Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 10-30-2009, 12:01 PM   #16
Tical84 is an unknown quantity at this point
Quote: Originally Posted by hexxamillion View Post
That's one of the things I don't like about Windows. Why not just make the one product then have the consumers choose what they want to during installation process, like what is done on LINUX. Then there would be no confusion..it could be as bloated as you want or as lightweight.
Because then they'd have to charge the same (most likely, cheaper) price since there would only be one version. This way they can say "You don't want to pay a couple hundred dollars for an OS? Well, we have a cheaper version, it does nothing you want it to do, but we have it."
I ended up getting Ultimate. Any tips on how to de-bloat it? I saw there was a good thread on speeding up XP but nothing on 7 yet. Right now with a fresh install, no software installed (even RR) it boots in 55 seconds on an old 7200RPM HDD. Haven't been through msconfig or services yet.
Tical84 is offline   Reply With Quote
Old 10-30-2009, 01:20 PM   #17
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
We may have to wait until nLite is updated to cover Windows7. That may not be long -- that's a pretty good package, and the developers seem to pay attention.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 10-30-2009, 03:15 PM   #18
hexxamillion's Avatar
hexxamillion is on a distinguished road
I am not much on the whole Windows thing as I am linux but nLite I know was used for XP. I came across vLite which was used for Vista and recognizes Windows 7 as Vista, supposedly compatible. There is also a forum. Google around there are all kinds of forums out there.
vLite
Windows 7 Lite Builds Forum
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 10-30-2009, 03:27 PM   #19
Ya, I poked around Google a bit and found that theoretically VLite works but I also noticed 7 has only a fraction of the programs and bloatware that Vista and SP2+ XP have so it may be alright. What are the boot times for your Windows 7 systems?
Old 10-30-2009, 05:40 PM   #20
Raw Wave
treetop777's Avatar
treetop777 is an unknown quantity at this point
That's a nice volume control and you're right, that coin holder is about useless!
A questions about volumouse if i may, what "condition" did you set in the configuration to tell the mouse to act as a volume control instead of scrooling? I would hate to have to press a key on a key board first everytime i wanted to control the volume.
BTW - maybe to late now, but i would go with XP, everything you through at it work. Seeing as though you already decided on win7, i hope volumouse work with it since it hasn't been tested on win7.
Then again, you can be the guinea-pig for all of us j/k
Good luck on the install. i also have a 2005 F-150 and will be watching.
Intel D945GCLF2 Dual Core ATOM
Lilliput 7" 629GL 2008 LED Backlight
BU-353 USB GPS Receiver / iGuidance / IGO8 / Garmin
M2-ATX Power Supply
RideRunner Front End / Various Skins
Windows XP SP3
treetop777 is offline   Reply With Quote
Old 10-30-2009, 05:49 PM   #21
You can set it up so that it works when a certian window is active, in my case, RR and no key is required. If you need help I can explain it better or even take a screenshot when I get home from work.
Thanks. It's starting to snow here already so it probably wont be installed until Spring but I'll keep updating as I collect parts and test software. That's actually one of the reasons I went with Windows 7. I have lots of time to test everything out and work out the bugs.
Do you have any glare problems with the LED Backlight in the 'Fiddy? I'm wondering if LED backlit is good enough, or even a normal LCD or if I should splurge and go for transflective.
Old 10-30-2009, 06:21 PM   #22
Raw Wave
treetop777's Avatar
..I'm wondering if LED backlit is good enough, or even a normal LCD or if I should splurge and go for transflective.
It is more than adequate, in fact, it will blind you at night. I also matched the rear window tint to the front windows so it's pretty dark inside the truck. Your skin looks preety bright too so i don't forsee a problem with just getting an LED backlit.
Good info on volumouse - let me go play a little.
M2-ATX Power Supply
Windows XP SP3
Old 10-30-2009, 06:24 PM   #23
Ya, I feel like I'm going to need a night skin or a gamma control button/slider for sure.
Volumouse is really easy, you'll figure it out.
Old 10-30-2009, 10:58 PM   #24
So far I have had no issues whatsoever relating to Win7 and drivers. I think he will be fine.
Old 10-30-2009, 11:11 PM   #25
Regarding bloat..I don't personally don't view Windows 7 as bloated much but you could do some tweaking with msconfig. In addition, it boots within reason for me. I have not clocked it. I would rather have full support as possible than a stripped down version such as the vLite...that's just a personal preference.
Old 10-31-2009, 12:21 AM   #26
Volumouse works as great as before, I just need an active PS2/USB adapter because the only PS2 port on my mobo is for a keyboard. Could I plug the mouse in there? I haven't tested it yet.
I don't see the point in having my OS be able to do absolutely everything when I'm not going to use it to do absolutely everything. If this was a desktop PC for home, sure I'd leave it, go get a drink of water while it boots for 2 minutes, but in a carPC application I want it playing my tunes or guiding me around a new town before I leave the driveway. 55 seconds isn't unreasonable, but I know it can be better. Surprisingly msconfig was empty and there were only 39 services. Much improved over XP and especially Vista.
Old 10-31-2009, 01:47 AM   #27
Yep. You might look into the Powershell also. You could probably do some major tweaking and automation through it. If you have the Windows 7 Ultimate you should have Windows PowerShell also. Not sure about the other versions if its standard or not.
Old 10-31-2009, 01:49 AM   #28
Just in case here is some info on Windows PowerShell.
Old 11-05-2009, 09:56 PM   #29
More progress!!
The case is mostly done (needs a top) and the mobo is securely mounted. The case, although not as pretty as, is based off of blk02si's dimensions from his Mustang build. I did what I could with what I had. It's functional and no one will see it anyways. I'll call that a win.
Old 11-05-2009, 10:33 PM   #30
Raw Wave
tbird2340's Avatar
tbird2340 is on a distinguished road
Looks sweet man.. I have a similar setup in my wife's car (link below).. I'm assuming you test fit to make sure everything was OK behind the dash? It was tight for me but I got everything in and up and running..
Wife's Vehicle: 2007 Dodge Nitro
Current Vehicle: 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
tbird2340 is offline   Reply With Quote
Testing Opus 150 via ATX - Computer is Continually Rebooting long.1 Power Supplies 13 07-19-2007 02:57 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Where to DL old version of RR? accentsound Road Runner 14 07-12-2005 01:51 AM
