Well, I guess I should finally start a worklog on this thing. As you can tell, I have been a member since '06... and that is pretty much when I started my carPC project. My progress has been slowed down by a lot of thing over the years; 2 kids (one born during this project), a new house, a move, a new job, and another house. This has been a strange ride!
Let me give you a rundown of the hardware. This first project has always meant to be a trial run. If this works out, I will go with something faster, smaller, and a little more modern for version 2. I patched as much as I could from old PCs I had laying around the garage.
Hardware
Enclosure: Custom (steel/aluminum)
MB: Dell GX280 - found this out in the garage
CPU: Intel P4 2.8 GHz - found this attached to the mb!
Ram: 512MB DDR2 - had this laying around as well
Screen: Lilliput 629 7" w/ transflective upgrade in a
Mechatroniks bezel (for now)
HDD1: 8GB CF with IDE adapter (started off with 2GB, but realized it was going to be too small for my needs)
HDD2: 3.5" 120GB SATA - had this laying around
PS: DSATX w/ a Brainstem
Radio: HQCT (the first version)
BT: Cellink BTA-6030 w/ BlueSoleil drivers
Wifi: Engenius EUB-362 EXT
DVD drive: Panasonic UJ-825 w/ usb enclosure
Sound Card: PCI Sound Blaster Audigy 2 ZS
Misc. Hardware
BT Keyboard: Freedom Mini keyboard
Joystick: ALPS RKJXT Encoder/Joystick w/ GPWiz usb adapter
TPMS: Robby's homebrew TPMS using the 3rdEye kit
Backup Camera: Hacked Nitemax camera using custom mounting solution for trunk keyhole
Audio Amp: (2) David Navone AMP100s to power the stock speakers
Custom PIC solution for auto switching Lilliput for backup camera
Software
OS: nlited XP SP3 (hope to use minilog as well as EWF)
Front End: Ride Runner
Skin: Have not decided on one yet, currently using DFX4
Nav: iGuidance 2009
Automation: Girder
Antivirus: AVG Free
Xport3
VNC
Progress (05/07/2009)
I have nearly all the hardware for this project. I have decided to add another fan in the case for the DSATX. That is on the way and I will have to knock a hole in the case for it. No big deal though. I also need to put together some relay boards for the HQCT (to control power on correctly) and the DSATX (remote amp line). One of the big things I need to figure out yet is how to install minilogon and enable ewf so I can use the CF card as my OS drive.
I have decided to make May 15th the start of the install. I have a slew of install parts on its way. I realize that I will not have everything perfect before it goes in the car, but I am going to have my main three concerns implemented: navigation, mp3s, and AM/FM radio. I will have to add the rest as I finish the hardware/software for it. Here is a rundown of what I need to finish up though:
TMPS: Hardware is done. I need to have the sensors mounted on the wheels. I also need to create a skin for the DFX4 skin. I have not tried messing with skins yet, so this will be a learning process.
Backup Camera: I am waiting on the design of the bracket for this. I am having a friend help me with the design and fab. This will run directly into the screen.
Cell Phone Control: I am currently attempting to use the
BT phone plugin by lambosprit. I will also need to make a skin for this as well.
Music: I desperatly need to organize my mp3 collection and download coverart for everything. This is going to be a daunting task, so it will come as time permits.
Well, that is all for now. I will try to get some pictures up of the car and everything this weekend.
Edit: Here is a picture of my car. This picture is about 4 years old now. I am using the wheels show as winter wheels now.
