Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 09-25-2008, 12:06 PM   #1
freehand is an unknown quantity at this point
2007 Hyundai Elantra - In Dash Transflective LCD - First CarPC
Ever since I was a kid I have always wanted to put a computer in my car. I just bought my first car a 2007 Hyundai Elantra.
Right away I started to plan out my first CarPC! Here is what I have come up with so far:
Screen: CarTFT CTF700-SH - VGA 7" TFT - (600nits) -Transflective
Motherboard & CPU: Intel D945GCLF2 Mini-ITX MB with Dual-core 1.6Ghz Intel Atom
PSU: Mini Box M4-ATX 250W 6V to 30V DC-DC Car PC Power Supply
GPS: Globalsat BU-353 SiRF star III USB Mouse GPS Receiver
Memory: 1GB OCZ (I might get a 2GB later)
Hard Drive: 3.5" 80GB SATA Western Digital (Will probably change this later)
Other: Griffin Powermate
Here is the stock dash:
First thing on my list was to put my deck in the car (had it in my parents car before )
This is the stereo installed with the dash apart.
While I had it apart I was trying to figure out how to mount an LCD in there for the CarPC!
And the stereo installed!
So my LCD finally came in yesterday! I ripped the dash out again and started to plan how to mount the LCD in there. I ended up buying a dremel from home depot and hacked off the two plastic mounts that were in my way!
I then sanded the plastic down and did a test fit. I couldn't believe it but it fit perfectly! There is absolutely no play vertically but some horizontally. I quickly got some foam to wedge the screen in there and then started working on a way to mount it in there. I got carried away and didn't take any more pictures. I will get them up soon! I made a really ghetto mount out of some aluminum siding and used two screw holes (1 for the clock and 1 for the AC vent). The mount just goes across the back of the screen diagonally. I was originally going to do 2 mounts but after the first one it was rock solid.
Here is the final result! A quick snap shot late at night. I am still blown away at how good it looks for just being placed behind the dash in one night!
That plastic on the LCD is just the protective stuff that came will the screen. It looks awful but I am leaving it on till I get something better. For now my deck is in my glove box ... I was hoping it would close but it doesn't ... I am thinking of just getting a 4ch amp so i can ditch the deck.
Please let me know if you guys have any ideas! I still have to mount everything else. I am undecided on where to put the computer .. under the seat or in the trunk?
freehand is offline   Reply With Quote
Old 09-25-2008, 02:01 PM   #2
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Looking good so far.
Will it fit behind the screen? That makes running the wires a lot easier . . .
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 09-25-2008, 02:11 PM   #3
Thanks.
You raise a good point. I never really thought much about going that route. I think mainly because I figured it would over heat and it is a lot harder to do maintenance on it.
I will have see how much room i have in there...
Old 09-25-2008, 02:14 PM   #4
skuller is an unknown quantity at this point
That's really nice.
Hook the pc and let us see the glare free monitor.
dsatx in voompc 2 case <HERE>
skuller is offline   Reply With Quote
Old 09-25-2008, 02:17 PM   #5
Quote: Originally Posted by skuller View Post
That's really nice.
Thanks... hopefully I can take some better pictures this evening after work.
Old 09-25-2008, 10:25 PM   #6
OK so I was able to take some more pictures of the screen. The screen was on the normal brightness setting (forgot to set it to the highest). I hooked it up to my laptop.
In this shot I compared it to my laptop screen which had a ton of glare. The touchscreen still looked amazing!
Google! It was getting darker out side.
I will have to take more pictures on a sunny day...
Old 10-08-2008, 12:42 PM   #7
DeAtH07 is an unknown quantity at this point
Looks good, but windows vista
DeAtH07 is offline   Reply With Quote
Old 10-08-2008, 02:34 PM   #8
For the picture yes. I didn't have the computer setup yet for the car so I was just using my laptop hooked up to the screen. I have since setup the computer in the car with XP. I am still finishing the case I made out of plexiglass, once it is done I will take some more pictures.
Old 10-08-2008, 03:03 PM   #9
Ah ok, looking forward to seeing the pics
Old 10-10-2008, 02:29 PM   #10
OK so I took some pictures of my plexiglass case that I built for my CarPC. It turned out pretty good for my first custom computer case.
It isn't finished yet I still need to make a lid and install a quick release connector for the power cables. I also need to figure out how to mount it in my trunk because right now it is just on the floor. I threw a bunch of cardboard boxes around it to stop it from sliding around
Old 10-10-2008, 03:37 PM   #11
jdc753 is an unknown quantity at this point
screen is looking really good for sure. Great work. Case looks well done, well layed out and cleanly built too.
2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
Planning:
[|||||||||-] 95%
Parts Aquisition:
[||||||----] 60%
Install:
[|||||||||-] 90%
Finally getting Built
jdc753 is offline   Reply With Quote
Old 10-19-2008, 08:47 PM   #12
servicefun is an unknown quantity at this point
Webcam
Hi i got the same Hyundai. Thanks for the Pic. Do U have more Pic, send it to me. U ever thought to build in a webcam? Like in front/rear. Then record it. Its a lot fun. Also when u will get a Ticket, it help u to proof u r not guilty! The cops didn't like it! Were u wanna place the Pc inside? If in the rear, U will get problems with the cable length. I had a VW Passat were i got some problems with cable. If u build the power supply in a difference box. so u will get more flexibility. Looks awesome ...
servicefun is offline   Reply With Quote
Old 01-17-2009, 08:04 PM   #13
pcpete's Avatar
pcpete is on a distinguished road
Man, the way that screen just fit into there is sweet, really looks stock!! (I wish cartft didn't put there logo and stuff though) Good job on the plexi case, It's giving me ideas...
Any progress? Did you get the PC mounted?
I made a raised mdf floor on mine and hid all my stuff under it, 2 amps, pc , etc ..
Check out my pics in my sig...
pcpete is offline   Reply With Quote
Old 01-18-2009, 06:51 PM   #14
Ya the screen turned out amazing ... it was pure luck.
I did get the PC mounted but winter started so I haven't had time to take pictures. I bolted a peice of plywood to the roof of my trunk. Then the plexi case is hung from that using thumb screws and L brackets, the plywood acts as the lid (I ran out of plexi glass, and got a bit lazy...). It turned out great, you can't see it at all when you open the trunk and I didn't lose any space. I also wanted it to be easy to remove if I need to work on it. I can take it out in seconds now which is nice.
Tags
canada, ctf700-sh, d945gclf2, elantra, hyundai
2007 Renault Megane...the OEM look Cris Show off your project 32 06-24-2009 02:23 AM
Streets & Trips 2007 / AutoRoute 2007 - testers with touch-screens needed Marvin Hlavac GPS 20 04-12-2008 03:39 AM
2007 Scion tC - CarPC DONE! mike6789 Show off your project 21 08-31-2007 01:01 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
carpc with name brand monitor fasteddie Input Devices 5 08-25-2006 08:09 AM
