Alright, redid everything, so...Here we go.
The computer, a glove box. I carpeted it because I DID have fans in the face, but they just sucked, so Instead of fiberglassing over them, I just carpeted it. It works.
And Here it is open. I know, lots of cables everywhere, working on a case...
The monitor. I did fabricate that. And I also put in a USB port and an LED for the HDD, but Ive changed things so the LED light no longer works, Ill remove it eventually. And I threw in a thermomiter so I can see how hot the glove box is getting. I cut some holes into the AC vents, so It doesnt get too hot.
My HU, I didnt build that for the HU, I purchased that from a member here. Its awsome....THANKS AGAIN!
When the HU is open, It does slightly interfere with the E brake, but not too bad, I just lift up the E brake a bit, then put it back, I lift it so little that the brakes dont even engage.
The power buttons. I just made the big one a few days ago, still sanding and I need a coat of clear coat on it. But thats the master kill switch. The small button on the right turns the puter on and off.
The dvd player is in the arm rest.
The amp box all cleaned up. Fans are connected to the master kill switch.
and I just finished the External HDD mount. Its not quite done, its still a bit flimsy, and the fans are not very powerful, we'll see if they are strong enough to cool it down a bit. And, I still need to clear coat it as well.
So, comments, suggestions? Im STILL not done, have another 10" sub to put in, and strengthen that external HDD mount. but overall, just about done. Also have a wireless adapter and GPS to put in. But Im happy with it so far.
