Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 07-28-2009, 12:05 AM   #466
freeflashstuff's Avatar
freeflashstuff will become famous soon enoughfreeflashstuff will become famous soon enough
Started working on the fan bay today, but I can't get the plastic welding to hold like it needs to. As much as I hate to, I think I'm gonna use ABS cement(God, that stuff stinks... literally). Hopefully that will hold it together. I have managed to get the motorcycle battery to hold a charge. It just needed more acid in it. What it had must have spilled out. (I had it in a moped, and I took a quick turn onto gravel, and bit it... )
Geek, Hacker, and EcoModder!
Project Turtle
[☺☺☺☺☺☺☺☺☺☺] Install 95%
Finalizing Fan Bay
Re-hiding wires: 25%
Please help me build my REP!
freeflashstuff is offline   Reply With Quote
Old 07-28-2009, 04:15 AM   #467
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
You may want to see if you can locate the motorcycle battery under the hood, because it produces fumes, and they're caustic. The underhood area is very well vented, even when stopped, because the radiator requires it; neither the cabin nor the trunk are vented that well.
In my car, there's still some space available in the area in front of the left wheel well. I'd have located a second battery there if I hadn't used a sealed lead acid system.
The wiring is the same no matter where you put it..
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 07-28-2009, 12:46 PM   #468
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Pics?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 07-28-2009, 12:52 PM   #469
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
OMG whats up with you driving off the road, lol. Also, what I would do is use Popsicle sticks to act as a reenforcement to make it stronger. I am guessing there is to big of a gap so the plastic is sagging and or falling off?
The wiring is exactly the same.
OMG, please make sure you put that battery in a safe place. You know dealing with electrical is so scary. Maybe thats why I am the only one that thinks its a bad idea.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 07-28-2009, 01:43 PM   #470
Tidder: that was two years ago, I couldn't get it to start after that, so I gave it to a friend who works on motorcycles. I think he ended up parting it out.
HiJack: I'll try that. And I'm gonna go look at my engine bay right now and see if I have the space there.
I do have space, next to the other battery even. I just need to finish charging this one and test how long it'll run
Project Turtle
Finalizing Fan Bay
Old 07-28-2009, 11:29 PM   #471
Since I added a cold air intake awhile back, I've been meaning to remove the factory air filter housing. Today gave me a reason to do just that. I removed the air filter housing, and what'dya know? Just enough room for the motorcycle battery(or the two scooter batteries, even). Two trips to AutoZone later, I had everything wired up and ready to test. Preliminary testing went well, but afterwards, my OPUS started acting up. All the wires were attached the same way they were during testing, but the light was blinking twice. I shorted the pins manually, and everything powered up, but I still haven't managed to get the OPUS to power everything on on it's own. Any suggestions? (And yes, I've flipped the plug on the pins on the MoBo...)
Project Turtle
Finalizing Fan Bay
Old 07-29-2009, 01:53 PM   #472
PIX of the AUX battery install:
In-line fuse holder with a 30A thermal circuit breaker:
Battery where the factory air filter housing was:
Reused one of the mounting holes for the ground:
My cold air intake:
Factory air filter housing:
Project Turtle
Finalizing Fan Bay
Old 07-29-2009, 02:31 PM   #473
Sheepdog
rdholtz's Avatar
. . . Preliminary testing went well, but afterwards, my OPUS started acting up. All the wires were attached the same way they were during testing, but the light was blinking twice. I shorted the pins manually, and everything powered up, but I still haven't managed to get the OPUS to power everything on on it's own. Any suggestions? (And yes, I've flipped the plug on the pins on the MoBo...)
I wonder if the auxiliary battery Voltage is too low to get the Opus to turn on. Have you measured its output Voltage at full charge?
Looking good . . .
Old 07-29-2009, 03:23 PM   #474
With the car running, both batteries are at 14VDC. With the car off, the main battery is at around 13VDC and the AUX is at 12.7VDC. The OPUS light blinks twice either way; car running or not.
Project Turtle
Finalizing Fan Bay
Old 07-29-2009, 04:10 PM   #475
HiJackZX1's Avatar
Change the voltage down to 11.7 on the OPUS by adjusting the jumper. I cant recall the number, but I think it may be posistion 4 or 5 or 7.... I would check the PDF.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 07-29-2009, 04:18 PM   #476
I lost all the jumpers... They're all zeroed out, so shutdown delay=10 seconds and shutdown voltage=8.5VDC.
Project Turtle
Finalizing Fan Bay
Old 07-30-2009, 01:30 AM   #477
I got my fan box finished today. The ABS cement held what it needed to, so I finished the smaller parts with plastic welding. Pix follow:
Inside:
Finishing the cold air intake is my next step. I still wish I knew what my OPUS's problem is... It still blinks twice...
Project Turtle
Finalizing Fan Bay
Old 07-30-2009, 07:20 AM   #478
HiJackZX1's Avatar
Inside:
I think that is perfect. I didn't realize the part was so deep though. You still may want to put a small plastic divider in the middle of the fans. Underneath, maybe about 3 inches. That will create even circulation.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 07-30-2009, 02:29 PM   #479
Well, I'm going to Dallas tomorrow morning, so I'll try to do that today. I need to find something to cannibalize plastic from so I can make that divider. I used all of what I cut off of this for the plastic welding and the center piece. A CD case would work, wouldn't it?
Project Turtle
Finalizing Fan Bay
Old 07-30-2009, 02:39 PM   #480
HiJackZX1's Avatar
You can actually use a piece of wood, if anything. No one will see that part.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Project: Toyota Matrix indash LCD begin (56K beware). MatrixPC Fabrication 44 06-02-2009 01:28 PM
2004 Toyota Corolla S Project! PaulDePimp Show off your project 17 04-13-2007 07:31 PM
1993 GMC Sport Truck Project chapstick Worklogs 14 06-22-2005 05:37 PM
swbball28's toyota highlander project - fabrication done by meeee xdjxklusivex Fabrication 7 05-21-2005 05:43 AM
A Start Community Project BenjaminS MacCar 9 03-25-2005 06:46 PM
