Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 05-18-2009, 05:02 PM   #1
eigenVector's Avatar
eigenVector is an unknown quantity at this point
05 Pontiac Grand-AM - AMD X2 7850 CarPC
So here's my official work log for my carPC
Vehicle: 2005 Pontiac Grand-AM SE1
Motherboard: Zotac GeForce 8200 mini-ITX
CPU: AMD X2 7850 Black Edition Dual Core 2.8Ghz 95W
Memory: 2x2Gb G.SKILL DDR2 1066Mhz PC2 8500 RAM (@800Mhz)
Case: Silverstone Sugo SG05-B Mini-ITX Tower
Hard drive: 1x OCZ Summit 120 GB MLC SSD ** Updated
Power supply: Opus 360W Intelligent DC-DC PSU
Monitor: Lilliput EBY-701
Keyboard: 1x Logitech Mini Dinovo Bluetooth Mini Keyboard ** New
Front End: Trying out Centrafuse + Building my own using WPF & C#
eigenVector is offline   Reply With Quote
Old 05-18-2009, 05:03 PM   #2
Place Holder - The Issue Log
Issue #1: I purchased a mo-co-so case, however I was unable to fit the planned OCZ HPC Reaper DDR2 memory modules into the case. These puppies are just too tall!
Resolution: Put the HPC Reaper memory modules into my desktop to bring it back up to 8GB. Purchased G.SKILL DDR2 1066Mhz memory instead.
Issue #2: I purchased a mo-co-so case, however I was unable to find a decent heat sink to fit the case.
Resolution: Purchased the Silverstone Sugo mini-ITX Case
Issue #3: I had originally installed a 125W AMD Phenom X4 9850BE Quad core CPU, however this puppy ran really hot on my afternoon commutes after a long day of sitting in direct sun light. Core temperatures ran into the mid 60C's when I decided to just turned it off.
Resolution: My father was building a new computer, so I had him purchase me the AMD X2 7850 Black Edition CPU, and trade him the used Phenom.
Issue #4: Nowhere to mount the monitor! The one place I can mount it, it leans forward causing the adhesive to unstick and the monitor to fall forward... I hacked a really nasty looking rig that adds pressure to the mount from the windshield. It's not pretty, but it works.
Issue #5: Sleep issues with the Zotac board. So aparantly my zotac board won't wake up from sleep mode correctly with windows x64. For the time being, I reverted to Windows 7 x86 edition. This corrected the issue.
Issue #6: Deluo GPS went out... Wow the battery just started growing and I think it'll explode sometime soon if I keep it in here. I replaced it with a nice QStarz BT-q890 MTX receiver. It listens on blueooth and works over usb, so I can have 2 comm ports to it without using a software com port multiplexer.
Issue #7: So my factory battery has got to be replaced in my car. It's just not going to cut it with the amount of power I'm drawing. I'm replacing it with a new deep cycle battery.
Old 05-18-2009, 05:03 PM   #3
Place Holder #2
Old 05-18-2009, 05:06 PM   #4
Place Holder #3 - Development of the Front End
Edit: With the purchase of the Lilliput Eby-701, the plans for this application have been scrapped.
Device: AT&T Tilt
Device OS: Windows Mobile 6.5 Professional
CE OS: 5.2.21502
Build: 21502.5.0.70
ROM: HyperDragon IV
I configured windows 7 RC1 to auto-login.
I wrote a WPF app in C# 3.0 (.NET 3.5) that exposed a TCP Service for exchange of message to a Windows Mobile device that's connected to the network.
I configured windows to automatically start the app on startup
Functionality includes:
- Sending screenshots of desktop to windows mobile device
---> Partial screenshots at multiple zoom levels and quality levels
- Allowing sending of finger touches from the windows mobile device to provide mouse clicks to desktop
- Playing of music and video by making use of Windows Media Player ActiveX control
- Allowing the sending of play/pause/ff/rw/stop/next/prev commands to windows media player
- Allowing sending of screenshots of WMP to windows mobile device for watching videos and music visualizations (Currently ~4fps)
---> Have plans to replace this with streaming the video content to a WMP Mobile active x control while still playing audio through the car stereo.
---> Haven't thought through this yes, since I know there will be delays between the audio and video
------> I may attempt to stream the file to the phone for complete playback on the phone, and having the phone send the audio back through the carPC, but this seems like a bit too much work.
------> I'm considering using UDP multicasting for transmission of video, since it supports dropping datagrams when there is no device present, and should automatically connect when I plug the phone in over activesync.
- Added support for viewing video and desktop images in both portrait and landscape mode.
- Allowing browsing of PC file system on windows mobile device for easy playing audio/video and enqueing files for playback.
Planned functionality:
- Currently I have a GPS Tracking application that I wrote running on my Windows Mobile phone. I plan to migrate this application to the CarPC for navigation enhancements.
- Quick access to favorite news sites (DrudgeReport/Boortz) as morning headline viewing for my morning commute
- Quick access to weather information based on GPS data
Old 05-19-2009, 10:36 AM   #5
Pictures!
2009-04-13: Zotac motherboard with original OCZ HPC Reaper memory chips and AMD Phenom 9850 Quad Core CPU:
2009-04-26: Swapped out the OCZ Memory with the G.SKILL and installed Arctic Cooling Low Profile Heat sink:
2009-05-14: Removed HS in preparation to replace AMD Phenom Quad Core with AMD X2 7850 Dual Core. I had to remove the motherboard from the case in order to get the heat sink off:
2009-05-19: After installing new CPU, testing and configuring started putting the components back together. Installed 120mm panaflow fan at the top of the case. (Fit perfectly where the AC/DC PSU used to sit)
2009-05-19: Reinstalled Opus DC-DC PSU into side of the case where a PCI card would normally sit:
Old 05-19-2009, 10:45 AM   #6
skeet2331's Avatar
skeet2331 is on a distinguished road
Do you plan on hibernating the computer? With 4GB of ram i don't know what you will use it all for. 1GB is usually more than enough.
Lilliput EBY701, M2-ATX, Intel 1.8 GHz, 1GB Ram, 160 GB 2.5 hard drive, Centrafuse, Garmin Mobile PC, GlobalSat BU-353.
My 2000 Saturn SL2 Worklog
skeet2331 is offline   Reply With Quote
Old 05-19-2009, 10:49 AM   #7
I'm planning on using s3 sleep mode, however I can't get it to work correctly. Zotac claims it's a bug with vista and this specific nforce chipset. But right now it setup to hybernate.
I'm gonna have a lot of background services collecting data from various peripherals over time, but right now it's only using about 150 mb or so. I've got SQL Server 2008 Express Edition installed, and it will be collecting most my OBD/GPS data whenever I port it over from my Windows Mobile device. So I'm sure I will make use of the 4gb eventually.
Old 05-22-2009, 11:27 PM   #8
So I keep running into issues that's requiring me to use a monitor of some sort. (That is when windows fails to load successfully.) My most recent problem is windows is asking me to launch a recovery session due to a shutdown problem. For some reason windows is defaulting this option instead of "start windows normally" like one would normally see with a 30second time out. So since my remote session service doesn't get started I've got no way to interact with the PC.
I've got a 19" 5ms LCD around the house that I could attempt to convert to DC power, but since I honestly have no idea about the ins and outs of electricity (other than what I learned in physics 1 and 2) I think I'll pass on this option.
As a result, I just went ahead and purchased a Lilliput EBY701 from sharptron over at ebay. This will probably force me to rethink my entire plans. I guess I can create my own front end using WPF since I'll no longer be needing to use my windows mobile as a display.
Old 06-12-2009, 02:30 PM   #9
So I purchased the Lilliput EBY-701.
The VGA+USB cable supplied was not long enough, so I purchased a couple of 'extension' cables for vga and usb.
Belkin 10' VGA Extension Cable
Mediabridge 10' USB Extension Cable
- Both cables run from the PC to the Lilliput custom cable
I also purchased another USB Extension cable and a USB Hub to supply my peripherals.
Tripp Lite 16' USB Extension Cable
Targus Ultra Mini USB 2.0 4-Port Hub
The lilliput itself works great. Picture is good, touchscreen is very responsive. It does have a bad glare when the sun is in certain places, or if the sun is shining on me when I'm wearing a brightly colored shirt, but most of the time it's very visable and readable.
When I plugged it in for the first time I had problems with the calibration test. It told me to tap the little X until the progress bar reached 100%, but every time I tapped the x, the progress bar would reset back to 0, so I just tapped it about 30 times, then gave up and let it go on and reach 100% on it's own.
Also, It seemed that it was sending my mouse position as if it were rotated onto a portrait screen. It wouldn't move the cursor where I clicked, but to a relative position rotated 90*.
After restarting, it all of a sudden started to work perfectly; It started clicking where I selected.
Now... I had to think carefully about where to mount the monitor. And to be honest, I'm still debating this.
- I am not installing it where my stereo is because I do not have an amp, and it's the only thing powering my speakers.
- I cannot mount it on the dash for a couple of reasons
  • 1) It would block my field of view
  • 2) The air conditioning vents on the 05 grandam are cylindrical so it has three bumps, and no flat surface.
I decided to mount it infront of the center airconditioning vent. The problem here is I cannot find an adhesive tape that is strong enough to support the weight of the monitor. The surface where I'm mounting it is flat, but it has two different levels of flatness, one thats above the other, so it's leaning downwards. It was suggested to me to just drill a couple of holes into the casing, and that should take care of it, without destroying the dash itself. I was hoping to maybe find some clips that could fit between the dash and the casing instead but I'm not sure where to look.
If you're curious about the little black thing hanging down from the windshield that looks like a goa'uld, It's a part of the mount I used for my windows mobile phone. I am thinking about making use of it to help stabilize the monitor and prevent it from falling forward, but so far I don't really have that figured out yet.
The monitor in this position blocks my center airconditioning vent, but that's alright. I can aim it up to help air get into the back seating area, and the other two vents work fine to push air around the monitor.
Last edited by eigenVector; 10-23-2009 at 03:04 PM. Reason: Added additional picture
Old 10-23-2009, 12:59 PM   #10
After lots of searching, and lots of reading through varios input threads, I decided to purchase the Logitech Mini Dinovo bluetooth keyboard, and so far, I'm absolutely loving it. I was really looking for a good one handed thumb keyboard, but this one sold me with it's additional cursor touch pad. I thought about using gremote, but it required too many button presses to setup every time I want to use it. With this, I just flip it open, and it's ready to go. I'm also quite pleased that I can finally get into the bios without having to get out of my car and open the trunk. Great work on this one logitech!
Old 10-23-2009, 02:41 PM   #11
Replacing my battery today... with an Excide Orbital (~1000CA/~800CCA) battery. Good bye factory battery!
Updated pic from passenger seat:
Old 10-23-2009, 02:56 PM   #12
I'm revisiting this question due to changes in system configuration. I haven't come across a situation where I've utilized more than 2GB of memory so far. I may remove one stick for a while, but I'm not really worried about hibernating 4gb. if anything, removing a stick could potentially decrease my boot times. As far as disk spaces goes i had a 30GB SSD installed previously, and 4gb is huge on that disk for hibernating. I'm replacing it with a 120GB SSD now, which will help out quite a bit.
Also, I don't really have to worry about hibernation times anymore, because I've setup my computer to enter sleep mode when I turn off my car. If I don't return to the car within 30 minutes, it will automatically wake itself up to enter hibernation mode. This has been explained in another thread, but basically as long as it doesn't take an hour to hibernate, I'm okay with it.
Old 10-25-2009, 09:56 AM   #13
Battery Update:
After replacing the battery I drove the car for about 45 minutes (averaging 65mph) when the battery light came on, followed by my stereo cutting off, airbag light cutting on, security light turning on, and my fuel gauge dropping to empty. I was close to home when this happened and was able to park it before it completely died on me. The engine had a very strange growling sound, and there was a bad aroma coming from the engine.
The guys at Merchant's Tire, who I had just bought the battery from after getting some major engine work done, paid to have it toed back to their shop to see what was wrong. We were thinking they had forgotten to reconnect the alternator or something, but it turns out the battery just had a bad cell in it and wouldn't charge. I am quite glad Merchant's was gracious enough to pay for the toeing out of their pocket and fix any damages they may had caused. I'll be picking it back up today.
How to: Change windows shell IntellaWorks WinNT Based 39 10-13-2008 04:41 PM
Testers wanted for Palm/Windows Mobile front end PDAKey StreetDeck 32 02-11-2008 11:52 AM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
CarPC Front End Looks on Mass Production Radios lfilomeno General MP3Car Discussion 2 06-03-2007 10:25 AM
Telematics.net IntellaWorks Software & Software Development 40 11-05-2004 09:20 PM
