Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 12-31-2005, 09:58 AM   #1
lft4ded is on a distinguished road
Cool 2001 S-10 Laptop Pics (19 of them)
When I bought my truck (Desert Moon) back in 2000 I created a list of upgrades that I wanted to perform after 3 months of living with it. I actually, really do, like the factory stereo. It's awesome but I wanted a disk changer and put a 12 disk JVC changer on the list.
When I finally got around to it however I had come across a Wal-Mart 10-disc Xtreme disc changer (Moon has the Xtreme body package, reg cab, V6, 5 speed, stepside bed and he's black with silver stripes and a charcoal interior) so I had to have it. I mounted it behind the center console.
One fine spring day I left his rear slider open and took a nap to awake to a heavy spring shower. Gone - one disk changer. A year later I purchased a refurbished JVC 12 disc changer and mounted it in the center console, that only lasted 5 months. So we went the next 2 years without a disc changer eventually buying the an adapter from Crutchfield and connecting my XLive XMB mp3 player, but it has a puny memory capacity, and I needed more.
Enter 2 month's ago when I decided to put a computer in and this was one of the first sites I came to. After some reading and looking around I decided to go with a laptop install for two reasons: 1 - I live in an apartment so no garage to wire for a LAN; 2 - Self contained so no need to buy an additional card for my pc for wireless comm. Besides, I also have a 20 gb portable.
I bought a Compaq Armada e500 off eBay: PIII 600 MHz, 512 Mb ram, 12 Gb HDD, DVD-ROM. It only has a single USB 1.1 port so I bought a 2 port USB 2.0pcmcia card for it. Display duties are handled by the ubiquitous TM-868 (came with both AC & DC adapters). I also purchased a mini-USB 1.1 hub, a floppy keyboard (with the huge @ss capslock key ), a DBT-120 bluetooth antenna, an iGo Juice power adapter (for the 90 degree power connection), and the docking station for the laptop.
I have passengers leaning over to see the regular stereo because of how far it angles in towards the driver, and because I like the stock stereo (not to mention any unplanned downtime from the laptop) I bought an Omnimount AB1 (though in retrospect the Universal kit may have been better, it didn't come in silver) mount. I Gorilla Glue'd the long leg of a disc changer 'L' mounting bracket to the top of the HU with the short leg near the front, mounted the Omnimount to it and the cut a just-the-right-size hole in the HU's top bezel for it. The other reason is that when I take my friend along with me on trips she likes to play games, surf the net, watch movies, and it makes it a 'her' activity while I stay driving.
I initially wanted to mount the laptop on its side (so the DVD tray extends towards the center of the Moon, and all the connectors point towards the passenger wall) behind the passenger seat until I realized that some work (welding) would have to go into relocating the jack. Then I bought one of those seat organizers used it as a sling for the laptop, placing it with the front facing downward and the top to the back of the passenger seat. This wasn't really okay, and was temporary because it was a pain to change disks. Besides, removing the laptop and putting it back in became an exercise in agility, taking a couple of minutes. The two things I did learn is that both it and the display would survive crank and could be left unattended for at least 5 hours connected without touching the battery really; and I would need the port replicator/docking station.
I should point out that the cigarette light and both auxillary plugs are always powered.
I had been thinking about replacing his center console for a while because the 5-speed consoles have two useless cupholders. Unfortunately the first 6scrap parts yard I came across didn't want/have the center console from an automatic so I could splice it in, and the C/K center consoles were to large, so I decided to remove it completely and replace it with a custom (kind of)one. Easier access for me and the passenger.
I drove around for the better part of the day without the center console and noticed how much better shifting felt without it so I knew that I would never go back to one that consumed so much space.
I relocated the buckets from the center console to the back wall of the cab between the two seats where they used to be with JVC changer. I bought a three tier rubbermaid container where the top tray hinged upward and lightly wedged it between the shifter and the underdash where the tray on the front of the center console is. I had to remove the bottom two drawers, leaving one and the top container. Just the right height! I have to slide it out to access the drawer but I only store the iGo's additional bits that I never use along with a few wire ties. Behind the shifter I placed a cheap 'center console' with two cupholders, a cd holder block, change drops, and two additional compartments. The side by side cupholders allow me to shift without '4th gear knock'. Next came the mount for the laptop.
Because the docking station has a built-in incline on the bottom I had to hacksaw/boxcut-ter it flat (wish I had a Dremel saw). The back of the docking station also has a slight incline but as I intended to connect everything to it I needed a surface a few inches off the floor of the Moon that would cancel the incline. I used a small file box because of the slight incline. (I'll have to take pictures of just this. Because of its location I could use a wire tie to loop through the security chain loop and around the passenger seatbelt. I used heavy duty velcro to keep the bottom of the docking station from sliding around. I also purchased a 4.5 inch wide file holder from Office Depot. It was $20 but just the right size so I used that (velcro'ed too), on its back, to fill the gap between the top of the docking station and the driver's seat. There's enough room in front of the document holder to place the mini hub. One of the compartments on the center console is large enough to hold a 1->3 12 volt outlet adapter which is beside the driver's seat which I plug the monitor and the iGo into. the rest of the cables I hid in wire covers or beneath the file box cutout.
The only issue I have now is that I have to unplug the docking station else it doesn't survive crank. It took a second to figure out what was going on all of a sudden. Before I got the specific problem down pat I had the hub connected to the docking station and connected the display to the hub but changed it to leaving the hub unplugged until I need it (then I plug it into the pcmcia card) and plug the display's TS controller into the docking station, which is more permanent.
I still need to cover the bottom of the docking station and sand the edges a little. The document holder keeps the rear facing side of the laptop from flapping around and I have a small piece of regular black velcro doing the same on the front now (post pics). Otherwise its just a slow process of adding things on over time - upgrade laptop, gps antenna and software, blah, and so on. Pics are the next post down.
lft4ded is offline   Reply With Quote
Advertisement Sponsored links
Old 12-31-2005, 10:05 AM   #2
Pics, as promised.
FrodoPlayer - awesome front-end! Painted vents.
Screen saver replaces the primary function of the stereo.
Microphone though I'm going to replace it with a noise canceling one. And I need to tape the wire out of the way. I also need to place the screws back in the dash.
More room to shift, new center console, 3 hole power adapter beside driver seat and painted bezel for ash tray. Those wires on the driver's side are in black wire wrap now and all Duck Tape is gone.
Laptop in place on docking station, microphone isn't replicated on the docking station, USB 2.0 card, and you can see the black file hold on its back.
More next post...
Old 12-31-2005, 10:13 AM   #3
Pics part 2
Another pic of the laptop, file holder, power adapter and you can see the top of the hub.
Top of the hub, power adapter, bluetooth antenna. I keep the cable folded beside the hub until I need it. There is a rubber plug in the un-used plug hole, the black plug is for the TM-868 and the silver one is for the iGo going into the port replicator.
Similar shot from the passenger view. Now there is a small velcro strap from this side near the front to the top of the close laptop keeping it in place. Wire tie between the security loop and passenger seat belt. Ugly isn't it? Need to cover it.
Keepboard velcro'ed to visor. Need to either give it a hard backing of figure easy way of removing visor to hand to passenger to make sure keyboard has a backing. Or get a different keyboard.
Ugh, desktop text is bad. Need to fix that.
More to come...
Old 12-31-2005, 10:17 AM   #4
Almost finished...
Requisite shot of the site. Cell phone that makes this all possible. Ah, the last pic was of me connecting to internet.
Monitor swivelled towards passenger, leaving me to drive in solitude.
Blurry, but you can see the Rubbermaid container in front of shifter.
What the passenger normally sees...
The original sling, now housing two Sidewinder Pros and my backup AC adapter.
Last pics next.
Old 12-31-2005, 10:19 AM   #5
Finit
Where would we be without MAME or SNEX...
There...
Old 12-31-2005, 10:50 AM   #6
racerx3165's Avatar
racerx3165 is on a distinguished road
Pretty cool install! so how is the reliability of the system? Any problems?
Cars
1994 Mustang GT Punch 240.4 2 12" Kicker Comp
2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
2003 Eddie Bauer Expedition DVD - Navigation Package Untouchable says the wife
Car PC
[x---------] Dash Is Off and Dreams are Floating
racerx3165 is offline   Reply With Quote
Old 12-31-2005, 12:30 PM   #7
skadoo323 is on a distinguished road
how is the LCD mounted? is it using a bracket? thanks!
skadoo323 is offline   Reply With Quote
Old 01-01-2006, 06:09 AM   #8
He appreciates the compliment. Again, with the exception of needing to unplug the power to the docking station when I crank, everything works great.
And yeah, I used an Omnimount speaker arm (the one rated for 2.5 lbs.) to hold the monitor up. I'll try to take a better picture of it later today...
Old 01-05-2006, 03:13 PM   #9
xs10x's Avatar
xs10x is an unknown quantity at this point
I'm waiting for some funds to buy my TS and inverter. Then you will have another s-10 Xtreme with a carputer. Would be cool to schedule a Car PC meet.
`¨`¨`¨`¨` _____||¯.\__
.:.:.:.:.:.:;!_(o)______(o)'i
TruckputerX - Vortech SuperCharger Vid
TruckputerX Progress Bar [|||||||||-] 90% Complete [It's never 100% done]
xs10x is offline   Reply With Quote
Old 06-06-2006, 11:09 AM   #10
breaker021's Avatar
breaker021 will become famous soon enough
Dude, awesome setup man! I am using a tablet in mine and love it! You gotta be diggin' your setup... your screen also rocks!
- sh00k
Duct tape and a Bandana for the win, b!shes!!!
My Setup:http://www.mp3car.com/vbulletin/show-off-your-project/73500-06-scion-xb-tablet-box.html
Cost so far: Less than a grand ;]
_________________
Economy/Commuter cars + Computers = many entertained miles
breaker021 is offline   Reply With Quote
Old 06-07-2006, 11:29 AM   #11
double-0-newb's Avatar
double-0-newb is on a distinguished road
I would really like to see a shot of the omnimount bracket, as well as get your opinion on it.
I believe it was this one, correct?
http://www.omnimount.com/consumer/pr...?p=33&mp=4.1.3
Also, where did you get the monitor from? I found the same one here
http://www.mp3playerstore.com/stuff_...ial/TM-868.htm
Freakin' company is a 10 minute drive from me here in Montreal, but I have to pay in US$. Grrrrrrrrr!
Thanks in advance.
1998 Volvo V70 "Volputer"
Worklog: planning and procurement.
http://www.mp3car.com/vbulletin/worklogs/75505-1998-volvo-v70-now-libretto-100ct.html
double-0-newb is offline   Reply With Quote
Old 06-08-2006, 08:36 AM   #12
Un_discovered is on a distinguished road
If yo'ure having to disconnect your DC-DC adapter when you crank, an idea would be to put a NC (normally closed) single pole push button switch in an easy to access spot, and just hold it while you crank, then let go, and all is done.
Un_discovered is offline   Reply With Quote
Laptop for carputer project airborne_cookie Newbie 13 05-31-2005 11:23 AM
My idea for a Laptop Switch for my MKIV Jetta. Can this work?!? Man Ace Power Supplies 47 05-03-2005 01:28 PM
Put laptop drive in dash? eblend General Hardware Discussion 2 04-30-2005 03:55 PM
Shutdown/Startup Controller for laptop JoyRidun General Hardware Discussion 24 07-01-2004 07:08 PM
laptop sound cards etc distortion General Hardware Discussion 1 06-27-2004 02:33 AM
