Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 08-21-2008, 07:56 AM   #1
MitchellO's Avatar
MitchellO is an unknown quantity at this point
2004 Mitsubishi Magna VR Car PC
I sold my 2000 Mitsubishi Verada auto a few weeks ago, and bought a 2004 Magna VR Limited Edition in Manual, and I'm loving it! Handling is much better thanks to upgrades in the later model, as well as the better suspension as part of the Limited Edition pack.
Only modification that the car had was a different Mitsubishi stereo than stock, along with a 4-disc stacker. And they both sucked, worst sound system I've heard in quite a while.
Of course this is to be replaced with a Car PC! Most of my old setup will go into the new car (PC, amp, Powermate, OBD-II connector), but a new screen is in order.
I decided to go with the same screen as was in my previous setup: a Lilliput EBY-701. I know it's not the best screen available right now, but it's the only one that I know will fit. Was cheap too, less than $230 on eBay!
This will be my first fabrication job (bought my old screen pre-fabbed into a piece I could swap into my old car) and I'm looking forward to giving it a go!
I'm adding a headunit into my setup this time for radio and bluetooth handsfree functions. I know I could do these things with the Car PC, but I will work all that out at a later stage. ATM the headunit I bought (a Sony) has replaced the stock garbage, and things are already sounding MUCH better!! The stock speakers are pretty good (splits at the front, 6x9s at the back), let down by a crappy stock HU.
Updates to come as the fabrication begins!
MitchellO is offline   Reply With Quote
Old 08-21-2008, 09:11 AM   #2
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Looks like you have a nice space for that screen. Where will the headunit go -- down under the climate controls?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 08-21-2008, 09:33 AM   #3
MitchellO's Avatar
Yeah my thinking is to mount it behind the door that you can see below the climate, but I'm not sure if the compartment is deep enough. Need to buy a spare one of those compartments and experiment
Old 08-21-2008, 11:31 AM   #4
Sheepdog
rdholtz's Avatar
Maybe you could just pull off the bezel and see what lies back there. It would be a sad thing to buy the unit and find out you don't really need it.
Old 08-21-2008, 05:07 PM   #5
MitchellO's Avatar
Oh I've pulled it out, and to have any hope of fitting a HU in it I would have to cut it up.
Old 08-22-2008, 06:39 PM   #6
MitchellO's Avatar
Woot!! The latest version of the graphics drivers for my Intel D201GLY motherboard supports native output to 800x480 at 16-bit colour to the EBY-701, no more power strip necessary!
Old 10-09-2008, 07:33 AM   #7
LTEE is an unknown quantity at this point
Hi MitchellO, I've got exactly the same car (2004 VR) and would like to upgrade the head unit. Some how to instructions of removing the head unit is much appreciated.
LTEE is offline   Reply With Quote
Old 10-09-2008, 07:47 AM   #8
MitchellO's Avatar
Hey mate, was really easy to remove.
First pull up the centre console strip thing (the bit with the window switches and cup holders). Then pull out the compartment below the climate control (it's tight, you'll have to pull bloody hard!). After that pull the stereo surround out by gripping just above the vents and below the climate controls. You'll need to disconnect the air sensor, hazard cable and climate cables. Then unscrew the four screws holding the DIN bracket in (two top two bottom) and disconnect the wiring harness from the stereo.
Hope that helps!
I really need to update this thread with my progress, since the Car PC and new screen is fabed in
Old 12-26-2008, 05:16 AM   #9
koolmoedee is an unknown quantity at this point
another great job man and a great car to love to see the oz mitsubishi's getting some screen
koolmoedee is offline   Reply With Quote
Old 12-26-2008, 12:30 PM   #10
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
See thats why I love the EBY701. It is so easy to achieve a OEM look with that screen. Ride looks hot!
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 01-01-2009, 12:12 AM   #11
philthy is an unknown quantity at this point
Having trouble removing head unit
Hi,
I am having trouble removing the head unit as well.
I'm new to this and don't get the part: "unscrew the four screws holding the DIN bracket in (two top two bottom)"
There are no screws to unscrew and whats a DIN bracket?
And is there any way of just removing the CD player instead of the whole unit?
Thanks for your help :]
philthy is offline   Reply With Quote
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
