 Lariat Truckputer
This project has undergone multiple iterations over the last year or so. I have been researching all of this for about 2 years, but only recently got the budget approval from my finance department (wife).
All of this was eventually built and working in the home office. After tweaking the software, I had XP booting directly to RR in under 20 seconds, and overall it was a fairly stable system. I had a lot of input from various members, and I was able to borrow strongly from BLK02SI's mustang project, since out dash's are very similar in setup.
Thanks to everyone who has helped on this project. Being a novice, it is a pleasure learning from people that make me feel retarded.
10-14-08
After a move, I had to change my design a bit, and ended up going with a X60 IBM laptop. It uses a bit more juice that I would have liked, but I can't beat the size, and the all-rear ports on the dock. This means it will have a clean look when installed, and won't have as much to snag on the interior of my truck.
The new setup called for a general overhaul of everything except the screen. I ended up using the bezel as a mount point for a lot of my electronics, as it was now a steel cubby capable of holding quite a bit.
Thus far, the new specs are as follows:
custom bezel ($70)
702 TSV screen ($500)
HD Radio (Visteon) ($50)
custom input cable from Mitch ($20)
x60 laptop with dock built into the dash ($350)
custom tray build into the dash for vibration resistance ($15)
hinged dash cover for ease of access to the laptop ($5)
5.1 Amp ($250)
5.1 external soundcard ($50)
12v adapter with dual out of 110v and 5v ($30)
7 port usb hub ($20)
BU 353 USB GPS receiver ($30)
iGuidance 4.0 ($100)
Xbox 360 wireless adapter, with 2 remotes ($80)
Logitech Dinovo Mini wireless keyboard/mouse ($120)
Master toggle switch for 12v power ($10)
temp on switch with phone cable power mod ($3)
Amp wiring kit ($40)
Speaker cable ($20)
Small 8" sub - (needed)
lot of wire, tape, and tie downs
11-14-08
Keep in mind that all of this is a constant work in progress. Cutting into a vehicle means there is always something to improve, so I keep learning and striving to make this a better system. So far, I have spent enough to have put in a SYNC system and wouldn't have to worry about the rest, but the knowledge that I have gained from this project is worth a lot more than that.
12-26-08
Added a 12" mag light mount to the drivers seat. 2 hour pain in the *** but it's as sturdy as a rock. Pics are up.
12-27-08 - P4
Latest update is that I have all of the power issues figured out. Everything is up and running.
Kalenth is offline   Reply With Quote
Old 07-03-2008, 12:56 PM   #2
Kalenth's Avatar
This is a picture of the back on the 702TSV without the ribbon cable connected. There is MAYBE 1/4" of play with the cable, so reposistioning the board where the case would fit around it is a precarious job. These cables are very tender and too much tension can remove it from the jack, or tear it. BE CAREFUL!
To fit in the bezel, I had to seperate the main circuit board and screen, and move the circuit board almost 1/2" to the right to get it to fit into the bezel with the screen. I never will understand why the board was built with so much overhang, but I got it moved and the screen is working without incident.
Take note on pulling out the ribbon cable. This HAS to be put back perfectly, or the video will display incorrectly (if at all).
Old 07-03-2008, 01:05 PM   #3
Kalenth's Avatar
Other than the PC itself, the plan includes modifying the cigarette lighter on the dash, where I will install a slot-load DVD player.
The right dash cover will be removed and hinged, so that it simply opens like a door. The interior grey parts will be cleaned and painted.
Amp will go behind the backseat, or under the passenger seat... I haven't decided yet.
Interior will be completely removed and covered with RAAM mat
Obviously the goal here is maximum usability while retaining the stock look. I think a lot of us here have the same thoughts on that aspect. I love that when I am done and resell this thing, the only thing I will have to do is replace the lighter bezel, and plug i nthe stereo.
Old 07-03-2008, 02:15 PM   #4
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Good work, Kalenth.
When do you expect to deploy? And, while we're on the topic, thanks for helping keep us safe.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 07-03-2008, 03:28 PM   #5
Kalenth's Avatar
Shedule for truck completion is 6 months. (I try to stay realistic, with realizations of tweaking the front end, waiting on backordered parts, and finding time once it's all done to strip my cab bare and coat/wire it.)
Dunno about the deployment, I just anticipate it. My unit (reserves) is on rotation, so I know it's inevitable.
Your welcome! My pleasure! Now everyone go blow stuff up on the 4th of July! Have a drink for the one's that can't!
Old 08-12-2008, 09:42 PM   #6
Kalenth's Avatar
I just finished installing iGuidance on the CarPC. I had initially installed it on a laptop for testing, so I could drag around the GPS receiver.
GPS has been the same that most use, the BU-353. Very nice unit, and very friendly setup.
I found out that the top part of the passenger dash, the part that covers the airbag... the underside is sheet metal. I sat the GPS receiver on it and it sticks because of the magnet. This is awesome in it's own right, however I ended up putting the receiver in the front right, as out of the way as I could. My wife didn't see it when she got in, so I assume it works.
Old 08-12-2008, 09:51 PM   #7
Kalenth's Avatar
So far I have my boot time to about 20 seconds. nLite is an amazing tool... the problem is, I took out most of my picture viewing capabilities, so I have no where to paste pictures and get them online. I'll get it figured out.
I have also ordered a laptop DVD-rom, due to the quiet nature and the ease of use. That should be in this week.
Old 08-12-2008, 09:55 PM   #8
Kalenth's Avatar
iGuidance is killing me. It runs just fine when the source information is accessed from the disk... but the manual says to put the data at the root of c:. I did that, and it doesn't error out, it just doesnt start. If anyone knows of a solution, let me know. (iguidance v4.0)
Looking for a low voltage low sound fan for the case also. The screen puts of a ridiculous amount of heat, and I know that will cause issues in the long run.
Plans for later this week include ordering an HD Radio receiver, and smoothing out this iGuidance issue.
Anyone have a hookup for RAAMmat? I've got about 2 months to install, and I wanted to do the whole truck over a weekend.
Old 08-12-2008, 10:44 PM   #9
Sheepdog
rdholtz's Avatar
I have no experience with iGuidance, but I've wrestled with some wacky software over the years.
Maybe iGuidance is determined to access its data in the same place it was installed from. What if you uninstalled it, copied the entire disk to the C drive, and reinstalled it from there?
Or, I wonder if you could map a folder on the C drive (call it drive E, for instance), and instruct iGuidance to install and run from there.
Another, more time-consuming idea would be to re-partition the drive, leaving a partition for iGuidance, and simply copy the disk and let the program install and run from there.
If iGuidance can be pointed to data on some drive other than the one you installed from, then you wouldn't necessarily have to install from the mapped drive or the new partition.
Does iGuidance provide any initial tech support or at least a comprehensive FAQ?
Old 08-16-2008, 04:06 PM   #10
Kalenth's Avatar
I did exactly that. First I completely uninstalled iGuidance, then copied the entire CD to the HDD, then installed, and now it starts up and accesses the map directory with no issue.
I also am using the wonderful write-up from http://granturing.blogspot.com, to install some of the features from xPE. So far, so good. My boot time, with a password prompt, is about 25 seconds. I think after I move the image to a CF card, it will shave a few seconds off. While I have experimented with EWF and minlogon, I am waiting until I get the OS optimized before I set those up.
Then create an image, pre-and post xPE features, moved the OS, and test.
The one lesson learned from this is take your time and research, research, research.
** I am also looking for a 12v fan to install in the case. This screen is HOT, so I need something to circulate the air... but it has to be quiet. Any ideas, please let me know.
(youtube link is a 29 second video of the initial boot)
http://www.youtube.com/watch?v=SNBS_hT0GtQ
Old 11-14-2008, 08:39 AM   #11
Kalenth's Avatar
Not sure what happened... but my M10000 died. I recently moved, and I think something got jarred in process. So... I am going in a different direction and using a palm top in the glove box as my processor source, and mounting the screen and bezel as a secondary monitor.
More to come...
Old 11-14-2008, 09:17 AM   #12
Sheepdog
rdholtz's Avatar
(From Post #10) ** I am also looking for a 12v fan to install in the case. This screen is HOT, so I need something to circulate the air... but it has to be quiet. Any ideas, please let me know.
Maybe that heat you were concerned about took out the processor.
What sort of palmtop are you planning to use?
Old 11-17-2008, 12:44 PM   #13
j007w is an unknown quantity at this point
Hi Kalenth,
I'm in DFW as well. Your project looks so nice! I'm also about to install my 1st carputer using BLK02si's double-din enclosure. The toughest part for me is finding a screen that'd fit. I noticed you're using the 702tsv but I thought the dimension I found of this screen is too large (155.4mm x 104mm) or rather 4mm too tall. Did you have to trim the Metra kit?
Thanks in advance!
j007w is offline   Reply With Quote
Old 11-18-2008, 08:27 AM   #14
Kalenth's Avatar
@RD - Yeah, I am not sure about the board. I may have crossed wires somewhere... I think the new plan will work out even better if I can get the mounting system right.
I am using an IBM X60 with a docking station for the laptop... it's a bit thick, and the processor is not as power friendly as I'd like... but it's what I have to use. I'm going to have to trim the 2 bracers in the dash behind the glove box, and then mount some track rails for the LT to slide in and out on. The advantage is mobility of the system.... being able to undock the truckputer and bring it inside for updates, etc.. makes it worth the modification hassle, and the dock is perfect since it is thin, and all the ports are in the back. I figure I'll make a nice harness for all the cables and I should be set. Most of the other hardware, usb adapter, HD radio, etc... will be mounted in the PC chassi that is no longer housing the computer components.
@joo7 - The only thing thus far that I have had to trim was the screen enclosure.... Trimmed top and bottom, centered it in the metra kit, and epoxied from there. The only issue is the ribbon cable, just be slow and careful when maneuvering it, and if you are having to force anything, then stop and take a look at what you are doing.
Old 11-18-2008, 10:53 AM   #15
Kalenth's Avatar
This is the gist of whats going on... I have NO idea what amp will do the trick. I am guessing I need a 5.1 to power 4 speakers and a sub? And I've found a couple of external sound cards, but I am still shopping for the best bang for the buck.
2005 Ford Mustang V6 Prem. CarPC Project mdlesk Show off your project 17 10-17-2007 10:46 PM
How can I use a laptop as a carpc? turbocad6 Laptops, Netbooks, Tablets, UMPCs, etc. 0 07-11-2007 01:55 AM
2005 Infiniti G35 Pentium M CarPC Caelric Worklogs 49 11-24-2006 01:16 PM
2005 Mercury Mariner - First CarPC install MileHighCFI Worklogs 25 10-10-2006 09:21 PM
Lekan's Ford Escape 2005 - CarPC LekanB Show off your project 9 03-07-2006 04:26 PM
