Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 10-16-2006, 12:22 AM   #31
sporty_drew's Avatar
sporty_drew is on a distinguished road
I've been watching this since you started and all i can say it it looks great and it almost makes me wish i didn't have a center console just so i could do this (tho it would never look as good). Keep up the great work! Later
sporty_drew is offline   Reply With Quote
Old 10-18-2006, 10:38 PM   #32
Eternalodyssey's Avatar
Eternalodyssey is on a distinguished road
Yeeeah!! Console pics!!
So far, I have I have hit road bumps and speed limits during this project but these past few days have yielded some absolutely excellent results!!! I was a wee bit nervous about cutting into the material that I have worked so hard to cover the console with. But the only way to advance forward is to get out there and do it! So I started with the fan openings to get a feel of how to cut the material without completely chopping it apart.
I cut slices to give a nice "round" look to the fan openings. I used thumb tacks to secure the material to the console while the locktite glue dried.
I repeated the method with the fan opening at the rear of the console as well. Having both these fans should allow me more then adequate airflow and cooling for the VIA SP 13000 Mobo that I am running. Although I do not expect it to get very warm because I have tried to keep things to a minimum of power constraints. Once the glue dried, I simply cut the excess material off and drilled holes for the fan assembly bolts.
My next step was to mount the stereo. I used staples and locktite glue to pull the cut material into the proper place to give it a nice refined look. I think that it came out rather well. My next step for the front of the console is to mount the A/C controls which look like they will promise to be a royal pain in the @$$.
While thinking about the steps I will need to take to get the A/C controls mounted, I decided to fit the DVD burner, the front fan, and the fan controller. I mounted the fan controller upside down so that I can see it when I am sitting in the driver's seat rather then having to read it upside down. When I post my finished project I will go over all of the accessories that I incorporated into this project and where I bought them from but for now I will keep my updates strictly to my work processes.
Here is a nice semi-side shot that shows the Thermaltake fan completely mounted. I plan on installing a 12" blue cathode light inside this case that will emit (hopefully) some light through the fan grills and through the plexiglass window in the back. I would like to get a nice little VIA logo for the plexiglass window but it looks like I might have to make my own and have a buddy of mine put it in the vinyl cutout machine. More updates to come. Till then..........................
Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/worklogs/85490-project-2003-dodge-dakota.html
IS JACK BAUER GONNA HAVE TO SMACK A *****?
Eternalodyssey is offline   Reply With Quote
Old 10-18-2006, 10:39 PM   #33
Deric's Avatar
Deric is an unknown quantity at this point
Can you post the dimensions of the new screen you are using? I am wanting to use this screen for my 06 Mustang project.
Thanks!
-Deric
Deric is offline   Reply With Quote
Old 10-22-2006, 09:02 PM   #34
Center console almost finished
Today I added more Bondo and did a minor amount of sanding. Oh yeah, for anyone wondering what the dimensions for my TM 868 replacement screen are, its 6 1/2 Inches tall, 8 Inches wide, and approximately 2 Inches deep or so. I promised myself that I would get as much done as I could before watching the Cardinals game. Man St. Louis turned into a madhouse this weekend!!
Anywayz, I needed to make an armrest for the top of the center console and acquired some nice carpet foam to use to keep the underside stiff and supportive. And then on top of that I added a few layers of very comfortable craft foam to fit under the material. My old console was kind of rubberish and during long road trips it would hurt my elbow.
I foamed the ever living SH1T out of the top and it is rather comfortable to the touch. I presented it to my boss, (wife) and got the thumbs up of approval. This whole project carried some stipulations with it and that dictated more then one design setail to say the least.
My next step was to install my Thermaltake fans to keep this badboy cool. I wanted the console to look factory and very well functional but I also needed to keep in mind that a computer is going in there and maximum cooling and stability will need to be maintained. I have two fans, one in and one out to matain a good constant air flow for BOTH power supplies. I'm running one for the computer and one will provide a nice steady 12 volts for the monitors and some of my accessories (USB hub, wireless headphone transmitter, etc.)
Check out the updates. Project 2003 Dakota worklog: http://www.mp3car.com/vbulletin/showthread.php?t=85490
Old 10-22-2006, 09:13 PM   #35
Okie dokie, I figured I would post these two pics before I drink beer and wach baseball.
I fit the stereo into the console the other day which allowed me to move onto the A/C controls. The only problem with that is that the console is not ready to get put into my truck yet and once I put my controls in I am not feeling enthusiastic about ripping them back out just to run my heater (its getting cold right now in STL). Nevertheless, it worked out and now my A/C controls are fixed very comfortably into my console.
Next step was cupholders fitted. I have found that if you cut an outline about 1 Inch in from where the actual edge of the wood is, it gives you a nice lip that you can pull tight and staple the material to so that it does not move. I have used Locktite glue, staples, and even a combination of both on different parts of this project but for right now I think that the staples work the best for quick results and instant gratification although it does add a little thickness to the material I am working with which make things tight to fit. Not a big deal though. Thats all for now. Gametime!!!
Old 10-23-2006, 09:23 PM   #36
Talking More screen work
Well, F the Cardinals. Now that thats out of the way, I sanded and bondo'd the screen to build up low areas and round off a few corners. During the process I loosened some of the Locktite glue and had to re-apply the glue to reaffirm the integrity of the pieces. After bondo and sanding I decided that it was time lay some preliminary layers of acrylic primer. Its clear like the stuff I used on my last screen and seems to go on pretty easily with very little chance of running.
I laid about 5 or 6 total layers to help even everything out and I wet sanded the screen to smooth it out. After some sanding and eye-balling I decided to lay another couple layers to give it a little more material for me to work with when I give a final sanding before I lay another layer or so of primer and then get into some painting.
Right now its looking rather smooth and I have already decided to lay down a preliminary layer of black to help bring out some of the imperfections. Originally I wanted to use some textured paint on the top and bottom pieces of stereo bezel trim but I decided at the last minute that it might look better if I keep it all the same color/texture. Tomorrow is another day and holds much opportunity for this screen bezel to be finished by the end of this coming weekend. My wife and I are taking a trip down to South Carolina at the end of November and I am very anxious to have the computer completely installed and running by then. Looks like I stand a good chance as long as I keep plugging away at my To-Do list.
Old 10-24-2006, 04:53 PM   #37
Screen painting..........
Today I wet sanded the newly primered and smoothed screen to prep it for paint. I really wish that I had some kind of colored primer right now because it is rather hard to see any imperfections. I am relying on feeling the imperfections and I don't think that is going to yield as great results as I could have had if I had simply acquired some colored primer. Well, I guess I know now for next project.
For now I have put some preliminary paint on the screen to look for imperfections. Perhaps I could have skipped this process if I had colored primer but again ........................... So I laid down a couple coats and I see some imperfections that need to be worked out with the wet sand paper. The thing that sucks is that I will need to wait until tomorrow before I can sand it and go for that final set of paint coats. Oh yeah, in case anyone gives a crap, I am using satin black which I think looks more OEM than I could ever get gloss black to look. I am happy with the way that the paint looks when it is dry and I will keep this information for any future projects of mine that I want to look OEM.
One thing that I have realized is that with the added material area space that the paint has added on, I will now need to widen my dash cutout. DANGIT!!! I had already put so much effort into making that nice and straight. Oh well, its a work in process. The only way out is through!!!!!
Old 10-24-2006, 08:00 PM   #38
Talking Console Finished!!!!!
Today I finished covering the top of the center console as well as the small cover for the hidden compartment which will house my Creative MP3+ USB sound card as well as my video splitter which will feed my 3 auxillary monitors. The foam went on pretty easy as well as the vinyl covering. One thing that I have noticed with this project is that the vinyl is much easier to work with when it is warm as it stretches much nicer to create the nice "flush" look.
From here you can see that the arm rest on top of the console appears to be rather thick and that is because I used two layers of stiff carpet foam underneath two layers of craft foam to make a rather comfortable arm rest. In fact, I like this arm rest at least 10 times more then the original one that felt like a piece of rubber stretched over some shallow foam. When I would rest my elbow on it for more then 10 minutes or so it would start to feel sore and I don't get that with the new one.
And here at long last is my finished console!!! My main requirements for this project were to be able to fit all of my components in a way that would not seem to cluttered and still be able to reach everything rather well. Everyone that sees the console remarks that the stereo looks much better down there and overall it has a good "accessible" feel to the whole thing. I am nothing short of impressed with the way this turned out and I would like to thank all that gave me input to get me this far. I still have much to do to finish this project but this is probably the biggest step in getting to that FINISHED spot. Next to do on my list is to finish the screen, finish running all of my wiring, and then simply drop the computer in. But for now, CHEERS!!
Advertisement Sponsored links
Old 10-24-2006, 09:50 PM   #39
AllThingsEnd's Avatar
AllThingsEnd has a spectacular aura aboutAllThingsEnd has a spectacular aura about
awesome install. i have an 02 durango and cant wait to see your whole project complete. how are you attaching your bezel to your dash? and how hard was it to relocate the the ac controls? just lengthen the wires?
[::::::::::] 100% - Planning
[::::::::::] 80% - Computer
[::::::::::] 0% - Fabbing
CarPC:
SP13000 / 120GB SATA 2.5" / 512MB DDR
8" Innovatek TS / Globalsat BU-353 / Engenius EUB-362 EXT
Slot load DVDRW / PS3 Wireless Keyboard
AllThingsEnd is offline   Reply With Quote
Old 10-24-2006, 10:02 PM   #40
Sidewalksalvage's Avatar
Sidewalksalvage is on a distinguished road
That is a flipping awsome install! It really came out nice an sleek... Sorry abou the first screen....
I cant wait to see it finished and running!
Worklog -- 1987 Toyota Camry Resurrection
Current Progress:
[XXXXXXXXXXXXXXXX====]80% Works Great; Front speakers need to be replaced; On hold while at school.
Brown 2010
Sidewalksalvage is offline   Reply With Quote
Old 10-25-2006, 08:09 PM   #41
The Durangos have much the same setup as the Dakotas from what I have seen. In order to relocate the A/C controls I had to extend about 11 wires and I used 14 gauge wire to keep the wires from heating up and maintain good conductivity. I was nervous about the wires being extended that far and what issues I might have as far as performance of my climate control being affected. But after having my wires extended for months I have noticed no problems with it whatsoever. The only factor I have experienced is that when I change a setting on the climate control, there is a very very slight delay in change. If you look back in my worklog you will see that I cut apart a Crutchfield aftermarket stereo bezel that allows you to use a single din stereo. After I sliced it in half I Used Locktite glue to affix the pieces to the screen bezel itself while I had all of the pieces taped and set into the dash the way that I would expect to have it when I am finished. After I was satisfied with the position of all pieces I trimmed, bondoed, and primered the pieces for paint. If you look at the outside of my screen bezel you will see the holes where the bolts go for the factory stereo/aftermarket stereo bezel. The dash assembly comes off wuite easily by pulling on the piece near the dash. It all comes off in one assembly and is not hard to get off. Below this post should be my latest and greatest worklog. If you have more specific questions feel free to post them or even PM me and I can share some of my "worthless" photos. I've taken literally over two hundred pictures so far. Not all were deemed worthy of my worklog because I didn't want to go overboard even though I know I post a lot of pictures. Not a bad thing though.
Old 10-25-2006, 08:33 PM   #42
Today I applied more sanding to my screen bezel and prepped it for final painting. I took care as much as possible to address any imperfections that I could find and although I am quite sure in my own critical eyes I will not find absolute perfection but I think that I will get really good results given that it is my own project.
And here at long last is my freshly painted screen with approximately 5 layers of Satin black. Although it might appear that my screen is rather shiny, the screen had just been painted and when it dried much of the gloss left to reveal a very impressive OEM looking bezel that appears to be all one piece which is exactly what I was looking to accomplish.
Here is a good view of just how solid the screen bezel appears. The finished product is rather strong and feels solid. I am fully confident that the bezel will stand up to just about any bumps and vibrations that I expose it to in the truck as long as I don't overdo it. I can't wait until the paint is completely dry and I can re-attach the touch screen. I need to widen out the opening in my dash ever so slightly to account for the extra area that the paint is taking up. Shizzam, this project is really coming together now. I am very excited about what the next couple weeks will hold now that I am getting closer and closer to the end.
Old 10-26-2006, 08:14 PM   #43
Craven is an unknown quantity at this point
Very nicely done. I also have a Dodge dakota quad cab and am looking at doing a similar center console. Mine will be minus the computer but i am going to be keeping the factory GPS unit in dash and installing and aftermarket head unit in the same location as you did. Did you extend the antenna wire to the new head unit, if so what did you use to do it?
Great install
Craven is offline   Reply With Quote
Old 10-26-2006, 09:11 PM   #44
Although at first it seemed a little ghetto, it actually worked out quite well. I got my hands on a coaxial cable extension kit from Radio Crack and used that to use a piece of regular cable wire to simply extend the wire. I have noticed absolutely no loss in quality of antenna signal with this route and I will be posting some pictures in my worklog soon. If you are making this same console I can email you the patterns and measurements that I used to make this if you would like. Matter of fact, if anyone is requesting any of my methods to madness as well as any measurements that I have not posted, feel free to PM me and let me know, as I would be happy to share any of my work with anyone that would like that information.
Old 10-26-2006, 10:04 PM   #45
Thanks, thats sounds like it would work well. My console is going to house 2 amps and a subwoofer in place of the compute and the head unit. It also has to have cupholders so i think it is going to be a little higher than yours.
2003 Mazda 6 project Brunation Show off your project 28 06-15-2009 09:51 AM
2003 Dodge Ram 4x4 Laramie GinoRP Show off your project 19 05-21-2008 01:10 AM
2003 Dodge Dakota Club Cab problems MisterMorse Newbie 2 10-15-2006 10:54 PM
2003 Silver Dodge Dakota SXT hum Show off your project 16 10-15-2006 10:27 PM
New 2003 Saturn L200 In-Dash Project snoslicer8 Newbie 5 08-20-2006 11:06 PM
