Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 04-23-2005, 07:02 PM   #121
My Village Called
0l33l's Avatar
Quote: Originally Posted by rafaelsherman
Still getting some money together, It's between an Infinity I30 (96-99), Honda Accord (V6?) (98-2000), Lexus ES300 (94-95), and finally Acura Legend (94-95).
Decisions.....
Peace,
Rafster
Those are all good cars
PowerVoice v1 | NaviVoice Source
GammaControl v2.4
SKINbedder v3
1995 Lexus SC300 <-- Weekend Car
1997 Mazda Miata <-- Daily Driver
0l33l is offline   Reply With Quote
Old 04-23-2005, 07:05 PM   #122
The Lavender Tie Just
Made It Obvious
Rafster's Avatar
Location: Bonita, CA (Hop, Skip, and a Jump from Tijuana, Mexico)
I know, that's the problem....
Peace,
Rafster
Post # 3000
Items for Sale
PM me!! Not using new Classifieds because I don't particularly like the way it works...
http://www.speedtest.net/result/133342788.png
Rafster is offline   Reply With Quote
Old 04-23-2005, 07:15 PM   #123
My Village Called
0l33l's Avatar
Peace,
Rafster
There's some nice ES300 installs
GammaControl v2.4
SKINbedder v3
Old 04-23-2005, 08:52 PM   #124
nobrdrntionsflg's Avatar
yo david, i can't get the sc300..for the time being anyways
nobrdrntionsflg is offline   Reply With Quote
Old 04-23-2005, 09:18 PM   #125
My Village Called
0l33l's Avatar
That's too bad. Atleast you'll have more driving experience with your parents.
GammaControl v2.4
SKINbedder v3
Old 04-24-2005, 09:55 AM   #126
PatrickB's Avatar
Like what?
i bet it needs a o2 sensor. a lot of times when they are failing the ecu doesn't realize its getting a bad reading it just thinks that the car is running a bit lean and dumps more fuel. also when u do that just do a tune up . spark plugs start fouling a lot quicker when fuel is dump all over them. i have had the problem with 2 cars and gained 10-15mpg each time i changed a o2 sensor and did a tune up.
PatrickB is offline   Reply With Quote
Old 04-24-2005, 02:03 PM   #127
My Village Called
0l33l's Avatar
That's partly what I was thinking. I've done a tune up right when I got the car. Just changed timing belt and water pump. Mechanic said that the spark plugs were fine
GammaControl v2.4
SKINbedder v3
Old 04-25-2005, 10:35 AM   #128
PatrickB's Avatar
i'd just change the o2 sesnor and see what happens
Old 04-26-2005, 01:40 AM   #129
My Village Called
0l33l's Avatar
True... atleast the car doesn't require a wideband o2
I'll figure out what kind I should put in when I get done with my AP tests (may 6th).
GammaControl v2.4
SKINbedder v3
Old 04-26-2005, 04:23 PM   #130
PatrickB's Avatar
i think you will get a big jump in gas mileage when u change it out. ps thanx for navi voice
Old 04-27-2005, 12:32 AM   #131
My Village Called
0l33l's Avatar
I hope that that's the problem. But I'm not getting a check engine light. Maybe its because I'm using OBDI I'm guessing that since I'm not getting that light then I'm not in an RPM-to-FUEL mode, which sucks up gas. I can't really smell that its running too rich though
GammaControl v2.4
SKINbedder v3
Old 04-27-2005, 11:25 AM   #132
PatrickB's Avatar
well it very well could be a failing o2 sensor. it would not throw a CEL if it was just on its way out it (reading but not well). It would just read little bit of a "lean" condition also the engine will pull some timing to keep from denation. also you may feel a small decrease in power. getting any blackness in the tail pipe? let the exhuast cool down, best to do early in the morning when its cool outside take a paper towel wipe the inside of the exhaust out till use the metal and see if its already black again in a few days (depending on how many miles u drive)
Old 04-27-2005, 10:49 PM   #133
My Village Called
0l33l's Avatar
Interesting. I'll drop by my mechanic to ask him what he thinks. I feel that the car needs some performance mods, but first I need to get it into the "stock" condition.
There's also been an update about the hit and run that I will post a bit later on
GammaControl v2.4
SKINbedder v3
Old 04-27-2005, 11:10 PM   #134
sheerdark's Avatar
Have you gotten an emissions inspection....ever? Because if you have, in my experience, that will catch a bad o2 sensor. Just a warning before you go throwing money into the car "pulling at straws" or whatever the saying is
I'm pretty sure they do emissions inspections in CA....I've heard horror stories about them.
2001 Isuzu Rodeo CarPC
sheerdark is offline   Reply With Quote
Old 04-27-2005, 11:11 PM   #135
My Village Called
0l33l's Avatar
The dealership says they got it smogged like 9 months ago. I've only put like 2k on the car. I don't drive much
GammaControl v2.4
SKINbedder v3
'95 Accord Carputer Project Gewehrschuss Show off your project 17 12-30-2005 08:51 PM
Project lexus ES300 with 300 or so pics mlazzaro@excite Fabrication 10 01-02-2005 08:48 PM
Lexus SC300 Carputer 1.0 bigmonkey70 Show off your project 10 04-06-2004 09:39 PM
