Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 05-16-2006, 04:46 PM   #16
cliffloehr's Avatar
cliffloehr is on a distinguished road
Quote: Originally Posted by tj!2k4
inside of the trunk lid
Yes the 01' is the same, you bring up an excellent point, and I should start inside the trunk and move to the spoiler if I have any reception problems. No since making more work or myself.
cliffloehr is offline   Reply With Quote
Old 05-16-2006, 04:49 PM   #17
cliffloehr's Avatar
Quote: Originally Posted by Red GTi VR6
fab works looks to be good, at least from the shots provided!congrats!
I went out of my way to hide imperfections from the camera!
Red, your work is insanely impressive - Hat's off to you!
Old 05-17-2006, 09:31 AM   #18
cliffloehr's Avatar
This is a bracket to hold the Computer in place. It was welded together then welded into the car to wrap around the AC controls. The top rail is the original rail and welded back into the same location... (maybe I was too gun-ho in the demolition phase).
Because the Car Computer is the same size as the original radio, I was able to use the original mounting hardware.
Old 05-17-2006, 09:37 AM   #19
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
very nice!
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 05-17-2006, 09:37 AM   #20
cliffloehr's Avatar
So Far...
Hear is the (assembled) PC setting on the bracket... it is very stable and easily slides in and out (Like the original radio)
NOTE:
A fan is mounted top/center on the case and draws air in from both sides of the DVD drive (under the motherboard) There is an 1/8 gap all the way around the motherboard allowing fresh air rise through the case, over all the components, and out the top. The car's air duct (above the case) is angled perfectly to deflect the air, exiting the computer, to blow on the back of the LCD screen.
Old 05-17-2006, 09:44 AM   #21
cliffloehr's Avatar
You can make more room for the extra wires coming out the back of the PC by:
  1. Cut the two plastic anchors
  2. Remove the bracket (on the left side) and reinstall it, in front of the wire harness.
This gave me more then an inch of more space behind the PC.
Old 05-17-2006, 03:18 PM   #22
pyros's Avatar
pyros is on a distinguished road
Looking good.. can't wait to see that finished. I like the relocated defrost/fog/traction buttons and a/c.
You mounted your case (along with the fan) the same way I did... turned out great for me. Good luck
2004 Ford Mustang Mach 1
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 05-17-2006, 03:53 PM   #23
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
Great tip!
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 05-18-2006, 03:40 AM   #24
cliffloehr's Avatar
The Screen
The screen came in today. It's an 8" 16:9 touchscreen (Provision PRTV805VT) off ebay The screen is thinner then most of the 7" screens and and has no odd shaped edges... all straight and square making it much easier to install. However... I made the stupid hole in the bezel too small and have to rework the whole thing. I also made the PC sit up too high and need to rework the mounting bracket.
Anyway, the screen is such a good fit and the extra inch makes a big difference! I'm SURE their will be more of you switching to this screen!!!
LESSON LEARNED:
Don't customize the bezel until ALL the components come in!
WARNING:
#1 While the screen is awesome! It is not with out some quirks! The VGA cable will not reach the back of the PC... and it is the wrong sex to plug directly into the computer anyway! It comes with a 6' extension, but I only need another 3 inches... (but thats another story)
#2 The screen had a bad connection (the red pin was not firing) after moving some wires around, I found the bad spot... it was inside the screen!
Since the connection was bad and the VGA cable needed a sex change operation anyway... I voided my warranty and copped it off!
#3 Two of the connectors (power and VGA) plug into jacks (inside the screen) that are the wrong size!!! The VGA uses 6 wires and has a 6 pin connector... but plugs into an 8 pin jack mounted on the main board! The power jack is the same way. I thought I'd never get the thing working again!
I finally did get it in the car for a silent run (no sound - just power) all is good (The screen fits and looks SO nice... I'll post some photos tomorrow.
Old 05-18-2006, 08:17 PM   #25
racerx3165's Avatar
racerx3165 is on a distinguished road
I've been planning my CarPC for about 2 months and have already purchased all the hardware. Speciman inspired the design approach with his 94 Mustang. I'm in the process fabricating the case and hacking up my dashboard right now and thought it would be good to start a work log. The plan is to place the entire PC inside he dash where the radio was.
Hahahaha and i still havent got mine done I need to get busy and find some money. Anyone have a money tree lying arond i can buy? Looks great man im hoping this will get me back at it...
Cars
1994 Mustang GT Punch 240.4 2 12" Kicker Comp
2006 Suzuki Aerio Sx Kicker KX 650.4 RE 10
2003 Eddie Bauer Expedition DVD - Navigation Package Untouchable says the wife
Car PC
[x---------] Dash Is Off and Dreams are Floating
racerx3165 is offline   Reply With Quote
Old 05-18-2006, 09:52 PM   #26
Raw Wave
tj!2k4's Avatar
When I saw the opening for the bezel's opening for the screen, I suspected that you were going with an 8", so I checked out the link to the screen you posted.
One of the things that would be of concern with that screen is the brightness of only 125 cd/m², especially when compared to the Xenarc's display brightness (w/ Touchscreen) of ~300 cd/m². From my experience in the coupe, the Xenarc leaves much to be desired in the way of visibility in the sunlight.
I realize that you are recessing the screen as far as possible, but even so
I'd be very much concerned about how that particular 8" will pan out in a vert..
Edit: Interesting.. the first link you provided to the amamax.com site shows the brightness as 125
cd/m².. the eBay link shows the brightness as 350 cd/m2.. which is it now..? lol
Old 05-18-2006, 11:56 PM   #27
cliffloehr's Avatar
The manufacturer's website said brightness=350 and contrast=350 so I was not worried. After receiving the unit, the manual also agrees... Also, I was driving around today and it is fine. Of course on a sunny day, with the top down, any screen would wash out. In addition to recessing it in as far as I can, I was thinking of mounting it so it can tilt up-n-down.
With the top down, it reflects whatever is directly behind me.
After rebuilding the VGA connector inside the screen, I've been having some flickering problems today. So this evening I've been in-n-out of the screen several times trying to improve the connections... at the moment it won't get power at all. I'm so freaking mad about those stinking connectors being the wrong size! Why would a company do that in a "moble device"?!?
I've been pushing myself to finish. Actually I've had the VIA M10000 for over two years! I gave up on trying to build a MythTV (Tivo thingy) I've decided I am NOT a Linux man! So I eBay'ed most of the parts to convert the project to a car PC... I'm glad I did. if I can ever get the screen to work!
Old 05-19-2006, 10:52 PM   #28
racerx3165's Avatar
Well i got the power wire ran in my Suzuki and most of my time has been spent on that car but i still plan on doing the Mustang PC for sure...
Cars
Car PC
Old 05-20-2006, 03:40 PM   #29
cliffloehr's Avatar
After trying to fit it all together, I've determined the gap between the A/C controls and the DVD needs to be smaller. So I'll be redoing the mounting bracket when I return home.
Old 05-23-2006, 10:59 AM   #30
Willy-Mach1's Avatar
Willy-Mach1 is on a distinguished road
Nice Job..... It's looking great!!!!
It's soooo nice to see more Stangs around here!
CHEERS!!!
Willy
Progress: |##########| 99.99%
- Tweaking and enjoying!!!! Never really done.....
-= MachPuter Project =-
-= MachPuter Project Worklog=-
Willy-Mach1 is offline   Reply With Quote
1987 Mustang GT Convertible MP3 Mustang jzgt Worklogs 27 10-26-2007 09:18 PM
Front end with Autoroute 2001 Davefocus Software & Software Development 3 06-26-2005 06:01 AM
FS: '93 Mustang GT Immaculate!!! **MUST SEE** Loco Classified Archive 2 06-16-2005 10:22 AM
WTB/FS: Alot of things. Mustang parts/Computer SilverGT Classified Archive 10 03-15-2005 12:38 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
