Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 12-30-2004, 01:29 AM   #46
ACleanSC4 is on a distinguished road
the xenarc screen should be easy to work with...don't worry about chopping away at the console trim...
after new years, i'll be redoing mine..making it smoother...too lazy to sand properly the last time i did it...
good luck on it! glad to see another SC with a carputer
Lexus SC400
Subaru WRX Wagon
ACleanSC4 is offline   Reply With Quote
Old 12-30-2004, 01:48 AM   #47
My Village Called
0l33l's Avatar
0l33l is on a distinguished road
The screen is as wide as the opening... right? Then how's it held in place. Me and my friend choppsed away like 2 of those top screws that hold the back together
I'm not chopping the console trim... one way to make it look stock
Yeh, when I'm done, I should be like the 5th SC owner with a carputer setup. But probably the 3rd who took the time to fabricate the screen into the dash and make it look stock
0l33l is offline   Reply With Quote
Old 12-30-2004, 02:25 AM   #48
i didn't chop the middle of the top of the trim...I shaved the sides a bit, used some plexiglass that I cut to fit the sides so it holds the xenarc faceplate into place...then just slap some bondo over everything.
you've seen my pictures right? i think it looks pretty stock, gotta redo it and sand the hell out of it and paint it black. Working on making it into carbon fiber to match my interior pieces but it's giving me some problems...
Lexus SC400
Subaru WRX Wagon
Old 12-30-2004, 02:42 AM   #49
My Village Called
0l33l's Avatar
Yeh, you took the other approach I'm still trying to keep that slight "gap" between the bezel and the monitor and climate control.
Good luck doing everything in CF
Old 12-30-2004, 02:56 AM   #50
My Village Called
0l33l's Avatar
Smile YaY!
According to this my car should have an AMP, so one less part to replace
Old 01-05-2005, 11:39 AM   #51
Katya's Avatar
Katya is on a distinguished road
The screen is a little wider than the opening. The screws hold the screen to the front frame. I got my Xenarc used without a front and 1 of the screw holes was chopped/sanded down, but the other 3 were OK. Without them, the screen will rattle around. I don't know if you'll be using the buttons or not, but the buttons on the newer Xenarcs extend a bit further down and need to be sanded down if you are using them w/ and older screen. I've got my Xenarc in without the back piece since there wasn't room to screw it back in once I bondoed the front frame into the dash.
Carputer Pics
Xenarc, custom case, M10000, 40 gig 2.5" hard drive, laptop DVD burner, Wi-fi, Bluetooth, GPS mouse, FP 1.09, M1-ATX
Look for me on the track, cause that's where you'll find me.
Katya is offline   Reply With Quote
Old 01-05-2005, 06:49 PM   #52
My Village Called
0l33l's Avatar
I'm not really fibreglassing the screen into the dash, just sanding it down. As you could see the stereo had small gaps between it and the climate control. I'm trying to keep those.
About the screws... I'm not chopping down the bottom ones. If worst comes to worst then I'm going to put a small U bracket between the front and back of the screen to hold it together.
Old 01-06-2005, 11:26 AM   #53
Tainted Love
Cris's Avatar
Cris is on a distinguished road
Little Timmy! Any new pics?
Cris is offline   Reply With Quote
Old 01-06-2005, 05:58 PM   #54
My Village Called
0l33l's Avatar
There won't be any new pics for a while. School is in so I'm gonna have to make my uncle finish this. Good thing mostly everything is done Plus, my unle was the one who painted the new (fixed) cupholder seen in the pics, and it does not scratch
Old 01-09-2005, 09:34 PM   #55
MySQL Error
Scouse Monkey's Avatar
Scouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud ofScouse Monkey has much to be proud of
didn't realise your car is what i know as a Lexus Soarer - they are bloomin huge - pretty good looking too.
I can't believe that steering lock you have!!!!! hehe that would last 10 seconds!
If you want more answers on anything I have posted you can find me at digital-car.co.uk
or skiing or diving or doing somthing else fun!
Scouse Monkey is offline   Reply With Quote
Old 01-09-2005, 09:44 PM   #56
My Village Called
0l33l's Avatar
Yep. I have a LFD soarer with almost no options (except black leather) I don't even have a power sunroof
The steering lock was in the pic because that pic was taken *the* day I got my car. The stock alarm was toast and I got a $450 clifford alarm (with fake carbon fibre ) to replace it.
BTW: Toyota never made a Lexus Soarer. Those are just kids rebadging their Toyota Soarers And yes, they are HUGE! My car is bigger than either my mom's sentra (02') or my grandma's sentra (98').
Old 01-09-2005, 10:08 PM   #57
Admin. Don't bug or I'll byte.
Bugbyte's Avatar
Bugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to beholdBugbyte is a splendid one to behold
I wish I had some pics of an open Xenarc case with the board already in it... would be good for figuring out how much space I have left.
Here's an 8" Xenarc that's open.
Want to:
-Find out about the iBug?
-Stop being a newbie? Take a look at the FAQ Emporium?
-Help me kill my car PC
-Watch live video streams from my mobile PC? Check it out here.
-Where is the iBug?
Bugbyte is offline   Reply With Quote
Old 01-09-2005, 10:11 PM   #58
My Village Called
0l33l's Avatar
Thanks! I think the 7" is about the same size proportionally.
Old 01-16-2005, 03:33 PM   #59
neuroplague's Avatar
neuroplague
How to stop the paint from scratching off.
Hi, I dont know if you got the paint problem solved yet, but I'll let you know where you went wrong in prepping plastic for paint. Peroxide will not clean anything other than a cut ... it will probably leave a residue behind that is preventing your paint from bonding. Wash the plastic with dish washing soap first to remove any oils or dirt, then wear gloves so you dont get your finger prints on it. Finally give it a wipe down with rubbing alcohol before you paint. This shold give you the best possible adhesion.
Hope this helps.
neuroplague is offline   Reply With Quote
Old 01-16-2005, 04:23 PM   #60
My Village Called
0l33l's Avatar
Hope this helps.
Thanks! I'll try that after finals
'95 Accord Carputer Project Gewehrschuss Show off your project 17 12-30-2005 09:51 PM
Project lexus ES300 with 300 or so pics mlazzaro@excite Fabrication 10 01-02-2005 09:48 PM
Lexus SC300 Carputer 1.0 bigmonkey70 Show off your project 10 04-06-2004 10:39 PM
