Go Back   MP3Car.com > General > Show off your project > Worklogs
Notices
Old 11-14-2006, 04:12 PM   #31
SnowDrift's Avatar
front with bondo
SnowDrift is offline   Reply With Quote
Old 11-14-2006, 04:14 PM   #32
SnowDrift's Avatar
All caught up
And that’s where I am today. Work and bad weather has prevented me from really working on this since last Thursday. I hope I can get the bezel done soon because I have a final project for school due in a month and I don’t think I can give it adequate attention while working on this. Plus I’ve been recruited to fix my little cousin’s Corolla. First it was just the front bearing, now it seems to be the ball joint and tie rod too.
Old 11-14-2006, 04:19 PM   #33
SnowDrift's Avatar
$ Cost $
After reading the title of this thread, I’m sure some people are wondering how much I’ve spent on this project. The simple answer is: $479.41(I think)
But let me explain a little so those of you who are considering doing a carputer project can get an accurate picture of the cost involved.
Here’s a list of everything I bought for this project since I decided to do it:
Touch screen- $196.95 (need some sort of monitor vga touch screen is preferred)
Ai-net adapter- $13.48 (need because my hu doesn’t have aux input and didn’t what to get amp, too expensive)
Computer- $65 (this is where big differences come in. Not running Photoshop or warcaft in the car so don’t need anything super fast, can always upgrade later on. Some will get killer used deals or hand-me-downs; others will build/buy new machines)
Mini keyboard- $14.44 (didn’t really need if because I got the ps2 one too)
Ps2 keyboard- $9.99 (need some kind of keyboard)
Serial cable adapter- $8.00 (need to connect vga out from monitor to vga cable, some might not need)
Laptop dvd combo drive- $59.99 (kind of need. Also have slot load one I could use but it a little old and skips too much)
10’ usb extension- $3.98 (need some kind of usb cable, should have got 2 of these instead of other usb cables)
Flat usb hub- $5.98 (don’t think I need 2 but depending where I put it, one will fit better than the other)
Square usb hub- $5.00
15’ usb cable (2x)- $12.99
20’ vga cable- $16.99 (need if putting computer in the trunk)
Usb 2.0 card- $15.00 (don’t need if computer already has usb2.0, still might not need if it doesn’t)
Dash console- $51.62 (don’t really need but I like to have extra, just in case)
Epoxy- $5.00 (need)
What’s missing from this list?
Psu- using inverter I already have. Plan on getting a proper one once I collect enough cans, and sell one of my kidneys.
Gps receiver- already have a Delorme one I got a few years back. It works fine.
Software- can’t afford streetdeck so I’ll have to find cheaper alternatives. I have some mapping software but they are a few years old.
Other things I’m using and already have are: shorter usb extensions, usb-serial adapter, rca, power and ground wire, back-up camera, spare interior components and dash radio pod.
Materials so far: mdf(had some), sand paper(had some, bought some), aluminum(had some), bondo(had some, borrowed some).
Tools: if you can’t get your hands on tools, project can’t go anywhere. The right tools also make the job easier.
I have a pretty basic set-up, and as you can see, I really didn’t NEED everything I bought, but I also already had a few key components. The best way to save money is planning. Know exactly what you want, where and how you are going to mount things, and what it requires to do so. This forum is a good resource for that. That way you won’t waist money buying things you don’t need. The downside to that is it leaves little room if you change your mind later on.
All in all, I found this to be a much cheaper alternative to pre-fab gps units on the market. Plus it’s customizable and upgradeable without any limits. The trade-off: your labor, not a bad deal if you ask me.
Old 11-14-2006, 04:22 PM   #34
SnowDrift's Avatar
In the works…
Now I need to work on things more before I can post more progress. I’m still trying to rewire my power button from the computer, finish the bezels, wire in the inverter, mount front dvd drive and usb hub and run a few more wires. Here are a few misc pics left over. More to come, but that’s all for now.
Old 11-21-2006, 02:27 PM   #35
SnowDrift's Avatar
Update on the progress
Well, it's been a rainy week up here in New England. That's bad and good. Bad 'cause it's hard to work on my car in the rain. Good 'cause can't work on my cousin's car in the rain and can work on mine. I've probably spent 5 days on my porch steps sanding and filling and sanding and filling... my bezel. In between drying times, I've made room in my dash for my dvd drive by cutting the dash up, I've installed RR and installed one of my old gps software.
Today is a very nice day out(and I don't have to go to work) so I'm hoping to have the bezel painted by the end of the day and reassembled tomorrow(I'm waiting for a coat of primer to dry right now). I haven't had time to resize my pics, but when I do, I'll post them and give a little more detail of the process, although it's just basically sanding, filling, sanding, filling, sanding,...
Old 11-21-2006, 06:51 PM   #36
lol, and oh yea...quick hint An, when doing stuff in your car, make sure it's ventilated...those fumes really get to yah... i learned the hard way
LaxPlaya8513 is offline   Reply With Quote
Old 11-26-2006, 10:04 PM   #37
SnowDrift's Avatar
Thanx for the tip, but I figured that one out already.
Old 11-26-2006, 10:07 PM   #38
SnowDrift's Avatar
Here's some pics of my bezel workout.
This is the first round of finishing bondo
Old 11-26-2006, 10:32 PM   #39
SnowDrift's Avatar
I'm using this sanding mouse with 80 & 120 grit sandpaper to do most of my shaping. It makes quick work of things.
Old 11-26-2006, 10:44 PM   #40
SnowDrift's Avatar
After a few tries, I finally decide on the final shape of the edges, corners, curves,... and start working to make it all perfect. I'd fill with bondo, then sand down with 120, 200, 320 grit sandpaper by hand (this is the sandpaper I had on hand). Then I'd molest EVERY inch of the bezel, marking all imperfections so I can go back and fix them. Towards the end, I'd be shaping with 320 grit paper, just so everything would be silky smooth. That went on for about a week.
Here's about half way...
Old 11-26-2006, 10:45 PM   #41
SnowDrift's Avatar
...and here's almost ready for prime time...
Old 11-26-2006, 10:51 PM   #42
SnowDrift's Avatar
It would go under the sandpaper a few more times after that last pic. A little bondo goes a long way, each time I'm filling, I'd only be mixing tiny amounts.
I finally feel that it's ready for some primer. Here's the first coat. I sprayed a thick heavy coat because there were knicks and pits I wanted to fill from my removing of the blue paint.
Old 11-26-2006, 10:53 PM   #43
SnowDrift's Avatar
Using this filler primer.
Old 11-26-2006, 10:55 PM   #44
SnowDrift's Avatar
Sanded the primer with 320 and 600 grit paper, then sprayed on more coats. Did this about 3 or 4 times.
Old 11-26-2006, 11:01 PM   #45
SnowDrift's Avatar
That night I brought it inside and wet sanded it with the 600 grit paper to get it ready for paint the next day.
I then painted it with paint I think I've had for like 10-15 years. It's a silver/chrome paint that didn't match and took fooooorever to dry. I would have to go and buy new paint, after I sanded the bezel down again.
CARPUTER 2002 Accord FINISHED! aznblueeboi Show off your project 44 08-18-2005 11:37 PM
WRX carputer project (working...) gleinz General MP3Car Discussion 30 06-24-2005 12:32 PM
2002 1.8T Jetta Carputer NEWBIE!! hockmastr8 Newbie 3 07-09-2004 10:08 AM
2002 Alpine Class A RV Carputer in dash w/mounted 10.4 LCD ProjectDinero Show off your project 11 06-14-2004 09:37 AM
Carputer on a $800 Budget f250crewcab Newbie 29 06-02-2004 06:27 PM
