Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 10-24-2006, 08:42 PM   #16
alertik is an unknown quantity at this point
i was looking for side pics and i found these before and after shots so you have an idea...
alertik is offline   Reply With Quote
Old 10-24-2006, 10:53 PM   #17
skuller is an unknown quantity at this point
great! keep updating the thread. can't wait to see the end result.
skuller is offline   Reply With Quote
Old 10-25-2006, 08:01 PM   #18
HybridPower's Avatar
HybridPower is an unknown quantity at this point
Sweet, you're right on track with what i was thinking about doing in getting the door to slide up and down when the pc turns on and off.... just haven't gotten around to ordering my screen and any phidgetts or something to raise and lower the door.
as for the question about the room above the screen when the door is up...you still have some room above the box section that it will clear.
I actually ordered the compartment off of ebay. I haven't touched it yet, and have looked at the mechanism that opens/shuts it. If needed I can take some measurements and pictures. I'm not taking the door off just yet until I know what I'm going to do with it. But I can get some pics for anyone that needs it.
Also, I ordered the repair manual that the mechanics get...so I do have other diagrams of things... electrical and expected reads of the signals... ect.
keep us updated on the progress! I'd love to know how the xenarc fits into it. I think when i initial measured, it was too big and would need to be cut exactly the way alertik did it (maybe look a lil less like he chewed it apart!) lol
I think i'd rather have the xenarc for its capabilities of changing screens when autodetecting a signal (reverse camera)
HybridPower is offline   Reply With Quote
Old 10-25-2006, 08:02 PM   #19
I'd be interrested in knowing how jason was going to fit a 10" screen in there too.....
Old 10-27-2006, 01:20 PM   #20
Zeeshan0581 is an unknown quantity at this point
I am working on the same thing, but getting my partts together so far, almost done. I like the idea of having the cover flip open on power on. What would i need to make that happend?
Also has anyone done any research if the Accord has the IBUS or CanBus interface that can be connected to the pc?
Zeeshan0581 is offline   Reply With Quote
Old 10-27-2006, 01:24 PM   #21
One more thing i forgot to mention: The double din for Accord is not made by Honda, but some other company, you can buy that off of crutchfield.com
Adapter it comes with allows you to connect your stock but you wont hear any sound from it, i had to create my own harness and splitter to get my second din going with the stock, even though i can only have it on one at a time.
Old 10-27-2006, 01:59 PM   #22
Sweet someone else in the loop... I'm not a programmer or elect. engineer..or had the time to learn, but it seems like the phidgetts web page gives a possible solution with usb controlled motors... to help with the opening the door. you can write a quick program that could run on start up, and run on power off.
I can't remember what honda uses, but i can look at my manual and tell you.
Old 10-27-2006, 06:51 PM   #23
I took the screen out to work on it over the weekend - more bondo, repaint + maybe play around to see how to make it to open/close by itself.
what I’m thinking is to have a circuit with a capacitor in it -- motor will open the door (not sure how yet... maybe a belt or a wire which motor will pull) after the cap. is charged motor will stop. opening should be fairly easy. but closing the door is a little trickier, since I’m not running any wires straight from the battery -- I’m using the cig. lighter and it is off when the car is off. I was thinking of using the charge from the cap. to give it a push and then gravity will finish the job, but I’m not sure if cap. will have enough juice in it for that... I guess I have to dig out my physics book.
another thought i had -- if i buy that PIE aux in with sony cd-changer interface, i think there is a hack with a pic chip to send sony cd-changer commands to the pc... that way i can send commands to the pc right from the HU controlls (or steering wheel controls if you have them).
anyway here are side pictures someone wanted.
Old 10-28-2006, 10:40 PM   #24
added a usb port today...
2003 Honda Accord install Worklog
Old 10-29-2006, 01:51 PM   #25
Methom is on a distinguished road
How long did you spend on the entire project?
Also, after you cut up the cubby hole, how much time did you spend on after thatt?
Methom is offline   Reply With Quote
Old 10-29-2006, 08:29 PM   #26
I thought about putting a usb port there on the drivers side right next to where the traction control buttons are.... would look clean and a little hidden
Old 10-30-2006, 03:57 AM   #27
Luderboy is on a distinguished road
ahh thanks alot for the pics. Does the cover stay open when you're driving? This whole time I was planing to keep the spring function on the cover.
Luderboy is offline   Reply With Quote
Old 10-31-2006, 09:12 PM   #28
you can easily fab it in one weekend... if you know what you are doing you can do it in one day... i spend around 4-5 days, becase i redid the thing 3 times.
thats where i want to place the power button
the cover stays open. keeping the spring probably wouldn't work out... at least not with my screen.
Old 11-06-2006, 08:31 PM   #29
ghetto door opener
here is what i ended up with for an automatic door opener... i've used a spare 12V motor and a pushbutton i ripped out of an old printer
the motor spins on the string, which opens the door, the door pushes the button,which cuts off the power for the motor.
so far it works fine... to keep it simple i decided to close the door manualy... at least for now.
Old 11-06-2006, 09:24 PM   #30
john05srt4's Avatar
john05srt4 is an unknown quantity at this point
thats pretty good work.
I had to hack up my inside part to fit my xenarc.
john05srt4 is offline   Reply With Quote
Resetting Honda Accord SRS light MatrixPC Off Topic 18 08-11-2009 08:56 PM
2003 2004 2005 Honda Accord CarPC Adam2312 Newbie 161 02-09-2009 10:25 PM
WTB: complete kit for honda civic 2003 thomasamiller Classified Archive 1 11-21-2005 02:17 PM
99 Honda Accord shane1234 Show off your project 10 10-17-2003 09:04 PM
Will the Garmin GPS35 usb work with copilot 2003? e36mp3 GPS 3 04-09-2003 11:48 AM
