Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 11-06-2009, 01:04 PM   #31
firstorbit84 is an unknown quantity at this point
Quote: Originally Posted by Scrambles View Post
awww, that is an easy fix!
You need a Ground Loop Isolator, keeps feedback from going back into the sound card.
http://www.radioshack.com/product/in...ductId=2062214
Cheers! Glad to hear its not a serious problem....
Man that thing has great reviews, so I'm assuming that it works. Looks like I'll be stopping by "The Shack" later. Only Problem is that I'll also have to buy adapters to get it to 1/8" mini-jack and back. $$$
One other thing I've been wondering is if the radio antenna cable can just be cut and spliced like any other cable, or is there something special to it, where it'd be best to buy a pre-made adapter/extender??
I've also been thinking that this is likely to be build version 1.0 and things will change in the future. So, here's what I currently have planned out for my 4 USB ports [3 external (2 front, 1 rear) & 1 internal]:
1 Internal:
USB Touchscreen Controller and 3 port hub
Internal 3 Port Hub:
GPS
MicroSD Reader with 4GB MicroSD Card (for Primary Media Storage)
Open (Future: To be used with relocated Built-in Webcam as back-up camera)
1 rear:
Bluetooth Dongle (only thing that will fit right now because of room)
2 Front:
Both Open for connecting following devices on the fly:
Phone (for internet, charging and music)
iPod
External HD (to load new media)
keyboard/mouse (only when updating/changing settings)
Other flash drives, etc.
My Tentative future version 1.5 setup (when I redo everything in about 6 months to a year to add the BT calling kit and other accessories):
MicroSD Reader with 8GB or 16GB MicroSD Card
Bluetooth Dongle
Webcam
1 rear:
USB 2.0 7 port (Self-Powered??) Hub connected through right angle USB cable/adapter for fitment
USB Hub:
80 GB External HD
GPS
OBDII
Mini Keyboard/Mouse (to be mounted in glove box)
Rest open
2 Front:
Open for connecting game controllers and other devices on the fly...
firstorbit84 is offline   Reply With Quote
Old 11-06-2009, 05:32 PM   #32
Progress:
Radio Shack Ground loop Isolator FOR THE WIN! It works perfectly and removes about 99% of the noise with no appreciable loss in sound quality....Although I did have to buy a stupid $6 Phono to 1/8" adapter like I suspected. Total came out to $24 after tax, bringing my grand total to $370! :O
I could have waited and bought one off of ebay for about $12, but I still would have had to buy the adapter, meaning I only would have saved about $6 bucks.
All in all, a good day in the build. I passed the in-car charging and audio test. Thanks for the tip on the isolator Scrambles!
Old 11-06-2009, 06:52 PM   #33
Scrambles's Avatar
Scrambles is an unknown quantity at this point
no problem! im setting up a VERY similar build in Dec-Jan (when i get paid) EEE 7" with touch screen, yada yada yada
Quote:
If its not broke, try and fix it.
My First Carputer
Scrambles is offline   Reply With Quote
Old 11-07-2009, 11:55 PM   #34
Progress:
Glovebox removed:
Note to MkIV owners: DO NOT go through the trouble of removing both lower center console pieces to get at the single hidden screw tab. JUST BREAK IT! I properly removed everything and it took me about an extra half hour or so of work only to find that 1. The tab is not even necessary to hold anything together. 2. It was about 90% broken already once I got to it, and immediately broke once I took it off.
Glovebox marked for cutting:
Glovebox cut:
Note: I will most likely cut a little more off the back where you can see that bit hanging down, as the front door really comes in close.
Another note to MkIV VW Golf/Jetta owners: The early style glove boxes (<'03) are smaller than the late style glove boxes because of some useless metal that VW decided to put behind the glovebox to the left. Pictured here (all of it should be removed, but the part circled in red may require cutting?):
Finally, I added two mounting brackets made of strips of aluminum with holes drilled into them to either side of where the head unit will go. I will get some pics of it installed tomorrow. Also, I think that the antenna wire should reach with out extending it any further, and I WAY over-extended my factory wiring harness by about a foot and a half. Oh well...
My only concern now is whether I should cut another hole to retain the factory glove box light, and I'm leaning towards yes.
Old 11-08-2009, 04:07 PM   #35
Progress:
Okay, so I got the CD player installed in the glove box today with the PAC IR-X infrared repeater to control it through the remote with the glove box closed.
Here is a shot of the mounting brackets I described earlier:
Here is how the head unit fits in the glove box, from the rear:
Then I had to go back and remove the metal bracket which was circled in red above. It doesn't need to be cut off but it is certainly a PITA to remove because of the three 8mm bolts with one only accessible with an open wrench that I had to go buy from Harbor Freight cause my set only went down to 10mm!
Anyway, once the offending bracket was off, the head unit, now mated to the glove box, fit like a glove.... box.
You can also see there that I relocated the stock glove box light, and swapped out the bulb with a red LED. I think it came out pretty good.
Then, once I made sure that all the wiring worked properly, I took everything back out to take out the radio cage, so I can fab up the Eee PC mounts this week. It left me with quite a large hole in my dash:
I held the Eee up in the different ways I imagined it might fit. First, is the way that I'm currently planning it:
The good thing about doing it this way is that I'll have both of my "front" USB ports accessible beneath the LCD screen. This way however, will extend beyond the dash about 1/2" and cause my screen to be tilted up at about a 10-15 degree angle.
So, a buddy of mine said that it would look a lot cleaner if the screen were flush mount, and I could build in some tilting mechanism later. Then I'd just have to get a USB hub sooner than I intended or run some USB extension cables from the side ports. Here is the fitment test sideways:
You can't really tell in that picture, but there is only a slight plastic tab on the right preventing the computer from going all the way back. And with a little cutting, there is plenty of room on either side for cables and such.
So, I'm kinda torn between mounting positions now. Any thoughts???
Also, while I had everything apart, I ran the USB cable for my GPS:
Finally, I scored a sweet deal on a used Parrot CK3100 this morning on eBay. Only $48 shipped!! Plus I had to buy a $4 right angle 1/8" adapter at Radio Shack to get the Auxiliary Input cable to fit in the glove box as you can see in the pic above. These two items bring the total cost from $370 to....... drum-roll please...... $422!!!! OH
Old 11-09-2009, 12:48 PM   #36
Scrambles's Avatar
i would go for the flush mount way
My First Carputer
Old 11-09-2009, 01:21 PM   #37
yeah I think I am gonna go with the flush mount. I didn't realize how much room was back there with a little cutting. I may have to find a right angle adapter for the power cord connector in the back or even tilt the mobo a little to make it fit, but it will definitely fit sideways. I also found a USB hub on craigslist for $5 and that will solve the problem of usb port accessibility cause I'll just run it to the glove box. Plus it won't get in the way of the AC controls this way and I won't have to fab anything to cover the sides of the screen.... It'd be nice if I can find a way to tilt it when I want to though. My buddy suggested those little cabinet door latches that you push once to open and again to close like this:
http://www.lowes.com/lowes/lkn?actio...89973-P655-STB
Old 11-09-2009, 02:14 PM   #38
Sheepdog
rdholtz's Avatar
rdholtz is on a distinguished road
Take a look at Rockler.com for other latch options.
If just enough is really good, then too much ought to be perfect.
2006 Scion xB with in-dash Atom & Lilliput 889GL -- Worklog at http://www.mp3car.com/vbulletin/work...res-links.html
rdholtz is offline   Reply With Quote
Old 11-09-2009, 08:18 PM   #39
It doesn't look like they have much more selection than Lowes.
Progress:
Tonight I picked up the final piece of hardware for the build: a Rosewill 4 Port USB Hub for $5 on Craigslist, new in box! This brings the total to $427!
Anyway, cost aside, this will give me plenty of options for accessories as I have 3 on-board external USB ports, which will have a 4-pot hub connected to one, and with the touch screen controller's built-in 3-port hub connected to the internal webcam USB port, I'll have an additional 2 ports, giving me a grand total of 8 available USB ports!
I know I've gone over this before, but I'm still not sure exactly what I'm going to connect to where yet, as I have so many options now, but I think it will go something like this:
3 Internal ports(Don't want to overload this hub because of reports of failure)
Bluetooth
GPS?? or MicroSD reader or open?
Open for webcam relocation later
1 Left External Port
Mini USB cable routed to center console to charge phone (and tether?)
2 Right External Ports
4 port USB Hub
GPS
4 port hub
External 80GB hard drive (may take two ports)
MicroSD reader
2 open for:
Mouse
Keyboard
iPod
Flash Drive
Finally, here's a shot of what I'm trying to fit in where:
Old 11-10-2009, 02:06 AM   #40
More Progress:
Eee Disassembly:
Comparing LCD Bezel to radio cage (I've got some cutting to do ):
Removed things I won't need like speakers and webcam:
Note: Wifi antennae (black and white wires) also came out too to be relocated.
LCD separated from mobo (incredibly light mobo BTW):
It almost fits without even cutting anything:
Heat spreader removed from plastic bezel:
Test fit of new cooling:
And that's where I'm at.... Tomorrow: let the dremeling begin!
Old 11-10-2009, 02:13 PM   #41
hexxamillion's Avatar
hexxamillion is on a distinguished road
EEEPC's are so fun to hack up. That's why I loved mine before it dies. Now I'm just repurposing out its parts with my new project.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 11-10-2009, 03:40 PM   #42
how'd yours die??
Old 11-11-2009, 11:08 AM   #43
Quote: Originally Posted by firstorbit84 View Post
how'd yours die??
My just would not power up anymore. There are tons of forum posts out there about this issue. I got it to power up briefly but it just shut back down. i did the whole resetting CMOS in addition to draining the power...blah blah.. It's all good though I had it for a few years and it worked great during that time. I do miss the portability.
Old 11-12-2009, 02:46 AM   #44
jgildert is an unknown quantity at this point
Just a message of support mate! Looks like you're doing well and this thread is going to make my mate wanna do his car, as he was so jealous that I can get a 10.2" in my crappy Clio! I bet you felt really guilty hacking your car apart as I know I did, and i was literally hacking apart!. I'll keep an eye on this one and i'll be up in the afternoon, hopefully posting on my progress as i've just finished night shifts and i'm shattered!
Regards,
John (Bolton, UK)
Check out my worklog!
http://www.mp3car.com/vbulletin/work...c-install.html
jgildert is offline   Reply With Quote
Old 11-12-2009, 01:42 PM   #45
Oh man, I hadn't heard of that problem. Sorry to hear about your Eee. Is there any explanation for what caused it?
I started cutting into the radio cage and it looks like the mobo will fit quite nice:
Tags
asus, eee-pc, eeepc, volkswagen
VW Golf 3 GTI car pc introduction azizi Worklogs 23 05-31-2007 01:58 AM
Budget car pc build for ~400 bucks..opinions fliplyricist1 Newbie 17 05-26-2007 09:44 PM
VW Golf TDi MK4 2002 ODB cable confusion - which one is the right cable? f1lby Engine Management, OBD-II, Engine Diagnostics, etc. 3 02-19-2007 08:19 AM
