Well today, my car kicked my ***. Spent another 250 today on wiring. When did cables get such a high markup??? anyhow. the price of wires is not what kicked my ***. I had my brother to help me today, hes off on vacation and was good enough to start while i was still in work. when I got off I went over to his place and started giving him a hand.
This car fights dirty and fought us all the way. First obsticle was running the amp wire. youd think getting thru the firewall would be easy. just pick a gromlet and go thru it. nope. the engine is set kinda into the damn car with really no way to get your hand or anything to the gromlet. so after about an hour and a half and a tore up arm squeezing it into places it wasnt meant to be, I got the power wire ran thru the damn firewall.
That dash was a pain in tha *** to pull apart. it seems like every panel needs to be pulled off just to remove the ones i wanted. figures.
My fiberglass interfered with the mounting of the heater/air controls. so it had to be cut down and shaved some.
now since theres no factory harness from metra yet. (yes i know theres a number for one metra 70-1722, which you cant get for another month. I called metra, and went to different places that sell metra harnesses. there answer was come back in 2 or 3 weeks and check back.) So I said the hell with it, i only need the ignition, power, ground and speakers. so i take a look at a diagram cut the proper wires leaving room to splice back into the harness later if i ever have too. So i said ok lets make sure which speaker this is. usuing a battery i jumped the wires. which makes a thud to the corresponding speaker. no thud. damn damn dman dman damn. so the only reason i know of for that trick not to work. theres an amp inline. dammit! Ive looked and looked and looked and havent been able to find any info saying there was an amp, If there is one, I think it has to be in the center counsil. but im not sure.
Anyhow so i called it quits for the day. time to search for some documentation on what wires pin out to what, maybe ill find a diagram for the amp too. ok so i know im dreaming. but heres a few pics i snapped today, also this is what it looks like when you take a brand new car and rip it apart for ****s and giggles.
