Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 03-29-2009, 06:03 PM   #91
freeflashstuff's Avatar
freeflashstuff will become famous soon enoughfreeflashstuff will become famous soon enough
The bezel is almost finished! I'm just waiting on Saul to get it painted. I went over to his place yesterday and got it re-fitted. Pic follows.
I'm still looking for a way to get my PC to fit under my seat. I thinking of risking the Morex again. Unless I can find my old IBM case, I probably will. Can't remember if I threw it out or not...
Geek, Hacker, and EcoModder!
Project Turtle
[☺☺☺☺☺☺☺☺☺☺] Install 50%
Finalizing Fan Bay
Re-hiding wires: 75%
Dead MoBo -50%...
Please help me build my REP!
Avatar from: Gates vs. Jobs
freeflashstuff is online now   Reply With Quote
Old 03-29-2009, 07:37 PM   #92
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
What size case do you need? How big is the system board? Do you plan to put a DC-DC power supply in it?
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 03-29-2009, 07:40 PM   #93
IDK the dimensions, but the board is a Full-sized ATX with 1.6Ghz Intel P4 W/O HT... But I'll try to get the dimensions in the next couple of hours and posted. I have a case that almost fits, but it's a few inches too wide. I want to put it under my driver's seat horizontally(on it's side). I'm off to find a tape measurer...
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 03-29-2009, 07:45 PM   #94
Sheepdog
rdholtz's Avatar
It really isn't hard to modify a case if you have sheet metal shears, a drill, and a rivet gun. You could use mine, but it's a bit of a drive from Artesia to Atlanta.
. . . or you could go back and try that resin-impregnated corrugated cardboard we talked about earlier; the only tools you need for that are a brush, mixing cups, mixing sticks, and gloves.
Old 03-29-2009, 08:00 PM   #95
I actually thought about that earlier today. I could actually use the fiberglass jelly that Saul and I used on my bezel so I would just need a putty knife... The more I consider it, the more I like the idea. Starting with a big enough box(I have to have 2 PCI USB 2.0 cards; all on-board are USB 1.1, 2 WiFi cards[one for in-car ad-hoc for iPhone, the other for regular WiFi], and my PCI sound card) and some more fiberglass jelly, I could have a decent custom case. Now when's the next time I get paid?
*runs to check calendar*
Should be next week or two. Got about $80 bucks coming my way from the Crystal Gayle concert last night(3-28)(Minus about $20 for gas...). I got to meet her. She's pretty cool and laid-back. I've met some artists that could care less about the fans, as long as they're getting paid for performing... :@ They anger me.
I just spoke with Saul while I was typing the other stuff. He's leaning towards using plate steel or aluminum and welding the pieces together. That seems better, because fiberglass jelly dries rigid and cracks really easy. If it should get kicked from the front or back, it needs to hold together. I like both ideas... Help plz?
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 03-29-2009, 09:38 PM   #96
Sheepdog
rdholtz's Avatar
While that sounds good, it's a lot easier to bend and rivet than it is to weld. I look at welding as something I do to add strength, not to manufacture an entire case. You can get a little Harbor Freight 18-inch bending brake for $35 (plus $8 shipping if you aren't near a store), and it will handle 18-gauge steel. That's plenty of thickness for a case and lid. Look around PC repair shops to see if they have old cases they're throwing out, and grab the sheet metal parts to modify. For cooling grilles, cut the grille out of a case and rivet it over (or under) a hole in your new design, or drill a nice pattern of holes using one of the existing grilles as a pattern.
That's shade tree engineering at its finest.
Old 03-31-2009, 11:39 PM   #97
I ordered this to use in conjunction with my MicroSDC from MPEGbox. Hope it works.
The Atom should be here tomorrow according to FedEX tracking. We'll see. Based on the events transpiring in my worklog, Saul, the guy that helped me do the fiberglassing, wants to put in a CarPC... LOL All this s*!t all over again.
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 04-01-2009, 12:55 PM   #98
The bezel is DONE! I got it yesterday, I just forgot to post about it. I'll edit this post later with pix of it. Just waiting on the board now...
EDIT: THE BOARD IS IN!!!!!!!!!!!!!!!!!!!111111111111111ONEONEONEONEON E
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 04-01-2009, 01:07 PM   #99
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
Pics?
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 04-01-2009, 01:11 PM   #100
Hey, you're trying for the goal by going the other way around, you're crazzzyyyy!
HiJackZX1's Avatar
HiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really niceHiJackZX1 is just really nice
I agree..... if you go to home depot, you can get tin snips for about $7.95... I actually used my crappy heat trapping Morex case for my new one..... I cut that bad boy up and use it to create my new case. It is so easy, just be careful, I cut myself a few times on the edges.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
INSTALL OF MULTI PC SYSTEM [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
HiJackZX1 is offline   Reply With Quote
Old 04-01-2009, 01:13 PM   #101
I would have pix, but I'm in class right now. I'll post some pix when I get home about 4:30 Mountain Time. K?
HiJack, that's a lot of cables...
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 04-01-2009, 02:14 PM   #102
Tidder's Avatar
Pics?
Tidder
Try RevFE
Best Quote EVER!!
Old 04-01-2009, 02:50 PM   #103
HiJackZX1's Avatar
LOL, thats what happens when you have alot of system, lol.... Whats funny is that I just redid the cabling so its cleaner, and as you can see its still alot.
HiJack ZX1 CFSC
CAR PC ITEMS [35%]
BUG WORKOUT [0%]
INTERIOR MODS [45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Old 04-01-2009, 08:14 PM   #104
I've got the Atom in a bench-test setup right now. Repairing my XP install right now. Tried to boot it up straight, but got BSOD. So by the time I get home from church, it should be done repairing, then all I need to do is wait for the PSU I ordered and get it all installed. I forgot about pix. Posting some low-res pix in about 5 minutes....
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Old 04-01-2009, 08:31 PM   #105
Here are some low-res pix from my iPhone:
FINALIZED BEZEL!!!:
Cigarette lighter relocation(Blurry, srry):
EDIT: Sorry about the trash in the floor. Tozir doesn't know how to pick up his trash from lunch, and I'm too lazy to clean out my car.
Project Turtle
Finalizing Fan Bay
Dead MoBo -50%...
Last edited by freeflashstuff; 04-02-2009 at 01:30 PM. Reason: Added info about trash
Project: Toyota Matrix indash LCD begin (56K beware). MatrixPC Fabrication 44 06-02-2009 01:28 PM
2004 Toyota Corolla S Project! PaulDePimp Show off your project 17 04-13-2007 07:31 PM
1993 GMC Sport Truck Project chapstick Worklogs 14 06-22-2005 05:37 PM
swbball28's toyota highlander project - fabrication done by meeee xdjxklusivex Fabrication 7 05-21-2005 05:43 AM
A Start Community Project BenjaminS MacCar 9 03-25-2005 06:46 PM
