Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 01-15-2008, 09:48 PM   #46
redls1bird's Avatar
redls1bird is on a distinguished road
More Fab done. I mounted my Powermate in what used to be my ash tray. Im somewhat pleased with the results, but, i think im going to redo the leather with a dark greay or black suede just for better asthetics and pleasing to the touch.
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
redls1bird is offline   Reply With Quote
Old 01-16-2008, 12:53 AM   #47
2001Civic is an unknown quantity at this point
Wow man, this whole experience has been a rollercoaster for you. hope things work out and they're looking good as of right now. Good luck.
2001Civic is offline   Reply With Quote
Old 01-16-2008, 09:48 AM   #48
redls1bird's Avatar
Yeah, its been all over the place. The worst part is, I have the drive to do all this stuff in a month or two, but my budget doesnt allow it. I Am getting married in may, and my fiance is also working on her doctorate, which means i am the only one working. This all makes things tight, so everything get stretched over a longer period of time. My goal is to have this done and installed before my wedding, may 18th.
My worklog
Old 01-19-2008, 05:15 PM   #49
redls1bird's Avatar
I found a way around the Gtgina.dll problem linksys users have for logon. If you dont know about it, installation of newer wireless adapters add in a file that throws off the way you log on. Its a real pain in the arse, and you cant change it via the control panel.
What to do about it:
Go to start, run: control userpasswords2 (no space in userpassword2)
Uncheck the box that says: Users must enter a name and password to use this computer.
Click apply. When the next screen pops up, leave the fields empty for password.
Click ok.
Reboot.
At this point you should see the login screen come up, then go right by.
My worklog
Old 01-19-2008, 05:27 PM   #50
WuNgUn's Avatar
WuNgUn is on a distinguished road
I have a planned spot for my Powermate (and a pair of analogue VU meters)...I'm so excited, I could wet myself!
WuNgUn is offline   Reply With Quote
Old 01-19-2008, 06:29 PM   #51
chvybeatsford is an unknown quantity at this point
First off nice setup and srry bout ur luck with it all.Also congrates on getting married.
What OS u running?
Also what has ur latest boot time been from cold start?Not hibernate.
chvybeatsford is offline   Reply With Quote
Old 01-19-2008, 11:32 PM   #52
redls1bird's Avatar
Thanks chevy! Im using Tinyxp for a os. It was quicker when i got it, with nothing on it. Just roadrunner and winamp, i could boot to music in about 34 sec. Now with Digitalfx 2.0 as a skin, bluetooth, wireless internet, gps and everything else, its boot to music in about 55 seconds. My way of combating this (after in bootvis and everything else i can think of) is to hook my psu up to an output on my remote entry system on my car to the same input as ign wire, with a diode. That what when i unlock my doors, it starts the boot process hopefully shaving off 10 seconds or so. Its only theory right now, but im pretty confident i can get it to work how i want.
EDIT: Bootvis shows cold boot takes 34 seconds, and winamp is running by 37 seconds.
My worklog
Old 01-20-2008, 06:38 PM   #53
wow i really need to see hwat is going on on my side my cold boot with jus rr and winamp also is roughly around 1 1/2 mins.No added programs to help though.
Old 01-20-2008, 06:47 PM   #54
What can I say? I like serial.
Curiosity's Avatar
Curiosity will become famous soon enough
Hibernate should help drop the time a little.
Remote starting the PC is very handy as well. I have a long range remote with some aux outputs and a custom SDC, but it should be easy enough with just the unlock. It's negative trigger (off one of the far right wires on the BCM) so you could use a relay if you want to reverse it for something that takes a positive pulse. If nothing else, make a 5-10 minute timer that simulates ACC/IGN (with 2 doides going into the SDC) before you get in.
XPort 1.41 -GPS port splitter, logger, and USB device resume fix
GPS DirectShow Filter / XOBD / MiniCam
Curiosity is offline   Reply With Quote
Old 01-20-2008, 11:41 PM   #55
redls1bird's Avatar
From the moment i touch the power switch to hearing sound is 22 seconds in hibernate. Thats not to shabby. I have no testing though to see if my usb components will make it back from hibernate and function properly. Because of this, i have told myself i may have to cold boot each time. Ive accepted it at this point.
What are your system specs chevy? Im running an old Intel board with onboard sound and video, 512 mb ram (maxed out) 1ghz PIII processor. Do you have an option in your bios for quick boot? or anything like that? It made a pretty good difference on my machine.
My worklog
Old 01-21-2008, 08:24 AM   #56
My specs
Via m10000 1ghz
512 mb
4gb CF card (133/x )
After some work in bios,disabling all devises from starting but the CF card I still get slow boot times.Now from standby (s3) I start back up in less than 10 seconds.I think I'm gonna use S3 for my start up.I haven't tested to see what power its pulling in S3 but I belive it is low enough plus the m1-ATX will shut down the CPU if the battery gets to low.
(srry I'm on my BB so proper text is a issue)
Old 01-21-2008, 01:28 PM   #57
redls1bird's Avatar
No prob about the BB. Ive noticed on my system that in quick boot mode it seems to skip the ram test. If i leave it uplugged for long periods of time, or remove the ram, it will do a full test on the 512 at startup and that adds considerable time. Is your testing the ram everytime?
My worklog
Old 01-21-2008, 01:54 PM   #58
Not sure. I didn't see a quick boot that's why I disabled all. The bios isn't what hurts me that's about 10-15 seconds at most, the windows XP boot screen is what kills me. But I think if I did minilogin that would help that alot.
Old 01-21-2008, 11:12 PM   #59
redls1bird's Avatar
Have you tried bootvis? Its very helpful and informative. It lets you see (via a bar graph and line graph) whats going on at each stage of booting and drivers as well. Download it and give it a shot. If you need any help using it let me know.
My worklog
Old 01-28-2008, 10:19 PM   #60
redls1bird's Avatar
Ive been debating mocking up my install in the car and testing it out for bugs and what-not. I was waiting til I had everything, but thats just gonna draw out the process longer. I think im gonna pick up either a m2-atx or a m3. I just dont like the idea of having to mount the m2atx, but hell its no big deal Also, in a couple of years i plan on doing a complete double din install, mother board and all, so i dont know what my power needs will be.
My worklog
Connecting carputer to stock amplifier of a 2001 Pontiac FireBird TransAm? WWE-TicK Newbie 11 03-15-2007 08:16 PM
how do i remove my car stereo's dashboard trim? (2001 pontiac firebird) tmc2k1 Car Audio 6 04-24-2006 01:18 PM
2001 Pontiac Sunfire Moneyfink Worklogs 5 06-24-2005 05:59 PM
2001 Pontiac Firebird TransAm and a DWW-7VGA? WWE-TicK LCD/Display 26 02-12-2005 11:16 AM
