Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 09-21-2007, 12:57 PM   #106
sporty_drew's Avatar
sporty_drew is on a distinguished road
what an update. I don't think i've ever heard anyone switch from the H701 to software. I'm glad it's all working out great for you. (thats one thing i really need to look into more).
What all do you plan to do with your Fusion Brain?
1998 Camaro Worklog Pioneer P860MP, 3 JL 500/1's, JL 300/4, 3 12" Type R's, Diamond m611's
sporty_drew is offline   Reply With Quote
Old 09-21-2007, 03:09 PM   #107
Car Audio Moderator
durwood's Avatar
durwood is an unknown quantity at this point
I ways back in my worklog I started to wire up directly to the front panel buttons on my factory radio. Origianlly I was goign to use a USB gamepad or keyboard controller, but it won't work the way I need it to. So I looked intot he Fusion brain and it has 10 analog inputs that I can interface with my buttons. Originally I needed 12 button capability but I can live with 10. So, I can connect things like track up/down, ff,rw, load, CD,media,sat to it and use them to control Roadrunner. It will also act as my amplifier delay turn on since i have a pop I need to get rid of. And last if it ever gets developed, better volume control. I might use it to turn on/off fans and such too to use it to it's full ability.
The software plugins and such are not easy to get working at first, but with the right soundcard it's pretty damn cool. It looks like Audiotrak is going to be producing more of it's Prodigy 7.1Hifi cards again and that card really makes it easier when using ASIO and VST plugins because of it's Directwire feature. Plus the sound quality of the card is pretty good-better than any of the Audigy cards I have used.
System always under construction
durwood is offline   Reply With Quote
Old 09-21-2007, 03:41 PM   #108
Super Moderator. If my typing sucks it's probably because I'm driving....
turbocad6's Avatar
turbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to beholdturbocad6 is a splendid one to behold
hows the processor load? is the pc still responsive & does everything it used to well? flash skins? video's? multitasking?... enquiring minds want to know!!
turbocad6 is offline   Reply With Quote
Old 09-21-2007, 04:06 PM   #109
Car Audio Moderator
durwood's Avatar
I haven't loaded in the EQ's yet, but they didn;t seem to impact the load as much as allocator. Preliminary tests showed it was peaking at around 50% with the EQ's. My 45 minute drive in this morning everything was working fabulous. Road runner didn't slow down one bit. I'm using the simplistque v1 skin. I'll try out GPS today too and see if it still runs full speed ahead. Last is DVD/video but I need to figure out the delay since I think my latency settings are set at about 1024ms on my soundcard.
Hibernation takes a little longer-it seems it hang a bit but I'm just happy it comes out of hibernation ok. The turn on thump is dangerous though. I need to protect my tweeters ASAP. First thing on my list for the weekend.
As far as sound comparisons between this and the H701, midbass is tighter and much more defined, midrange is more netral sounding which is nice because 1-2Khz was really ripping my head off with the alpine. I still need to adjust my highs a bit more because they don't seem right yet, but they are a bit smoother than the alpine was. I translated the exact crossover settings and TA from my alpine to this and I ahd to tweak it a bit. I heard rumors taht the H701 isn't as accurate on its filters as one would think, which might explain why I had to tweak it a bit. Once I take it out of my car, I plan on testing to see if that is really true.
Old 09-21-2007, 04:16 PM   #110
Sounds cool. I love how versatile the Fusion Brain is, and making skins for it is a breeze. I'll look into those sound cards. And thanks for the cpu load info. I was wondering how it was.
Old 09-21-2007, 04:18 PM   #111
Car Audio Moderator
durwood's Avatar
Do you have a fusion brain? I started to follow it when they were first designing it, but I got busy with other things and have to go back and catch up. How are you using it if you have it?
Old 09-21-2007, 04:22 PM   #112
I bought it for a friends install. We are just using it for 8 outputs to relays which are controlling lights (cathodes, leds, iceled) That is all that he wanted to do with it. I know, i know what a waste with everything it can do.
Old 09-21-2007, 04:40 PM   #113
_
RedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura aboutRedGTiVR6 has a spectacular aura about
question for ya about the tuning via software:
do you have it so that all of the programs start at start-up?
do you have to go in and adjust anything on start-up? I know you're using hibernation, but what about just start-up?
Jan Bennett
RedGTiVR6 is offline   Reply With Quote
Old 09-21-2007, 11:58 PM   #114
Car Audio Moderator
durwood's Avatar
Once I save the setup in console, I just created a shortcut to the setup/config files and put it in the windows startup folder. It takes a few seconds for it to load it up but it does load it up. The thing with my card is that WDM is muted in the driver control panel (directwire) so unless console is running, nothing comes out of my soundcard and that was one of my fears. I'm not sure how that would work with any of the other methods besides Directwire.
When it comes out of hibernation is stumbles for a few seconds (sounds similar to a CD skipping), but then it is fine. I imagine that is just how ASIO reacts since it is picky like that. I might try to do some fancy smancy stuff in RR to turn off console as it hibernates and then turn it back on during resume.
Update: I tossed in my PAC TR7 for the time being and I have it delay turn on, no more turn on pop! That should hold me off until I pick up the Fusion brain. Last final thing to do is get better volume control. My long time installer buddy heard it tonight and said my car has never sounded better, and I haven't even begun to tweak it with any EQ work. Now he is itching to do a PC with software processing and admits the H701 sounds like poo poo compared to it.
Old 09-22-2007, 10:42 AM   #115
turbocad6's Avatar
tr7's are like duct tape, you can use it for almost anything
durwood, what your saying is pretty strong, it sounds better with no eq'ing than it did with the 701 fully tuned? that's saying a lot, but I'm not 100% sure exactly what.
my first thoughts are, if this is really the case, maybe the 701 install had something not right? maybe level matching is more ideal now? maybe it wasn't tuned as good as it could have been, or overprocessed?
I remember once in a thread somewhere in a discussion with red, we were talking about the quality of the components in the 700-701 processors, & of course while the alpine is an amazing piece in it's own way, it obviously comes with the tradeoff of less than optimal components in the signal path. the alpine is amazing to me because before it, you needed like 3-4 seperate components to do the same job, & you didn't have a nice gui interface to it on the dash,
but I always felt a slightly less... something with the alpine, the best way I can discribe it is to me it sounded just a bit more digital almost, if that makes any sense, slightly less warmth & detail, but in a new install too, so I never had the chance for side to side comparison really.... I always felt the 700-701was a trade-off, but acceptable for what all it did, especially for just a street system.
for the convienience & ease of use & great interface it's been a viable option for a good while now... I used to want to upgrade to the pxa h900, with the though of, THAT'S the difference between the f1 status units & the budget minded 700-701's, the actual components in the signal path
so, is that what your hearing? is there that much of a difference in the components in the signal path now? to what would you atribute such a dramatic diffence that it sounds better even before tunning???
Old 09-22-2007, 11:24 AM   #116
Car Audio Moderator
durwood's Avatar
Well one night when I was tuning I finally heard the low level hiss coming from the rear channels (midbass) that people complain about. I'd been having problems with my midbass drivers and there was some sort of weird phasing issues is the best way I can describe it. There always seemed like a null in the midbass on the drivers side no matter how much TA or level matching I did. Then there was a null in the upper midrange/lower treble I could never fix on the passenger side??? It might have been that with the sub crossover point so low and the narrow band the midbasses were crossover at, it may have been asking too much from the processor. I don't know I'm just speculating.
It could be the level of adjustability is greater now, level can be adjusted in 0.1db increments where as the 701 is only 1db, TA can be adjusted within 0.01ms, alpine 0.05ms. I'm not sure what frequency arbitrator does in terms of crossover phase correction, but somehow it "corrects" the phase form frequency allocator. That could also play a part. I also heard a little rumor that the Alpine's digital crossovers are not accurate. I have yet to see proof of such an accusation so I plan on testing that once I pull it out of my car. I'll just say I've never had as much a of a solid center image as I do now.
All in all, The alpine is still a great piece. It can do so much processing that most of the others can't do. For the price, it really can't be touched. The Behringer with the new DC power supply comes close, but it's still only 6 channel not 8 channel. I mean there are alot of great sounding cars out there using the alpine and I'd not be afraid to use it again. It's one of those things where once you start to have ultimate adjustablity and great quality components its hard to go back.
I had a look inside Alpine and they use standard 4580 opamps on their preamp. I don't know what DACs they use inside the 701, but I'm sure that plays a factor. And the last issue is usually clock jitter. But like I said at the 701 price range, what else is there?
I've got to get 8 more points and then I'm eligible for MECA finals. I wasn't really excited about going because I just never felt it was up to my par and recent tuning issues were getting me down, but now I'm revived again and I really feel like trying to make it again. We will have to see.
Old 09-22-2007, 12:30 PM   #117
_
The 701 is a great piece, don't get me wrong, but the 701 does have a number of issues...we're running into them currently and it's limiting our ability to get the most out of our system.
This is why the 701 is in the price point that it's in...adn why Alpine makes the F#1 processors...because the 701 has some limitations...
A properly set-up system, with EQ points done correctly, won't need much EQing at all...mostly to firm up imiging and to work out some minor issues with tonality.
The sound card he's using also has replacable opamps, something the alpine doesn't have....
I've thought about sending in my 701 to have it reworked and upgraded in various ways...but I think it would be just as good to implement tuning on the PC.
Jan Bennett
Old 09-22-2007, 12:34 PM   #118
_
REALLY annoying isn't it?
everything I've ever heard about Behringer equipment is that it's mediocre at best....which after asking some of my buddies that have been doing studio recording for some time now confirmed...
If USACi finals wasn't the same weekend, I would have gotten points to go to MECA finals this year....maybe next year Ralph won't drag his feet on setting a date for USACi finals...
Jan Bennett
Old 09-22-2007, 01:24 PM   #119
Car Audio Moderator
durwood's Avatar
Yes it is!
Ya I wouldn't expect super amazing sound, but it does use some decent quality stuff and I've heard the suer interface is easier to use than the alpine. Apparently, the biggest mod that really helps is an upgraded output board that swaps out the 4580 opamps and does some other things as well. ezaudio is also thinking of developing an upgraded output board that would also tie in a remote mounted volume control. he recently started a thread about that on DIYMA as well.
Well from what I read a while ago, having uasc finals on the same date this year is really screwing MECA too. Last I read MECA couldn't get any sponsers because of the date conflict and the cost was going to be driven up because of it. I have to go check to see if that is still the case.
Edit: Here it is:
Quote:
I've rented 2 buildings for SPL vehicles. All vehicles will have to be pushed into and out of the lanes. All Fire Marshall laws will be enforced, so that will cost us more, since we have to have a Fire Marshall on-site, and our vehicles and the way we do things will be under more scrutiny than any previous event.
The cost of entry fees are going up, for sure, and will be $150 for SPL and Drive-by SPL Parade. If you qualify for both, there's no extra fee.
The same for SQL entries: $150 fee for SQ, Install, and RTA Freq Out, with proper qualification.
I am working on a discount for those members who do both.
I'm sorry that anyone who competed in previous Finals Soundfests feels crapped on or 2nd rate. That was not intentional. I am working to make everyone feel as comfortable, equal, and satisfied as possible, as always.
Spectators will have a more difficult time seeing the action, but we will try to give them a good viewing area.
Get ready to push
BTW, at this time there are no sponsors for this event. I have been working since May to try to secure sponsors. There is a conflict in the 12-volt industry schedule now with USACi doing their event on the same weekend, and we are getting the short end of the stick....actually, at this time no stick.
Given that fact, I am working harder than ever to find a sponsor, or sponsors, for our event.
There is still plenty of time to compete and qualify for our Finals Soundfest, and it is not too late to add event to the Event Schedule.
Old 09-22-2007, 01:37 PM   #120
_
Yeah - Ralph is falling back on the excuse that USACi finals has always been on that weekend...but it doesn't change the fact that he drug his feet setting the date...
I think in the long run, everyone looses.
Jan Bennett
Sound quality of running 3.5mm into RCA and then outputting to subs? AznArkitekt Car Audio 5 10-12-2006 11:25 AM
RC3 Sound QUality justintime Centrafuse 24 09-23-2006 10:17 PM
VIA and Mini-box Announce First Sub-$300 Car PC Kit Goofus General Hardware Discussion 27 03-13-2006 12:28 PM
Sound Quality? nettech_gt General MP3Car Discussion 3 07-21-2005 03:48 PM
sound quality of wafer 7850 ? krazy General Hardware Discussion 5 07-08-2002 06:48 AM
