Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 07-17-2009, 04:22 PM   #1
sophistications is an unknown quantity at this point
Smile 94 Accord Wagon CarPC Worklog
Car
1994 Honda Accord Wagon EX
This is an older picture but it pretty much looks the same as it did then.
H&R race springs with Koni Yellows
18" x 7.5" Sendel Chrome wheels wrapped in 215/40/18 Nangkang tires (cheapo tires seeing as I have -3.0 degrees of camber all around :S)
Full polyurethane bushing kits in front and rear suspension parts
Suspension Techniques front and rear sway bars
Intake
Brullen exhaust with custom dual tip piping
auto->5-speed conversion (Honda did not sell any 5-speed accord wagons in Canada)
Rear disc swap (again, Honda only sold the accord wagon in Canada in 94 & 95 and in one trim model: EX with automatic transmission, which is the DX model in the USA)
Current Audio
Pioneer Premier Head Unit
AudioControl Crossover
AudioControl 30-band 1/3 Octave Equalizers
AudioControl Spatial Reconstructor
Clarion Pro Audio 640.4
Soundstream SQL 2-way components (bi-amped)
Clarion Pro Audio 1000.1
Hifonics Titan T1011
Computer Specs:
My old Sony Vaio TX series
Intel® Pentium® M Processor Ultra Low Voltage 753 @ 1.20GHz
Intel® PRO/ Wireless 2200BG Network Connection (802.11b/g)
Integrated Bluetooth® Technology
11.1" WXGA display (1366x768) with XBRITE™ technology
80GB (4200rpm) PATA
1GB PC2-3200 400MHz DDR2 (512MB x 2)
Disassembled:
IMAGES HERE
Carputer Plans
Carnetix P-2140 to power laptop @ 16V
USB GPS receiver
USB Soundcard - still need to choose one
USB Griffin RadioShark
Audiocontrol Four.1 - To control line out volume from USB Soundcard and to add iPod AUX input for iPod connectivity
Input: Logitech DiNovo Mini and Ergonomic Touchpad
Extended range WiFi Antenna for the roof
Install plans
I will be using turbocad6's method to fabricate my custom dash. Cheers to turbocad6for a GREAT writeup, now I just have to source the Dynatron in Canada - does anyone know of any sources in the Greater Toronto Area?
11.1" LCD display from laptop to be mounted at the top of the in center console - The internals of the laptop are rather small and I will be fabricating a housing to attach to the back of the screen to hold everything.
The P2140 will sit in the dash behind as there is a lot of space back there and there will be 3 custom fans to keep the area cool.
I am also trying to figure out a way to utilize the optical drive out of the laptop but the ribbon connecting it to the motherboard wont allow it. Will report back on progress in the coming days/weeks.
AudioControl Four.1 below the LCD - my preference is a hardwired volume control as opposed to having it software controlled.
3 USB ports below the AudioControl for expandibility
Stock ashtray and cigarette outlet will remain intact.
Pictures
You can see how the optical drive is right beside the HD, it is connected by a ribbon with plugs on both sides so I am scrapping the optical drive and may opt for a USB one later on.
Everything is so nice and compact, I will be fabricating a bracket to mount it to the reverse of the LCD screen that will be mounted in the center console below.
This is my center console
You can see the lines where I will be trimming the console to recess the LCD
A better idea of the fabrication that will be required as the console angles in... I am thinking of building the curves with ABS sheets and then dynatron over that to create the stock look...
sophistications is offline   Reply With Quote
Advertisement Sponsored links
Old 07-18-2009, 11:44 AM   #2
zillacles is an unknown quantity at this point
Hey, nice to see another Accord on here. I have a 95 sedan, and was thinking of possibly putting in a bigger screen, but I just cannot see how it is possible to put in a screen that large in our centre console/dash ? Are you replacing the whole dash so it can fit? I can't wait to see some pictures.. will be really interesting
zillacles is offline   Reply With Quote
Old 07-18-2009, 12:51 PM   #3
Reserved...
Old 07-30-2009, 12:46 PM   #4
Some more progress pictures.
I have cut out the opening for the monitor to fit in, I am still waiting very anxiously for my dynatron plastic stuff in the mail...
Old 08-10-2009, 11:45 PM   #5
So today was the day that I visited Plastic World at Sheppard and Allen Rd in Toronto. I picked up 3 sheets of scrap Plexiglas to use for my carputer build for $7.00 plus $3.99 for the cement.
I must say the gentleman there was EXTREMELY helpful and knowledgeable... I highly recommend dealing with this place and will do in the future.
There are a lot of pictures as I am trying to document each step of the fabrication process as well as possible.
I didn't run into any major problems at this step other than not being able to score and break the Plexiglas in a straight line.
For the smaller bits located in later pictures I ended up just using a hand saw to cut it.
I was able to score the Plexiglas and then snap it into the following pieces in order to make a faux box in which to mount my laptop internals into...
This is WELD-ON #16 Clear Solvent Cement, perfect for joining Plexiglas, acrylic etc. It is a thicker consistency rather than just using liquid epoxy.
It was recommended to use this product by the guys at Plastic World because it is perfect for welding two or more pieces of plastic together that are not perfectly perpendicular to each other (or perfectly square) as in my case with the poor attempt at cutting the Plexiglas.
Below is a close up shot of the cement in action, it flows viscously into the spaces created from a non-perfect cut, melting the plastics together and then forming a solid joint within a minute.
Almost done...
AND THE BOX IS DONE!!! I was so excited... I still am just talking about it.
This was my first attempt at cutting and welding plastic together and it was so easy... I youtube'd some videos on using Weld-On #16 and found some useful tutorials... I'll try and dig up the links and post them here.
So I dropped in the laptop guts and started to mock up the fittings...
There will be ample room in this case for cooling, which i will document in later posts once it is completed
This is the back of the LCD screen from my VAIO laptop, I had to modify the housing to make the wire come out where the board is so that I have enough play to hook it into the motherboard without extending the wires.
You can see here that I dremeled out a hole before actually measuring anything and had to abandon it in favor of one with easier access
And the proprietary connector...
Just a quick mock up of the case and how the motherboard will be mounted.
Dremeled out a hole for the single USB port that will power my 7 port hub I got off of trusty ole eBay
A closer shot... This Plexiglas stuff is really hard to work with, it can be so brittle yet a dremel will melt it causing it to warm when trying to cut straight... I haven't yet figured out what tool would be best to create holes like this...
Here is the hole that the LCD cable will pass through... I started it with a drill bit then played around with the dremel... not the cleanest, I will fix it up later...
The next two pictures show how the USB will line up with the opening, The motherboard has it on a ribbon cable that I will have to bend up and mount to the Plexiglas in a weird manner... I will be experimenting with different screws in which to mount them with... see below...
Here is the monitor connector beside my drawing of where it will actually be...
These are the feet that will be glued to the bottom of my case that the motherboard will sit on and be screwed to... I didn't want any metal to be exposed therefore I glued three 1/8 thick sections of Plexiglas together, I must now find screws small enough to actually hold the motherboard into these "feet"
The box was made to fit snugly into the factory DIN space allocated for any stereo. I will be bolting it into the metal brackets you see on the left and right side with rubber grommets to dampen any harsh road conditions...
Here is a back shot of the LCD in place... There is little room between the LCD and the computer case, which is intentional as this setup requires the LCD to be close to the motherboard as I didn't want to extend any LCD ribbon cables...
So that was my day today...
tomorrow I will be mounting the "feet" and motherboard to the case, I will be mocking up the top lid of the case and fabricating the cooling system...
My Dynatron arrived in the mail a few days ago but I cannot start to mold the LCD into the center console until my case is completed...
Stay tuned for more updates...
I am also working on a piece to contribute to the WIKI under the plastic fabrication section... I am hoping that I can document some good pictures and write some instructions... We will see how dirty my hands become when attempting this as that will affect how many pictures I can take (don't wanna ruin my borrowed camera... THANKS SIS!)
Old 10-27-2009, 09:41 AM   #6
Hey, how have you been going with this? Interested to see how it turns up as I'm thinking about moving my screen from down below in the centre console to higher up. It's only a 7" though, so not as big as yours, but still would be better having the screen in a more friendly location.
Old 11-02-2009, 08:52 PM   #7
Well, I had finished molding the lcd into the center console, but when i went to mock up everything and power up the computer, NO POWER... ARGH!!!
so basically this whole setup is trashed because I have tried to test every connector and ribbon cable and I just give up. Finding another VAIO laptop (VGN-TX51P) might be near to impossible since they were $2500+ in 2004 so if anyone is interested in purchasing this LCD already pre-molded into a 94-97 center console, PM me...
Anyways, I caved and ordered a lilliput touchscreen from mp3car store... I should have it by sunday and will hopefully have the system up and running by the next sunday (pending cold weather)
I was so tempted to get the 10 inch model and fab it up but that would leave 2 inches of space below it for my add-ons, which is not enough space...
Going back to the fabrication... I thought my use of dynatron turned out pretty well, its too bad I have to abandon it... This stuff is so much easier to work with than bondo or fiberglass
some pics (sorry for crappy blackberry quality)
Old 11-03-2009, 07:30 AM   #8
Damn man that sucks about the laptop. Maybe it's a good thing as that screen might not have been as readable as a Lilliput (which is pretty bad in itself) in sunlight? Anyway it sucks with our car how the centre console and heater controls are separated like they are, because otherwise could put the screen in between them so it's higher up.
Good luck with the install
Old 11-04-2009, 10:28 AM   #9
hexxamillion's Avatar
hexxamillion is on a distinguished road
I feel your pain. Same issue with my EEEPC..of course no where the status of you Sont definitely was an inconvenience. Nice work though. You gave me an idea on how fix some spacing I have around my exhaust fan.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 11-17-2009, 11:23 PM   #10
So I got my Lilliput touch 629GL screen from mp3car.com store and I realized at once how small it is... I don't think I like it too much, I'm kinda regretting not buying the 10.4 inch one now...
Anyways, I sat in my garage today playing around with the screen and thinking of ideas of how to mount it. I didn't want to open the case and mold it into my center console so I came up with something ingenious (in my opinion )
I also wanted to recess the screen a bit and add some sort of cover to attempt to shade the screen from the sun...
After spending about 20 minutes ripping my beautiful 11.1 inch Sony LCD out of my center console I immediately began to cut and shape some ABS plastic to form the pictures below.
Since the Sony laptop crapped out on me I had to find a different setup. Luckly my girlfriend was kind enough to donate her ****ty Acer Aspire One 8GB SSD netbook. So far I have been loading software (Ride Runner, VLC, Winamp, etc) on it and it doesn't lag how it did when she used it for word processing, youtube, music, internet, skype, peer-to-peer (you can see why it kept freezing) The netbook will have a home in my glovebox... more pictures to come when I move on to that part of the project...
ONTO THE PICS
There are quite a few so you can get an idea of what I did today, and yes this was all done today from 3pm to 9pm... I gave up going to the gym because I was so into it...
Comments? I'd love to hear em...
I am working with Ride Runner and it appears to be an interesting program to skin (which I will be embarking upon in the winter months...)
Old 11-18-2009, 01:10 AM   #11
firstorbit84 is an unknown quantity at this point
Nice work, but I'm confused about what the three holes to the right of the monitor will be for?
And you should rename this thread from a "worklog" to a "picturelog"
firstorbit84 is offline   Reply With Quote
Tags
accord, plastic bezel, sony, wagon
2004 Accord navigation with carPC blazer563 Newbie 21 11-11-2009 03:54 PM
2003 2004 2005 Honda Accord CarPC Adam2312 Newbie 161 02-09-2009 10:25 PM
Accord '94 Head Lights i3igmind General MP3Car Discussion 6 05-16-2006 11:10 PM
WTB: Accord 94 LX Air Bags i3igmind Classified Archive 8 07-25-2005 03:12 PM
OBDI and Honda Accord ('94( Envitro99 Engine Management, OBD-II, Engine Diagnostics, etc. 2 12-07-2004 02:12 PM
