Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 10-26-2009, 10:37 PM   #136
hexxamillion's Avatar
hexxamillion is on a distinguished road
Power Supply Location
Here are a few pics displaying where I may be mounting the Power Supply on the console. I am thinking of mounting across from the PC on the opposite wall of the console. I am thinking about getting the enclosure that is available for the M4-ATX and just use the base much like I'm using the case for the motherboard. The base will be attached to the console and the PSU would be attached to the enclosure base.
This is the console laying sideways with the PSU sitting on the bottom. The Mini-ITX case is mounted above.
I turned the camera to simulate how it would look with the PSU mounted across from the PC.
Another view with the console on its side.
If I do mount the PSU here will probably turn it 90 degrees with the ignition connection facing towards the front of the car rather than down.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Homepage: Hexxamillion.com- Now Mobile Friendly!
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 10-27-2009, 01:51 PM   #137
Mid-Project Testing
I figured before I get carried away it would be good idea to hook things up again and test them.
I want to make sure that the following were working: HDD LED, Reset Switch/LED, Front USB ports and 120mm LED fan.
Click the images for zoom
Preparing setup for testing:
Here you can see the fan and LEDs are working. It's a good thing I decided to test at this stage because I found that the latching LED switch definitely does not work well as a reset switch. I am replacing it with a 22mm diameter momentary button with LED. It will look identical only it will be momentary type vs. latching. I also was able to successfully test the new USB ports I mounted on the front panel.
Aside from the switch I am satisfied with things and will continue with the rest of my build.
Old 10-27-2009, 02:08 PM   #138
Preparing the Intake Filter and Grill
If you followed my worklog you would have read that I decided to ditch the top intake fans and will just install a simple grill with a filter. These are the pics of me preparing this next mod to my console.
I decided to use the 120mm filter/grill and cut it in half to fit the top part of the console. This will just help minimize dust from being pulled inside the console.
Click the pics for zoom
120mm Filter/Grill before modifying:
The grill/filter consists of three pieces. The front grill, the filter, and the rear grill.
This is the area on the console that the grill and filter will be mounted.
Inside view of the console where the filter and grill will be.
This is the grill modified.
This is about where it will be mounted.
That's as far as I got so far today. I will continue later this evening with cutting the console, drilling and attaching the filter.
Old 10-27-2009, 02:49 PM   #139
My Blog
Anyone please feel free to comment and follow my project on twitter or my blog at hexxamillion.com. I update it with my project details in addition to other topics of interest.
Old 10-27-2009, 09:55 PM   #140
Intake Filter and Grill- Part 2
I completed the front intake grill and filter. I used the 120mm fan filter/grill I had. I cut it in half and cut holes in the console so air can flow. I could not simply cut a large rectangle and attach the grill because I need to use the console to support the filter to avoid it from falling inside in the console over time due to the air flow.
Click on the pics for zoom.
This is a reminder where the grill is going.
I made the first cut.
Preparing for the next cut.
Made the second cut. They're not one hundred percent perfect but they will be covered by the grill and filter, plus this will serve its purpose for intake airflow.
I cleaned up and sanded the frayed plastic around the inside edges.This will also help prevent damage to the filter.
A preview of the grill in it's place.
The completed installation of the grill and filter.
This is the rear inside view of the filter and grill.
Now that's done..on to the rear exhaust fan.
Old 10-27-2009, 10:08 PM   #141
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
You've cut the intake area to half of the outflow area. Since you're going to have so much fan pulling air through that grille, I'd recommend opening it up as far as possible to minimize the restriction. Anywhere you can see the console material through the grill, you could cut more material away and still have plenty of support. It's a little more work to do that, but it will keep your 120mm fan from working so hard to pull air through the reduced opening, and it could reduce the possibility of airflow noise at the grill.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 10-27-2009, 10:41 PM   #142
Rear Exhaust Fan- Part 1
I started the exhaust fan modification to the rear panel of the console. I will complete this tomorrow. Here are the pics of the progress so far.
Preview of the fan on the back panel.
Preview of a rough outline to guide the cut for the fan.
Preview of the lip that needs to be cut so that the fan sits flush against the panel.
I cut the lip and started the outline cut for the fan.
The completed cut for the fan.
Preview of the fan in place after modifying the panel.
That does it for tonight. Tomorrow I will perform the sanding and clean up of the panel for the exhaust fan. Regarding the outside of the panel, I will be mounting a chrome laser cut grill. The design is in a way appropriately called an "Atomic Laser Cut Grill" (the motherboard is an 'Intel Atom') . It will be interesting to see this with the green LED shining through once my installation is complete.
Old 10-28-2009, 09:30 AM   #143
I see what you're saying. I really don't think airflow in general will be an issue only because this console area is quite open anyways, space is not too restrictive. I probably didn't really need the top intake at all but chose to just to help bring in some of the cooler air that may flow from A/C or from rolled down windows. My tower at home has about the same area for intake with a 120mm exhaust fan and it runs very quiet.
Old 10-30-2009, 01:02 AM   #144
I ordered my fan grill, rubber screw mounts and silencer to minimize vibration noise from the fan. I also ordered a momentary switch with LED to replace the current latching switch, which does not work well as a reset button.
Old 10-30-2009, 10:40 PM   #145
Well my DVDROM/RW/CDRW drive has been shipped also. I decided to get an external USB only because it was convenient at the time. I was originally going to get a SATA drive but the cable I needed was out of stock and the USB was available. I have no problems with USB either..I will only really use the drive for software installation when needed.
Old 11-02-2009, 12:17 PM   #146
I performed more work on the back panel for the exhaust fan. It was a little dramatic because the design of the panel is not flat, it's a bit curved. I had to do more cutting to the panel in order for the fan to fit flush. I need to do some clean up and cover the space that is seen now. Pictures coming soon.
I also received my new momentary switch and it tested great. The LED is amber as opposed to green but that's ok. This week I should be receiving my slim DVD drive and USB extension cable.
Old 11-02-2009, 01:24 PM   #147
More Work on Exhaust Fan
Here are the pics for the work on the rear fan.
Click on the pics to zoom
A View of how the grill will look.
Examining the placement of the fan silencer.
Rubber screws to assist with minimizing vibration noise.
Time to do some minor sanding and clean up.
It may be hard to tell here but the panel is not flat but has a curve to it. This impacts how flush the fan sits against it.
I had to do more cutting in the area where the hump is so that the fan sits flush.
The fan sits flush now but the view from the back shows the space that needs to be filled now. I need to figure out how I am going to fill or cover that but this should be a minor task.
This is a view of the fan at work while mounted. You can also see the ugly spacing that I had to cut.
Well this part of my project is done for now. I will have to figure out how I am going to fill in that space but this doesn't impact the rest of the tasks to be completed for my project.
Old 11-02-2009, 02:12 PM   #148
Installing Momentary Switch
These are the pics of the new momentary switch. I am replacing the latching switch which does not work well as a reset switch, at least in my installation.
Switch with Amber LED ring and cable with LED Power/Reset
This is the simple wiring diagram that came with the switch. I think the diagram posted on the FrozenCPU website is better.
Removing the 22mm Latching Switch.
During the process of disconnecting, testing and moving the cable connections on the switch I accidentally broke one of the wires. So I had to break out my soldering iron.
Connecting the cable to the mobo headers.
The switch and LED works.
Old 11-02-2009, 02:18 PM   #149
Inside View of Switch
I forgot to post how the switch looks from inside the console so here it is.
Old 11-02-2009, 03:02 PM   #150
Modifying Storage Tray
If you have followed my thread you may recall I had to do some modifying to the storage tray to make room for the I/O panel and cables. Well I finally got to perform this modification today.
Here are the pics.
Before modification.
I needed to make room for cabling and I/O panel.
Originally I was going to just cut the bottom of the tray. I had to make drill holes to relieve the stress of the dremel...thick heavy plastic.
Today's work. Surveying what work needs to be done in order for the tray to close and allow room for cabling.
I need to cut the bottom and side of the tray.
Started to cut with the Dremel.
I did some riggin' and put the dremel attachment on my drill because it has more power and it proved to be too much work for the dremel. That ABS plastic is thick which is great for stability but bad for modifying and OEM work.
So eventually the drill was just a little too much but it got the job done. The cutting disk broke It's all good because I have more.
Cutting complete
A view of how the tray looks now on the console.
You may be asking why all this work on the tray, why not just remove it from the installation altogether. Well I thought about that but the hinge of the armrest is also supported by this tray which is why I only cut the bottom and inside wall of the tray. The hinge area is still in tact.
Subaru Impreza 2.5RS '05 Wagon Install... on a budget Pseudo Nim Show off your project 35 06-24-2008 02:38 PM
2004 Nissan Maxima Install BobbyCreekwater Show off your project 7 05-14-2008 07:22 AM
Freak show - 22 year old Nissan install Yuriy Show off your project 28 09-18-2007 12:09 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 11:19 AM
'98 VW Passat 1.8t, budget install Beehphy Show off your project 4 06-11-2007 04:26 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
