Finished this up last week (well almost finished), I have been working on this since Thanksgiving. School, work, kids, and wife were the only things that slowed me down
Price list -
Screen and housing ~400 Ebay
Mac Mini - 400 craiglist
Now upgraded to a dual core 1.66, 2gb 667Mhz ram 160gb Seagate hard drive
Pac AAI NIS2 (Satellite to RCA inputs) - ~85 Don't remember
L.O.C. ~20 Ckt City
VGA to RCA converter - ~35 Ebay
eDi 6500's Already owned
eD Nine.1 amp - Already owned
eD 13ov.2 x2 already owned, second one is waiting for a box.
The Car
To take the head unit out follow these directions that were made by someone else
05-06
http://www.psedog.com/G35/G35ScreenH...stallGuide.doc
03-04
The one for the 05-06 is missing a step, you have to pull of the panels next to your shifter/radio, they are a pain to get out, you have to yank it out starting from the bottom rear and work your way up.
Here is the IR for the remote. I put it right next to the Passenger air bag light. The flash really makes it stand out, but under normal lighting you can't see it.
First test fit
In order to run the 4 gauge cable for the sub amp, I drilled a hole in the firewall (5/8" drill bit), put some touch up paint in the hole, and installed the grommet/cable.
Screen Power Cable. Having a cable plugged in to the cigarette lighter at all times is not the look that I'm going for, so I soldered it.
Power supply for the Mini, directly under the head unit (Radio).
Around the forums I have seen some mis information about the coloring of the Rear speaker wires from the head unit. Here is a picture of mine (06 AT)
yellow and black = left ground Teal = left +
Pink and Black = Right ground Orangeish red = Right +
My L.O.C. wasn't going to fit behind the radio with the case still attached, so I took it apart and wrapped it in electrical tape to keep it from shorting out on anything
More to come, MP3car has a 15 pic limit, but they aren't even hosting the pictures, I am.
Edit:
New custom sub boxes
