Quote: Originally Posted by
Luderboy
what did u use to seal up the daps?
hows the door function? does the screens frame get in the way?
lastly, can you take side shots with and without the door on? thanks
epoxy to hold it together, bondo to fill. The door closes and opens with no problems. Keeping the door functioning was my goal and is the trickiest part of the fabrication. if the screen was just a few mm wider or thicker it wouldn't fit and i would have to create my own casing for it.
I will post pictures next time i take the thing out, there is a pic with no door though... as you can see i had to cut off a lot of plastic, which makes the structure very unstable. once you put the bin back in the car, side-rails hold everything together. what i ended up doing is super-gluing bezel inside the car to make sure everything will fit, then reinforce it with epoxy.
i'm trying to figure out how to open/close the door automatically as i turn the pc on/off...
