Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 06-29-2009, 12:41 PM   #1
DaXSi is an unknown quantity at this point
2002 WRX-Project MT22
Carputer Worklog for 2002 Subaru Impreza WRX-Project MT22
Asus eeePC 900HA:
Operating system: Windows XP Home
Internal memory: 160 GB hard disk drive (HDD)
RAM: 1 GB DDR2-Will Upgrade to 2 GB DDR2
Processor: 1.6 GHz Intel Atom
Memory expansion: Slot for MMC/SD(SDHC) cards
LCD: 8.9 inches, 1024 x 600 pixels
Networking: 54g Wi-Fi (802.11b/g), 10/100 Fast Ethernet
Peripheral connectivity: Three USB 2.0
External video: One VGA
External audio: One headphone and one microphone port
Webcamera: Yes, 0.3 megapixels (VGA)
Battery life: up to 5 hours
Weight: 2.5 pounds (40 ounces)
Dimensions: 8.9 x 6.7 x 1.33 inches
I plan on keeping this laptop in my glovebox. I want to build an autoconnect tray that will basically clamp around the lappy when i get in the car and hold VGA, USB and Ethernet connections solid, but allow easy install and removal so it is not permanently installed in the car. I will need to create a custom power control system using WOL ethernet capabilities, an asus car charger and a few 12 vdc relays. Will give that system its own line item in the future.
Liliput 7" LCD Touchscreen Monitor:
Item name: 7" Lilliput EBY701 + LCD Frame 701 Bybyte LCDFR701
Frame Dimensions: 177mm Width, 107mm Height and 71mm Dept.
Screen Description:
High Resolution Display up to 1024 x 768
350:1 contrast ratio and LED backlighting - Model 2008 6th Generation
VGA input
Touch Screen Function with USB interface
2 Video inputs
Computer display/S-video/DVD/VCD/Security system/Navigation system/ Rear view camera
Compatible (Cables included)
Native ratio: 16:9 wide TFT screen
Color configuration: RGB stripe
Video system: PAL/NTSC
IR remote control
Full function OSD control (Multi-language)
Video input signal: 1.0Vp-p, composite video
Power input: DC 12V
Power consumption: 9W LED BACKLIT.6TH GENERATION
Brightness: 500
Responsive Time: 30Ms
Will mount in stock double din in WRX. USB touch screen control and VGA video input will come directly off of lappy. Powered via 12vdc from Battery.
Trendnet USB to Serial Converter:
This will basically plug into my Wideband O2 sensor controller which should allow me realtime PC side O2 readings. Will more than likely plug directly into USB Hub.
Tactrix Openport 2.0:
Will be used for Datalogging and Flashing my ECU via Romraider (www.romraider.org) and ECUFlash (www.openecu.org) Will plug directly into USB port on computer to avoid COM issues.
Startup Controller System:
I will basically be running a single 12 vdc dpst relay to turn on power in acc and on key positions but leave it off in off and start key positions so that cranking voltage and current spikes dont get sent to the computer. the second pole of the relay will contact pins 2 and of 6 of the ethernet port while pins 1 and 3 are always connected this will resume the compy from standby using the wake on lan (WOL) function. I am also using ShutControl to control the automatic standby function.
USB Hub:
I decided i am going to run a Macally 7 port externally powered USB hub. I feel external powere will be important as I plan on running a fusion brain and an external sound card in the future.
Frontend:
I was originally gonna run a version of RideRunner for a front end that an AWDPirates member(surtr) had created, he had already embedded enginuity(romraider) to display engine data scrolling across the display but I belive i'm gonna nix that and go with sawmill resized with winamp running on top.
DaXSi is offline   Reply With Quote
Old 07-08-2009, 12:41 PM   #2
Xygar's Avatar
Xygar is an unknown quantity at this point
Have you started the install?
Of course we want some pictures .
I like the idea of the EEE as a removable car PC, I'm really curious how your custom dock turns out. And the custom power controller is very intriguing. Keep us posted!
Xygar is offline   Reply With Quote
Project-Start on VOLVO S80 D5 2002 Diesel-Junkie Newbie 6 06-27-2009 10:11 PM
2002 WRX CarPC stitaxi Worklogs 26 08-28-2008 04:31 AM
2005 WRX STi Car PC Project RR BuGGz Worklogs 59 10-24-2005 09:44 PM
Subaru WRX UK -- Full project Muddy Show off your project 24 08-05-2005 02:36 PM
Carputer as a comp sci final year project? MikeHunt79 General MP3Car Discussion 5 06-23-2004 10:19 AM
