Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 09-25-2009, 02:42 AM   #31
hexxamillion's Avatar
hexxamillion is on a distinguished road
Ditching the After Market Head Unit?
Ok so...I think I am finally breaking down and deciding on replacing my head unit with my PC. I can run cable from the sound card to my AMP. When it comes time for me to upgrade my AMP I would prefer to get one that has a remote to adjust and tune it. Any suggestions?
I am going to test this with my EEEPC which I have mounted as my CarPC currently. I will need to get a higher grade Jack to RCA cable adaptor but we shall see how it sounds. If all goes well as could be expected then that will cut more cost from my project (I was going to upgrade my head unit). This will also provide an easy switch over to use my Windows Mobile phone as a backup media player. Since the LCD Monitors have 2 video inputs, one will be the PC and the other will be my Phone if needed (though no interaction unless I use the VNC...we shall see). I use my rearview mirror as my backup camera already so that is covered.
I found this straight forward overview of connecting my PC to my AMP: CarPC Hacks
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 09-25-2009, 05:22 AM   #32
USB Sound Card Solution
I know there are many USB sound card solutions out there but I think I found one that adds an "easy to reach" option for controlling the sound. If I decided on this, the upgraded audio jack to RCA cable will be connected from this straight to my AMP.
Creative Labs Xmod USB Sound Card
These are the specs:
Connectivity USB Mini-B
Line Out - 3.5mm (1/8") Stereo jack
Line In / Mic in - 3.5mm (1/8") Stereo jack
Headphone Out - 3.5mm (1/8") Stereo jack
X-Fi Technology
X-Fi Crystalizer
X-Fi CMSS-3D Virtual
X-Fi CMSS-3D Headphone
Earphone Specifications Frequency Range: 140 Hz ~ 20 KHz
Sensitivity: 112 dB ± 3 dB (I/P Level:1 mW)
Impedance: 32 ohm ± 15%
Plug: 3.5 mm (1/8") stereo miniplug
Power Requirements (USB or AC Adapter)
Supply Voltage : 5V +/- 5%
Current : 1A
Power : 1W
Old 09-25-2009, 06:19 AM   #33
Which Power Supply? CarNetix CNX-P2140 or M2-ATX-HV Intelligent PSU
Ok...after some more forum reading and manual reading I wonder if I should get the CarNetix CNX-P2140 rather than the M2-ATX-HV Intelligent PSU.
They both generally have the same goal in preventing improper shutdown and protecting from battery drain. I am, however, especially interested in the "Pulse Start Feature" of the Carnetix. I have been looking for such a solution for a while now.Search for term pulse in the Manual.
Any suggestions? How well will the CarNetix work with the Intel D945GCLF2D Mini-ITX?
Old 09-25-2009, 06:44 AM   #34
OK...So my question was already answered in this post. Even though I am no longer using a Zotac IONITX, I believe this answer still applies being that the Intel board I am going to use is similar.
Carnetix it is! Time to update my checklist in post#22.
Old 09-25-2009, 08:29 AM   #35
My Center Console Modify Plan
I think I am going to purchase a center console from a junk yard or online (I saw some people are selling online). This will avoid me having to chop up my stock and will serve as a backup in case things don't work out quite how I want them to.
This is basically what I will be disassembling and modifying. These pics are to provide a general idea of what I will be working with. My interior is tan not black. These pics are from a post on ebay...just to use as an example.
I plan on modifying the storage bin as the area to mount the motherboard and other components. This is an actual pic of my console...look at that wasted space.
Old 09-25-2009, 11:01 AM   #36
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
The Zotac and Intel boards aren't similar in power supply. The Zotac board uses an external 19V power brick, so it needs 19V from your power supply; the Intel board uses a 24-pin ATX connector, so it can use either PSU to get the 12V, 5V and 3.3V it needs.
The Carnetix isn't going to solve any power issues. On the upside, it would still be an excellent choice, and you'll gain pulse start. On the downside, you'll spend twice as much on your PSU.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 09-25-2009, 11:12 AM   #37
Yeah. I realize the power supply differences but I think the Intel with the CarNetix may better suit my needs...or wants rather. Thanks for the feedback.
Old 09-25-2009, 04:26 PM   #38
LancerAM is an unknown quantity at this point
I would double check on that x-mod. If I remember correctly the jog dial isn't for adjusting volume but for adjusting the crystalizer.
LancerAM is offline   Reply With Quote
Old 09-25-2009, 06:47 PM   #39
Good looking out. I will have to find a retailer that might have one on display.
Old 09-26-2009, 06:38 AM   #40
I came across this thread about a USB CarPC Amplifier. This is very interesting...wondering if anyone has had experience with this? Here is the online store link.
This is definately something I have been looking for. Too bad after you do the euro to $$ conversion you're looking at around $330 or so including shipping and tax. Neat idea and maybe waaaaaay down the road I may consider it just to satisfy my own curiosity or just to be unique..realizing probably not too many will have such a device.
Old 09-28-2009, 03:49 PM   #41
Windows 7, Centrafuse & Windows Mobile (xv6900/HTC Vogue)
Today I tested Centrafuse (trial version) on my Virtual Machine running Windows 7. Bluetooth connectivity took some figuring out but now I know what I need to do it's all good. Obviously I am limited with the trial version (on a virtual machine) but for general functionality Centrafuse ran flawlessly on Windows 7. My Verizon xv6900 was paired flawlessly and even the A2DP functionality worked without issues on CentraFuse. I played a video on my phone and the audio played through my speakers. I was able to make a call through Centrafuse and setting up my phone was easy.
I was able to setup my Gmail IMAP easily through Centrafuse and it worked great.I was able to send an SMS through my IMAP to my phone. Mighty nifty that it also has quick replies to select and you can add.
So mainly because Centrafuse so far appears to be less hassel (if at all) I will probably be purchasing it rather than using Ride Runner. Don't get me wrong Ride Runner appears to be a great product and has come a long way but I like the functionality of Centrafuse better...just personal preference..they both are great front ends in any case.
....it's a shame that Bluesoleil is not free... too bad it doesn't come bundled as a full version with Centrafuse..it's only a trial but at least it's affordable. That would be one of the things I prefer LINUX over Windows..at least simple software components such as Bluetooth Managers are free. I never had any issues with Bluetooth on LINUX...does the same stuff but it's open source.
Old 09-30-2009, 03:40 AM   #42
Shows how much of a newbie I am with Centrafuse. Apparently Centrafuse does come with Bluesoleil bundled but it's a modified stack for Centrafuse. So I'm sure I will get complete functionality once I purchase Centrafuse...no more Bluesoleil disconnects due to 2MB data transfer limit on the trial.
Old 09-30-2009, 03:49 AM   #43
Updated Component Checklist
I updated my post with the new components I now have from my checklist. Post#22
Check it out!
I forgot to mention that I received my new front dash cover from Coverking. I am eventually going to be modifying that with flexible solar panels...down the road..after the PC build is complete. View my thread Solar Charge your Laptop. The title was created from my first and current CarPC project using my EeePC. I will be modifying that but it could still be applied to other applications aside from a laptop.
Old 09-30-2009, 11:47 AM   #44
Time to Test Components
I purchased a USB port (x 2) to Motherboard header extenders w/bracket. I am going to bench test some of the components (power switch, memory, SSD, Windows 7, blah blah) that I have so far and if all is well I will at least install Windows on the 32GD SSD.
We shall see how things go.
Old 09-30-2009, 12:51 PM   #45
Test Progress
So I hooked up the following: (pics coming soon...what a crazy bench setup)
NOTE: I'm not as cool as the majority of you that have your own garage or shop...I'm working with what I got, out of an apartment.
  • Intel D945GCLF2D Mini ITX motherboard
  • PSU
  • Ethernet cable
  • 2GB DDR2 Memory module
  • 32GB SSD (via SATA connection)
  • Power Switch
  • Dual USB to Motherboard header cable
  • PS/2 Mouse & Keyboard
  • LCD VGA Monitor
  • Audio out
  • DVD-RW/ROM (via SATA connection)
The system booted so fast I missed the F2 prompt for me to access the BIOS. Once I got to the BIOS I set it up to boot from USB because I created a Windows 7 RC bootable USB. It successfully booted using the Windows 7 USB and I was able to proceed with the install.
So that's as far as I got for now. I will start working with installing motherboard drivers and all the other driver installation drama that's involved with any new system.
Subaru Impreza 2.5RS '05 Wagon Install... on a budget Pseudo Nim Show off your project 35 06-24-2008 03:38 PM
2004 Nissan Maxima Install BobbyCreekwater Show off your project 7 05-14-2008 08:22 AM
Freak show - 22 year old Nissan install Yuriy Show off your project 28 09-18-2007 01:09 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
'98 VW Passat 1.8t, budget install Beehphy Show off your project 4 06-11-2007 05:26 PM
