10-25-2007, 05:49 PM
#16
The box in the back is just held down by gravity, there's a lot of equipment in there .. although if you wanted you could remove the four tie down hooks in the floor of your blazer and secure it that way [be careful though b/c i think those are "special" bolts, i took mine out at one point and i cant remember if they were or not ]
as for getting it snug w/ the interior i started w/ a large piece of cardboard, cut it so it fit just right, then took a little extra off [adding carpet adds to the size] used that as a template for my wood piece, and there it is .. sits real nice, mine also supports a ton of stuff in the back [moved back and forth to college 3 times w/ it, and trust me i had some heavy equipment]
--pictures coming--
Carputer Status:MobileOne: retired - via - Gentoo Linux, gps drive, nGhost, tethered e815
MobileTwo: retired - via - Ubuntu Linux, gps drive, nGhost
MobileThree: development - Intel Atom - Gentoo Linux, iGuidance3, navIT, nGhost2 -- worklog--
10-27-2007, 01:49 AM
#17
I was still kind of curious where you routed your power wire, and other various wires. I am getting ready to tackle the wiring as soon as I get my monitor back from DigitalWW (taking FOREVER) and I was kind of stumped as to where I should route my 4 gauge wiring. I also wondered if you had any issues with any pinching, rubbing, or excessive wear on your cabling where you have routed it.
I was also wondering where you brought your power cable into your false floor/box, and did you modify any interior panels in the process.
can't wait to see the pictures of your install as well, ESPECIALLY your 10.4" LCD ...WOW man...WOW
So Far: MII10k Mobo, 1GB Corsair PC3200, 100GB Hitachi HD,M2-ATX PS, Ampie Case, XMD1000, Panasonic CD-RW DVD-ROM. Orinoco Gold, Lilliput 629, WiFi, TV/FM, Amateur Radio, and XM Antennas
NEED TO BUY: GPS.
NEED TO INSTALL...EVERYTHING
10-28-2007, 12:59 AM
#18
ok so, what i havent update on this thread, is i have completely rewired my truck.
I now have a 0/2 gauge wire running from the battery to the back, it enters the truck through the Firewall on the passenger side real low. if you remove the panels below your glove compartment, and peel the carpet back a bit there is a plug in the firewall where your FM antenna wire comes in, what i did was drill a new hole for my fm antenna wire and use the existing hole [it's BIG] for my power wire. from that point i had to go a bit of a different route than you will, since 0/2 gauge wire is almost 1.5" think i took out all of the seats and the carpet and ran it up the center of my car [very carfully avoiding spots where the Rear seats contact the floor].
ALSO: i ran all of my other wires - VGA, 4xRCA's[front,rear,sub,computer], 3xcat5[networking wire, each has 8 wires in it, figured i could use them for something later, like turning on relays, so i put them in while i was there], 2xusb ---- try to run power and sound wires far away from each other, as the power wire can and will put noise into your audio
Bring it in through the firewall like i described above [side note i wrapped the wire in "aluminum heat tape" to help fight off engine heat]
Prior to my new 0/2 gauge, i had 3 4gauge wire, and i had them run up the passenger side under the door sills, or tuck them under the carpet near the doors.
well i can tell you where NOT to put the wire, do NOT try to snake the wire through the fender then in the door jam into the cab, it works for about a year, then your girlfriend will open the door when you're bringing her home from your 2 year anniversary dinner and you'll hear that sound you fear, zap pop, and you know the shielding on your wire finally gave out, and the night is ruined
if you use the firewall/fm antenna method i talked about above i suggest using a gromet on both the power wire and the fm antenna wire
Into the box was easy with the 4 gauge, snake the wire under the carpet from just behind the rear door, up by the wheel well, under your box, cut a little slice in your carpet and put a small hole in your box, and run it in, then use some sort wire hold downs to route it to it's final location cleanly.
I cant wait to put them up either, but being a student i've had NO time in the last few days, i'm hoping to catch a break tomorrow morning and get the pictures for you guys.
i've been working on this truck for 3 years now, and before that i had an s10 pick up for 3 years [same body style], so please feel free to ask away and i'll answer best i can.
i know this was long but i really hope this has been a help anything else, fire away, and best of luck on your installs!
11-05-2007, 01:01 PM
#19
as promised, pictures are posted in the first post
current status is:
the computer works well, it's running gentoo linux, as it is light weight and easily configurable, i dont use windows on any of my computers why bother using it in my car, my front end is nGhost, it's a really nice front end still under development, but check out there project make comments they listen, it truely is a front end made for the users, by other users.
I have iGuidance installed and "working" i do not have a sirfIII usb gps, so turn by turn will not work yet [it's on the christmas list]
i DO have an older garmin eMap which i've hooked up via serial to the carputer and i can get gps location through gpsDrive [but no turn by turn]
11-23-2007, 01:36 AM
#20
-- no progress, but a plan --
My carputer, has gotten buggy, my proof of concept install of a gentoo based carputer [named: MobileOne] has gotted to be a bit of a hack job, and it is now time to reinstall gentoo and cleanl install only the required packages.
possibly calling this install MobileOne.1 [hmmm maybe while things are compiling i'll make a logo for stickers something like: MobileOne.1
Features: - Gentoo
- nghost 1
- iguidance3.0 in xover
- Suspend2 kernel
- wifi scripts
- on screen keyboard
- handwritting recognition [through x-stroke]
Possible new endevers:
control via PDA/cell phone
voice control
Well big idea's all dependent on time. and also in development is a bluetooth hardware/software application to control many features in the car [not linked to MobileOne other than to turn on the computer]
it is nice to have MOST of the fabrication done on this project [although i'm sure ill think of more this summer]
12-27-2007, 09:15 PM
#21
shaggy or red, have you done anything with the overhead unit right above the rear view mirror, showing MPG, gallons used, estimated driving distance, outside temp, etc...? I've been looking to hook that up to a carputer, or modify the LCD to show all the options at once.
12-28-2007, 10:47 AM
#22
i have had that same thought, but have not done anything yet. Mine only does temperature, heck i'd be happy if i could just upgrade it to do all the things yours does.
my thought was not to connect it to my computer but to a microcontroler, so that thing will be avalible when my computer is off, i do a lot of short driving which it doesnt make sence to have the computer come up, and if i wanted to send data from the computer to the lcd i guess i could use serial imput to the microconrtoler... well those are my 2 cents
12-29-2007, 02:14 PM
#23
I've posted in Engine Management, OBD-II, Engine Diagnostics, etc... I'm too lazy to read the forum rules for cross thread posting. It's titled Chevy Blazer 2001 - Overhead Display. 45 views, and no replies.
Found this
http://www.hail.org/2tech/vancons/index.htm
and a discussion about it
http://www.hotrodders.com/forum/96-b...ion-10959.html
Reason: added links
01-10-2008, 03:41 PM
#24
christmas was good to mobileOne, new wireless card, two 2.4ghz antena's! except the ram died, so i quickly got my old HTPC, threw ubuntu, nghost, kistmet, and gpsdrive on it threw it in the truck and drove the 350 miles back to school in style [only problem was i couldnt get the touch screen to work :-\ ]
now i'm awaiting new ram then gunna reinstall gentoo like i talked about above.
01-17-2008, 01:36 PM
#25
thats looking nice. kinda big tho. i did mine to look as stock as possible to save room to use as a practical daily driver. check out my link in my sig.
02-26-2009, 10:22 PM
#26
I just read in Maximun Pc mag thers a linux for those small net pc's.
| Thread Tools |
| Display Modes |
Linear Mode
