03-20-2007, 02:58 PM
#136
Quote: Originally Posted by IC-C30
but USB2 has greater bandwith....
The eternal debate of big numbers
In one corner USB2 = 480 and in the other Firewire 400 = 400
Now have you ever scored harddisk test of real wolrd throughput and you'll understand what I mean
Further don't forget that the big pusher of USB2 is Intel you know the guys that were telling and selling for years that only MHz counted
They are now in a position where they have completely obliterated that concept as to go in the direction of power to Watt ratio (incidently it is a selling factor :economy of energy)
Forget USB and given the choice of Firewire take it you'll be glad
Music is not only throughput but also timing and that is another matter and here the OS is also playing a big role (latency etc ...)
03-20-2007, 03:08 PM
#137
_
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
Quote: Originally Posted by SKiTLz
Whats with the terminal strip on the OPUS casing? Are you not using the 6pin Molex on the rear side?
Just curious what those wires are?
Cheers
It's so that the case can easily be removed. The wires there are 2 for the case fan (it's connected to a switch at the front of the car so that it can be turned off while being judged) and the other two are to the reset button that's in the glovebox.
I'm not using the 6pin molex on the side either as I'm running the DSATX PSU. The 150 watt PSU that comes in the case isn't big enough for this PC and I wanted the features that the DSATX offers.
Jan Bennett
Centrafuse Support
04-14-2007, 08:18 PM
#138
Vehicle: 2000 Honda Accord LX
are the 5" Focal Be Midbass or sub?..i noticed you said sub, but i wasnt sure.
04-14-2007, 09:01 PM
#139
_
sub...
they play down to about 40Hz
Jan Bennett
Centrafuse Support
04-15-2007, 02:56 PM
#140
Vehicle: 99 Trans Am
Is it a Be? I thought they only made one 5" sub and it was the 13KS.
04-15-2007, 10:21 PM
#141
_
Yes, they are Bes.
They make a Kevlar 5" sun and a Be 5" sub.
It's the 13ws.
Jan Bennett
Centrafuse Support
04-16-2007, 06:12 PM
#142
Tasty install. I like how you welded the panels for the 5" in the kicks, nobody be stealing that.
ps: LMK about the STEC amps when you can
04-16-2007, 09:11 PM
#143
_
Thanks for reminding me, been a busy day. I'll check into it tonight.
Jan Bennett
Centrafuse Support
05-02-2007, 08:24 AM
#144
Vehicle: 96 Dodge Ram 2500 Cummins Diesel (turned up)
Wow Red, I didn't realize you were that hardcore!
Nice project!
Where did you get those fuse boxes?
05-02-2007, 08:38 AM
#145
_
Ordered them online somewhere....this isn't the place, but it's the same:
http://www.americanautowire.com/prod...ccessories.cfm
ooo...they are 'spensive there!
www.wiringproducts.com
That's where we bought them from.
Jan Bennett
Centrafuse Support
06-15-2007, 12:42 AM
#146
Vehicle: 1992/Subaru/Liberty
Any updates?
Red,
Any updates on this? I've just gotten my PC working in the car, and I was curious as to how I can increase the quality and pre-out voltage.
06-15-2007, 06:46 AM
#147
_
I'm still working with the Alpine.
With everything we've got going on, I've not had the time that's needed to devote to this.
I'm actually looking for a PXA-H900 to replace the 701 with.
I'm not sure what you're asking about increasing the quality and pre-out voltages on?
Jan Bennett
Centrafuse Support
06-15-2007, 08:18 AM
#148
Did you give up on using the mutiple DAC's like the Hippos straight from the PC?
What things do you have going on?
06-15-2007, 08:21 AM
#149
_
No - still with the optical out of the mobo to the alpine.
Work and building a house are taking up most of our time right now.
My husband is starting a new job as well next week.
Jan Bennett
Centrafuse Support
07-06-2007, 06:48 AM
#150
Vehicle: 06 Cobalt SS Supercharged
desoldered the 1/8", solder on wire to the ports on the boards then solder the other ends of the wires to the RCA sockets. Done.
As for mounting the RCA ends...am wiaiting to figure out where I'm going to be putting this PC in the GTi and if I'm going ot be using a case, etc.
i never thought of that but could that be done for pretty much any soundcard?
| Thread Tools |
| Display Modes |
Linear Mode
