The MP3car.com Store
Go Back   MP3Car.com > General > Show off your project > Worklogs
Thread Tools Display Modes
Old 11-11-2005, 04:08 AM   #1
Vehicle: Honda Goldwing
My Photos: (0)
01 Goldwing 1800 BikePC
ok work in progress
There are more images on my webserver
http://www.nigelf.dyndns.org/gallery
Due to the limitations of this site (max number of images = 15) i have moved to Digital-car.co.uk where no limitation seems to be made.
Nigel Fenton
Nigelfenton is offline   Reply With Quote
Sponsored Links
Old 12-16-2005, 04:08 AM   #2
My Photos: (0)
isnt the touch screen plastic and therefor water resistant ?
Old 12-16-2005, 07:39 AM   #3
My Photos: (0)
Its plastic, yes, but the seams in the casing aren't sealed. I think you're going to run into problems due to water unless you silicone it all shut. And then you may have overheating problems.
I love the idea though.
Also, why didn't you flush the screen in? Was there an unmovable structure underneath the bezel where you cut?
In the works...
Dell GX240 SFF
P4 1.8GHz, 256 RAM, 160GB HDD
8" Lilliput (fab work completed - F-150)
My worklog
Misc crap FS - OLD laptop (w/ adapters) | Sony memory | USB key | Printer Dock, etc
SMOKINV8 is offline   Reply With Quote
Old 12-16-2005, 09:52 AM   #4
My Photos: (0)
yes the small lcd has a pokey out bit and i dont have a replacement plastec for that! may be in mark II.
I intend to seal around the screen (front panel) with a small bead of silicon and sort of box the rear away from moisture with a small fan to keep things cool.
nigel
Old 12-16-2005, 10:00 AM   #5
Daley's Avatar
Vehicle: Caddy Seville
My Photos: (0)
Hmm, awesome idea, but I'm concerned about you losing the functionality of the original display. It contains things like speedometer and other indicators. I used to work at a Honda dealer, and absolutely *love* the new GL, and have even thought about the idea of a bikePC myself. I simply couln't come up with a good place for the display..
Best of luck, and keep us posted!!
To find your favorite restaurants in Houston, check out http://www.thehubgrub.com.
If it's not fun, you're not doing it right!
Daley is offline   Reply With Quote
Old 12-16-2005, 10:33 AM   #6
cheap custom title
JC-S60's CarPC Specs
JC-S60's Avatar
Vehicle: 01 Renault Espace BiFuel | Mitsubishi Canter | BMW R1200GS Adventure | Yamaha YZF600R | Honda CB650
My Photos: (0)
Marvelous idea!
Love it, really! Keep 'em pics a-comin' !
JC-S60 is offline   Reply With Quote
Old 12-16-2005, 11:10 AM   #7
My Photos: (0)
Here's a thought... what if you snipped a small piece of air filter material to attach to the grill area on the back of the case? That should let the air still flow through enough to cool it, while wicking the moisture out of the air.
In the works...
Dell GX240 SFF
My worklog
Sponsored Links
vB code is On
Trackbacks are Off
2001 Goldwing Bikepc :) Nigelfenton Show off your project 10 11-11-2005 04:10 AM
TT Sirius USB interface Pyrotek General Hardware Discussion 0 09-08-2005 08:15 AM
AutoTap ODB-2 cable... coleman Engine Management, OBD-II, Engine Diagnostics, etc. 18 11-28-2004 11:13 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
