Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 08-17-2005, 03:03 AM   #16
Raw Wave
lostreception's Avatar
rocky whn u hook it up again let me know how the viewing angle is from side to side after its flipped vertically specs say 50 degrees vertical viewing angle. and it says it has a 110vac power supply are you gonna be using an inverter im assuming?
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 08-28-2005, 01:16 AM   #17
yup, im going with an inverter (which i still have to order). I'm still in the process of mounting everything in..which i pretty much completed today. Also, i took pink insulation foam and put it around my computer case and i'm going to shape the foam, then fiberglass around it. Though, i should have everything up and running within the next 2 weeks, and i'll get back to you about the viewing angle and such then.
Sorry it took so long to reply, and it might take awhile before i can answer your question. I'm not moving as quickly as i would like to on this project due to work (and having a girlfriend..hahah)
Tomorrow i'll post some pics up if anyone is interested to show some of the progress i've made.
Rocky388 is offline   Reply With Quote
Old 11-12-2005, 03:19 AM   #18
..well that never happened
but heres some pics:
Case prepped and primed (1 coat)
Cover prepped and primed (1 coat)
side pieces prepped. These were made out of fiberglass, and will go on the sides of the screen to cover up the open space.
Old 11-12-2005, 03:27 AM   #19
Base prepped and primed (1 coat). The case gets bolted to the base, and the base gets bolted to the truck.
Base, diffrent angle
Trim piece prepped. This fits over the whole computer case.
Trim piece
Old 11-12-2005, 03:58 AM   #20
That's it for the fiberglass pieces. I didn't take pictures of anything after it was primed, or painted, but they are finished.
Heres some shots of the computer being tested..
You can't really see how the whole case came out. But just to give a general idea of everything:
Old 11-12-2005, 04:06 AM   #21
Some progress updates:
Whats finished:
Inverter mounted and wired
Fiberglass pieces painted
Computer assembled, and ready to go
LCD screen installed
What needs to be done:
Put computer in
Mount powersupply
Wire everything
Make braket for new headunit and DVD drive
Install headunit with DVD drive below it (into double DIN space)
Make bezel for H/U and DVD
What's next:
Overhead console with character display, that shows track titles and other various info. Also, a glasses holder (i usually put them on the arm rest/seat....and they end up getting sat on, or falling onto the floor)
1 10" sub with custom fiberglass enclosure. I'm going to take out 1 of the rear jumper seats, and put the sub there. I want the sub to take up no more space then what the jumper seat did folded up.
Old 11-12-2005, 04:14 AM   #22
I'm not too sure if you're even interested anymore, but I still haven't tested out the monitor vertically. I'm hoping that viewing angle isn't going to be a problem...especially after making the fiberglass pieces for the sides.
Old 11-16-2005, 09:36 PM   #23
Update:
I decided to re-make the piceces that go around the monitor. This time, i'm also making a screen bezel for it. I'm making the whole thing out of plexiglass. I didn't think it was such a pain in the the *** to cut... I'm not too sure if it's going to come out the way i'm hoping..but it should still look better than the fiberglass pieces i made.
Aside from using a sharp blade to score the plexiglass, and then breaking it, is there any way to get a nice clean, straight cut? I need to cut a 14" square into the plexiglass for the monitor bezel, but i want the cut to be real straight (obviously). My dremel skills are good, but not that great. Could i set up a piece of angle iron and use a fine blade jigsaw?
Old 11-16-2005, 10:11 PM   #24
seanshine's Avatar
Update:
Do you have a local plastic shop? I know the one close to where I live has a shop that will cut plexi in any shape you want.I'm not sure what tools they use to do it,but I've had 'em cut a few different peices on a few projects for me,and it's worth the cost.
Ripped it all out the Dodge....here we go again.
Planning 100%
Parts 90%
Install 0%
seanshine is offline   Reply With Quote
Old 11-17-2005, 11:12 AM   #25
blacklancer's Avatar
looks good so far. i think the screen turned sideways might be pretty cool when its all finished.
blacklancer is offline   Reply With Quote
Old 11-17-2005, 02:50 PM   #26
Thanks for the reply. I ended up just gluing it up the way i had it (without making the cut i was talking about in my previous post). And after letting is sit for around 15 hours, i took the clamps off and discovered that it's too flimsy to really work the way i want it.
Being that i'd rather not fiberglass again, i think im gunna make it out of sheet metal this weekend. I have the plexiglass pieces i can use as a template, and the metal will be hell of a lot stronger then plexiglass glued together.
Old 11-17-2005, 02:53 PM   #27
Thanks. I'm hoping it'll come out pretty good, even though some of the pieces didn't come out to plan. Though, this new piece that i'm going to make for the screen should clean it up and make it look alot nicer than what it does with the fiberglass side pieces. Once i finish it up, i'll post pictures comparing the two.
Old 11-24-2005, 02:33 AM   #28
Update:
I welded up a quick mount for the powersupply (the welds came out terrible, but it's plenty strong)
After glueing up one side of the plexiglass, and realising how flimsy it is, i decided to ditch the plexiglass idea. I decided to use aluminum instead. I plasma cut it roughly, grinded it, and filed it to fit. It still needs some minor filing, but i think it came out real nice. Plus it's a hell of a lot stronger than plexiglass.
With the results i got from that, i'm considering re-making the back fiberglass piece that goes around the computer out of aluminum (which i'm also not happy with - it's uneven and doesnt fit the way i would like). It'll put my welding skills to the test
I'll post some pics up tomorrow.
Old 11-24-2005, 04:39 PM   #29
Today i decided to just glue the plexiglass piece to the case lid (behind the flames)
Heres the finished computer (and my spyderfly ):
I'm pretty happy with the way it came out. Now i just might add a few lights behind there to show it off occasionally.
Old 12-31-2005, 12:05 AM   #30
It only took a month..but here's an update of the aluminum pieces.
The aluminum trim piece for the computer isn't completly finished yet, the front sides need to be welded on, but other then that fabrication is pretty much done for both the screen and computer piece. They came out alot better then the fiberglass pieces.
Heres some shots of the monitor enclosure:
Take 2 - '03 Audi A4
macmini with an 8" widescreen (in progress)
My 2004 Ford Ranger:
14" LCD w/ custom made aluminum bezel
Completly custom computer case
status: Totaled
2003 Ford Ranger FX4 Install (Lots of pics) tbird2340 Show off your project 85 10-23-2007 06:35 PM
Possibly FS: 2003 Ford Ranger FX4 - LOTS OF MODS! tbird2340 Classified Archive 3 07-05-2005 10:59 AM
1996 Ford Ranger - Suggestions on Sound Setup Mrbmw99 Car Audio 26 11-10-2004 01:47 PM
1996 Ford Ranger - Photoshopped Image of touchscreen Mrbmw99 Fabrication 15 11-03-2004 01:12 AM
1996 Ford Ranger w/M10000 & Xenarc parawing742 Show off your project 8 01-30-2004 06:37 PM
