Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 11-22-2005, 05:17 AM   #1
tja
tja is on a distinguished road
2005 Nissan Xtrail
22/11/2005
Have been working on this sporadically for some months now... have finally made enough progress to start a work log.
Bits n pieces:
Xenarc 700TSV
Opus PSU
DFI 855GME-MGF Pentium M Mobo
Pentium Celeron M 1.4Ghz
200Gb SATA
sony rm-x2s wired remote
The xtrail has a nice dash panel which covers the double din stereo, Air Con, vents and compartments which comes off nice and easily. Pulled this off leaving the internal bits floating around loose in the dash for a few months while I fabricated the bezel into it.
The screen bezel was attached to the dash with JB Weld... hopefully it wont crack!
Please note this is the first fabrication of this kind i have ever undertaken! Some pics:
Mounting Bezel in dash:
Filled and sanded the edges:
Final coat of paint after 3 layers of primer and 3 layers of top coat:
Close up of above:
Screen mounted:
Rear of dash piece:
Test Run:
In the last pic you can see the mobo and opus in the case, with the sata hdd sitting on top of the temporary 240V PSU. The plywood case (from ikea) might be replaced soon with a white acrylic custom case... depending on cost.. have been quoted AU$150
Update
28/11/2005
Have started making a clear perspex case. Materials are 3mm perspex (not much room under the passenger seat so the thinner the perspex the bettter), and Acrifix 192 glue.
It has been quite a challenge making the case, as I live in a 1br apartment without a garage, and my work bench is my coffee table, much to the dismay of my girlfriend. Tools are limited... the perspex was cut by scoring with a stanley knife, then snapping along the score line. this produced a straight enough "cut" to assemble a box out of. The glue is activated by fluorescent light, which I only found out after researching the product on the internet.. i couldnt work out why the glue wouldnt cure!
I am still to install two fans (one on either side of the case for cross-case air flow), and the lid is cut and just need to glue hinges to it. If i ever need to use the PCI slots i will dremel some holes into the case in the apropriate place.
The hdd is mounted horizontally, because there wasnt enough room to mount vertically... will see how it goes.. if it fails i will look into mounting it vertically. It is suspended on anti-vibration pnumatic pump feet which i found lying around at work. it seems to work ok so far!
Here are some photos:
3/4 view of case
HDD mounting method
close up of HDD mounts
close up of OPUS case ventilation
Update
05/01/2006 and 06/01/2006
Progress has been slow.. but to motivate myself i ripped out the original radio, and installed the dash/screen unit back in the car. So now i have no radio/cd, so hopefully ill get my arse into gear and install the rest of the hardware! Sorry about the dark photos. Will take some better daylight ones tomorrow.
Finally got around to installing all the power wiring for pc, xenarc and amp.
4G to distro block and then 8G x 2 for pc and amp.
Tapped into the accessory power for the original stereo for the remote line for opus and amp.
Ran fig 8 power wire from pc up to xenarc (powering xenarc from opus)
Ran usb and vga extension leads from PC up to xenarc.
(PC is going under front passenger seat.)
Photos in the morning hopefully after i get the pc in and do a first test run in the car! exciting. well for me anyway!
2005 Nissan Xtrail
DFI 855GME-MGF - Celeron M 1.4GHz - 256Mb RAM - 200Gb SATA HDD - OPUS 150w - Xenarc 700TSV
worklog
tja is offline   Reply With Quote
Old 11-22-2005, 05:25 AM   #2
Hellcat is on a distinguished road
Looks awesome! Good job.
Cant wait to see it in the car.
Hellcat is offline   Reply With Quote
Old 11-24-2005, 02:33 AM   #3
tja
cheers... i cant wait either!! this has been a long project.. well too long for the progress made ("ur spending too much money on that thing... ur spending too much time on that thing... spend time and money on ME" said the gf)...
yesterday i went down to bunnings and bought some clear acrylic, and some Acrifix 192 acrylic glue. cut up the pieces last night and have started gluing the box together tonight... it's a long process as the glue im using is cured by exposure to light! Fluorescent to be precise... so i had to go to kmart and buy a fluro lamp to get this glue curing! It still takes around an hour it seems to cure to a useable state.
the acrylic is only 3mm as i'm doing this on a tight budget and its cheaper than 6mm! Also it's all bunnings stock. but its pretty tough stuff and should be fine for this purpose.
Photos to come when its stuck together.
2005 Nissan Xtrail
worklog
Old 11-24-2005, 02:38 AM   #4
ArthrDent's Avatar
ArthrDent is on a distinguished road
Looks great! i love the clean fit of the lcd! Look forward to seeing more!
If only everthing in life would do what I WANTED it to, rather than what it was SUPPOSED to do.
ArthrDent is offline   Reply With Quote
Old 11-24-2005, 03:32 AM   #5
BIzFlawless's Avatar
BIzFlawless is on a distinguished road
Nice Dash!
BIzFlawless is offline   Reply With Quote
Old 11-28-2005, 06:20 AM   #6
tja
updated first post with photos of PC case and hdd mounts.
2005 Nissan Xtrail
worklog
Old 11-29-2005, 01:07 AM   #7
pip
pip's Avatar
pip is on a distinguished road
Might be me... but the hdd mounts only seem to dampen downward movement of the drive...upward movement of the drive is not dampened. I think you should put rubber/foam on both sides of the hdd bracket.
pip is offline   Reply With Quote
Old 11-29-2005, 03:25 AM   #8
tja
well the rubbers that the hdd is mounted on can compress (downwards pressure) as well as expand (upwards pressure)... hopefully taking up movement in both directions... rubbers also allow for sidewards movement for fast cornering..
its just an idea anyway, and its the parts that i had available to me!
2005 Nissan Xtrail
worklog
Old 11-29-2005, 03:41 AM   #9
Para Laura
thanatos106's Avatar
thanatos106 is on a distinguished road
Very nice... super clean dash pice!
Thanatos.
RexBruMet Skin for FrodoPlayer
Nissan Aux-in MOD
Quote: Originally Posted by bgoodman
We're an international forum, post in whatever langauge you like.
thanatos106 is offline   Reply With Quote
Old 01-06-2006, 07:32 AM   #10
tja
update first post
- installing screen in car
- installing wiring.
2005 Nissan Xtrail
worklog
Old 01-08-2006, 07:03 AM   #11
tja
well its all in, and mostly working! One thing i found out is that Hibernating doesn't like almost flat cmos batterys... mine keeps resetting the bios and then it wont come back out of hibernation, so until i get the battery replaced i have to shutdown fully, which is a shame, as i had startup to music playing (using s3 hibernation) less than 15 sec which for me is good as it takes me longer than that just to get out of the garage!
the only other problem thus far is that my on board sound is only outputting one channel. crappy realtek ac97. i guess i shouldnt complain, it is a second hand mobo. good excuse to get a creative external usb one though.
took the car for its first test drive with it all installed and it kept working. carpc survives cranking.
so all that is left now is to add a new soundcard, my sony rmx2s remote, usb gps, and maybe wifi...
2005 Nissan Xtrail
worklog
Old 01-11-2006, 03:08 AM   #12
tja
well after various problems with on board sound cards and lack of ACPI support for proper hibernation with the opus (even thought my motherboard supports it - stupid microsoft), my carputer finally works.. i *****ing love this thing!
2005 Nissan Xtrail
worklog
Old 03-03-2006, 01:36 PM   #13
BiGGy's Avatar
BiGGy is on a distinguished road
I like it, im going to use the hdd rail idea in my pc. I got a quote of $70 a sq meter for the 3mm stuff how much did you get it for? and how much of it did you get? My case will be smaller, prolly wont use more then 1 meter.
Did you glue the mobo face plate in or just quezzed it in?
Mitsubishi Magna VR-X - Whitsundays, Australia
Continued Worklog... Upgrades in progress:
*15.4" WXGA LED backlight touchscreen upgrade
*Custom fiberglass dash bezel
*768 X 1024 Narrow RR Skin
http://bigs.omfg.net.au/
BiGGy is offline   Reply With Quote
2005 Nissan Altima edrex Worklogs 80 03-22-2006 10:56 PM
2005 Nissan X-Trail SE ecrase2500 Worklogs 4 10-16-2005 07:47 PM
Where to DL old version of RR? accentsound Road Runner 14 07-12-2005 01:51 AM
2005 Nissan Cefiro Piperclub Show off your project 12 06-08-2005 06:05 PM
Nissan Xtrail 2005 Xputer project finished !! p4intel Show off your project 10 05-27-2005 02:06 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
