I decided not to hack up my dash. I might eventually sell the car and I don't want to have to sell my car pc with it. So, I created a mount for the Lilli. It looks pretty good considering. I have pictures below. BTW, the box doesn't fix under my seat. After I built it I knew there was no chance. Right now I'm thinking of alternate mounting locations. The best one that comes to mind is in the back. There is a 12v accessory outlet there so thats some of the wiring already done. I just have to check the fuse in the fuse box to make sure it can take 15 amps. It should be no problem though. It will be a pain wiring the constant 12v, video, USB, and sound. . . . I think I'm just going to get some CAT 5 and wire it with that. Except for the constant 12v that is. I have some 8 guage for the 12V constant.
You can see the wood I used to make the mount in one of the pictures. It's barely visible. If it bothers me, I'll add some ridged rubber to seal off the area.
I decided to put the old LED screen on the floor infront of the center console .
Also, I ordered a wireless card for file sharing. It should be here tomorrow.
What do you guys think so far?
Any suggestions for the location of the computer?
You can barely see the wood in the picture below.
Now if I only knew where to put the computer.
