Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 07-06-2006, 05:21 PM   #46
Tercel96 is on a distinguished road
Wow, good stuff, I got some quick questions though: can you mention some more details about the Amp? So there is one after the output from the OEM head unit? Where is it located physically, in the dash somewhere?
Also, about getting through the firewall, where did you end up putting the cable?
I currently got an SI on order and I like what you've done with the thing... any plans on making the steering wheel volume controls work in the PC? If so let me know how that goes, as well as ironing out all your issues... Keep us posted!
Tercel96 is offline   Reply With Quote
Old 07-06-2006, 05:51 PM   #47
yrean's Avatar
yrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to allyrean is a name known to all
thanks man.
Yes on the SI. there is an amp besides the factory radio. its in the center console. by the floor in front of the shifter. The SRS controller box is there also. I believe the amp sits on top. of it. basically stay away from any wires in your car that are wrapped with yellow tape. Yellow means Airbag. I guess that i could of used line level in to the factory amp, but i wasnt sure if i could use the amp or not so i went with the 5 channel amp. To get the wiring diagram youll have to go to honda service dept and have them pull the schematic up for you. ill see if i still have the diagram but im not sure where i put them when i was done. and the diagram wasnt under the radio schematics. there was a seperate section for amplifier/sound i beleive. it took like an hour for them to find what i was looking for.
as for the wiring thru the firewall.
If you look where the wire goes under the 2 airconditioning lines. there are two rubber gromlets in the firewall there. its a tight fit to get your hand in there or anything else for that matter. in your dash in the car theres a huge air filter for the ventalation system on the passenger side. the gromlets are behind there. which is also a tight fit. I had to go from the inside of the car and then fit my hand in the engine compartment to be able to find the wire. I wasnt able to do it any other way. and i literally fought with the damn thing for a couple hours. there is no real easy way since the engine practically sits half under the dash.
The steering wheel controls are in the works. I had a few things come up that needed cash so i postponed finishing a few of the little things. the only 2 things I didnt finish was the steering wheel control, and the obdII conector.
I have to still remount the gps reciever, I found it doesnt grab a signal in the dash, it has to see the sky, and I have a u132 pcmcia to usb adapter that i still need to mount for my verizon card.
but really other then that Most of my bugs are worked out all ready. now all ive been doing lately is tweaking the software to get better load times, and making sure i get everything working 100%.
Then again, once you start this project your never trully 100% done. If youd like to know anythng else let me know.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
yrean is offline   Reply With Quote
Old 07-06-2006, 10:11 PM   #48
portabuddy's Avatar
portabuddy is on a distinguished road
nice progress looks great so far. hows the angle of the screen for viewing? is it dim when your sitting in the drivers seat or not? also can the passanger see the screen? and can you please post the pinouts as i also may need them... thank you very much.
Life Dosn't come with a reset button, if it did you might as well turn the game off.
portabuddy is offline   Reply With Quote
Old 07-07-2006, 03:04 PM   #49
yrean's Avatar
I found where i stashed it at, but i wasnt able to scan it in. my scanner got an attitude and i kinda tossed it out a window. besides the point. anyhow. i drew the diagram real quick. forgive the sloppiness i wasnt going for an art award. this is for the wiring of the amp itself thats hidden in the center counsel.
remember you cant amplify an amplifed signal so you need to bypass the factory amp unless you plan on using it.
heres a nice write up i found on taking the dash apart, and the harness up top at the radio..http://www.8thcivic.com/forums/showthread.php?t=3534
one last thing. if your going to add a radio of some sort. you need an antenna adapter. the extra wire hooks up to accessory turn on.
http://www.crutchfield.com/S-r04odOg...&display=L#Tab
My Worklog
Old 07-07-2006, 03:08 PM   #50
yrean's Avatar
yes the passenger can see my screen just fine. its better at night but you can still see it during the day, i can see pretty much good in the drivers seat. it looks like im tilted up about 2-4 degrees too much, but everything is very visable.
My Worklog
Old 07-12-2006, 04:29 PM   #51
portabuddy's Avatar
im glad that you found the diagram, i found out that my dealer is filled with incomptent morons. btw, i think that im going to buy another peice. the trim part that goes right below the spedo, the one that has a criss-cross pattern on it and bows around. it only costs $25 cnd.
i think that I'll buy it and get that painted as well just so the dash ties in a bit more. what do you think?
Old 07-12-2006, 08:30 PM   #52
yrean's Avatar
yeah im not saying the guys at my dealership were really all that competant. It did take them 4 phone calls and then when i went up there, it took them another 2 hours to actually find what i was looking for. and i couldnt find that on the interent. oh wells. hopefully it will help other people out.
i know the piece your talking about. i think that would look good. not sure until ya do it lol.. if you dont like it you can always change back to the original. :P I cant wait to see some updated pics of yours.
My Worklog
Old 07-13-2006, 01:05 AM   #53
portabuddy's Avatar
i've been working on it the last two days on and off on the count of not having a job.
you know what im ordering it right away. and im going to try to use the factory amp for the front and back speakers... minus the ****ty crackly sub
Old 10-18-2008, 02:20 AM   #54
portabuddy's Avatar
dude, still have those pinouts?
PROJECT ST34LTH : Project Car Purchased w/PICS ST34LTH General Hardware Discussion 69 09-01-2008 10:09 AM
2003 civic si. $40 000+ project completed kumanan Show off your project 198 07-03-2008 03:19 PM
A Start Community Project BenjaminS MacCar 9 03-25-2005 06:46 PM
Carputer as a comp sci final year project? MikeHunt79 General MP3Car Discussion 5 06-23-2004 10:19 AM
RLion Project Webpage Reactor General MP3Car Discussion 0 02-18-2004 06:43 AM
