Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 05-31-2005, 02:04 AM   #1
c4shm0ney's Avatar
c4shm0ney is on a distinguished road
Chevy Metro supercharged with car computer intergration.
I'm posting pics of my progress today. I have the computer and custom enclosure mostly completed.
I will be doing the electrical including lighting and mounting the 10.4 inch tft touchscreen in the near future. More pictures to follow.
The enclosure is made of plywood and smoked acrylic. The large fan was taken from an older compaq server.
Completed box with acrylic top and front panel
This is a closeup through the smoked acrylic.
The acrylic paper is off with a dark wood stain
Total build time on the enclosure was about 3.5hrs
c4shm0ney is offline   Reply With Quote
Old 05-31-2005, 03:35 AM   #2
John_Duh's Avatar
John_Duh is on a distinguished road
any pics of the car it's going to be installed in ?
'02 Toyota Celica TS
Carputer progress : [#######---]
Currently working on : software ...
Parts : IBM thinkpad X60 wired up in the booth (T7200 - 1.5Gb Ram - 320GB HD)
Parts needed: USB wifi dongle (with external antenna)
John_Duh is offline   Reply With Quote
Old 05-31-2005, 05:44 AM   #3
c4shm0ney's Avatar
I'll post some later in the project. I'm sure everyone will laugh b/c it is a cheap car but I'm mostly happy with it for now.
Old 05-31-2005, 07:44 AM   #4
John_Duh's Avatar
being impatiant as i am i did some and came up with this :
Is that the one ?
Old 05-31-2005, 09:49 PM   #5
c4shm0ney's Avatar
Yeah that is the Metro, mine is silver however and I have way more bird**** on the hood.
"Metro, It'll get you there"
Old 06-01-2005, 03:17 PM   #6
PatrickB's Avatar
PatrickB is on a distinguished road
not that i care but i just find your car and user name so ironic :
PatrickB is offline   Reply With Quote
Old 06-01-2005, 03:40 PM   #7
Tainted Love
Cris's Avatar
Cris is on a distinguished road
I like that case.
Cris is offline   Reply With Quote
Old 06-01-2005, 10:14 PM   #8
c4shm0ney's Avatar
it's all cool, I'm just a southside balla on a budget.
Old 06-03-2005, 12:03 AM   #9
c4shm0ney's Avatar
almost done.
After 12 hours of wiring,cutting,painting,fusing,bleeding,cursing,dr illing,cursing,sweating,sanding,testing and installing the system is operational.
Remaining to be done.
ground pc chasis
install ATI TV card
jump audio from FM card and TV card to line-in on soundcard.
mount TFT bracket and install
create enclosure for GPS reciver,Linksys USB Wifi adapter and radar detector in rear view.
Troubleshoot custom keyboard extension cable.
wrap cables in conduit
Pictured below is my keyboard which I'm still working on it was designed for one of the early police car / computer intergration. It is illuminated with red leds. I had it sandblasted and powder coated a flat black. The cable is extended with 12 foot of CAT5e cable.
Pictured below is the switch panel. Made from folded aluminun cut to shape.
Installed, excuse my nappy floor board.
Installed.
Old 06-05-2005, 05:03 AM   #10
c4shm0ney's Avatar
I discovered the system is unstable during hot days like today. I'm currently working on a design to vent the trunk cavity which warmed up like an oven today. The system will involve a port hole from the trunk to the interior cabin with a high capacity DC fan and some tubing. I believe cooling the trunk interior will make the system more stable during the warmer months. I will be doing some testing with a wireless tempature probe tomorrow to gauge the temps in the trunk. I am interested in hearing how others have addressed this problem.
01 Metro LSI
79hp 41MPG Highway
Check my progress
http://www.mp3car.com/vbulletin/worklogs/51295-01-metro-lsi-4-door.html
Old 06-05-2005, 07:46 PM   #11
c4shm0ney's Avatar
I am reconsidering the system cooling idea as it has been stable today which is equally as warm as yesterday. The wireless tempeture probe shows the temp inside the case at a peak of 104.5 today with the system operating stable.
I completed a mount for the Datalux TFT today. The mounting bracket is made of steel with an aliminum tube connecting each wing of the bracket tied together with a piece of allthread and wingunts. The gooseneck is made of a 3/4" copper pipe a 1/2inch pipe mounting bracket and a 3/4inch 'pipe sealer' for lack of a better word to describe it. The goose neck is mounted into the left tap that holds the passenger seat with a locking nut/washer and about 2" of thread into the tap. I will be painting the mounting bracket and covering the copper with pipe insulation for astehtics and to manage the cables.
The mount as you might expect causes a bit of vibration on the display however I suspect there is little that I can do as the vibration is coming from the car/road and not because a design flaw.
The mount is very functional I can tilt the screen up-down left-right, push to be flush with console for passengers or push down to the floor.
01 Metro LSI
79hp 41MPG Highway
Check my progress
http://www.mp3car.com/vbulletin/showthread.php?t=51295
Old 06-05-2005, 10:07 PM   #12
c4shm0ney's Avatar
01 Metro LSI
79hp 41MPG Highway
Check my progress
Old 06-06-2005, 01:45 PM   #13
c4shm0ney's Avatar
Talking
I am dissapointed with my Datalux during the daytime. The glare is unbearable I would almost rate this unuseable in day light. I'm currently working to find a solution to the glare problem.
01 Metro LSI
79hp 41MPG Highway
Check my progress
Old 06-06-2005, 04:30 PM   #14
Tainted Love
Cris's Avatar
And so another one joins the LCD backlight upgrade mission...
Old 06-06-2005, 05:03 PM   #15
c4shm0ney's Avatar
Post
I am thinking about testing out a fine nylon mesh screen over the display from what I understand it should cancel out most of the glare.
I suspect that the mesh would make using the touch screen almost impossible however if it worked it would be a removeable overlay that would come off at night.
If all else fails I am seriously considering putting a higher power inverter and tubes up in this mofo.
ref: http://www.displaymate.com/glare.html
01 Metro LSI
79hp 41MPG Highway
Check my progress
Door handle i3igmind Car Audio 2 05-23-2005 02:19 AM
Garage door torsion spring MatrixPC Off Topic 4 02-11-2005 06:54 PM
01 Metro + laptop install = most getto carputer cash_Money Show off your project 9 12-09-2004 10:03 AM
AutoTap ODB-2 cable... coleman Engine Management, OBD-II, Engine Diagnostics, etc. 18 11-29-2004 12:13 AM
Replace door inserts? SuperMatty Off Topic 0 12-02-2002 12:54 AM
