The MP3car.com Store
Go Back   MP3Car.com > General > Show off your project > Worklogs
Thread Tools Display Modes
Old 02-26-2007, 04:24 PM   #106
_
RedGTiVR6's CarPC Specs
RedGTiVR6's Avatar
Vehicle: VW GTi VR6 / Ducati 900 SS & S4R / Dakota R/T Supercharged
My Photos: (73)
Matrix:
The mid range and the mid bass are running a 4 wire twist. The issue here was mostly due to size. Using this method we're able to effectively use a larger gauge wire (when you combine the two) in an area or a screw terminal where we wouldn't be able to use a larger gauge otherwise.
mezz: www.wiringproducts.com
Hope that helps!
Jan Bennett
Centrafuse Support
RedGTiVR6 is offline   Reply With Quote
Sponsored Links
Old 02-26-2007, 04:32 PM   #107
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
Cool thanks.
Really really nice work there
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 02-26-2007, 08:00 PM   #108
JasonWW's CarPC Specs
Vehicle: 99 Trans Am
My Photos: (0)
The only thing that kind of looks off is the bolts on the 5". Are you going to replace them with something nicer like button heads or something?
Everything else is
1999 Black Pontiac Trans Am
CarPC's in F-bodies
How to tune your sound system
How To Relocate Climate Controls on the 97-02 F-body Cars
(AMD Sempron 3000+, Opus 150)
Car PC system is out, Alpine system is in.
JasonWW is offline   Reply With Quote
Old 02-27-2007, 07:07 AM   #109
_
RedGTiVR6's Avatar
My Photos: (73)
Nope - those are stainless cap head screws.
When the grills on the 5s are removed, you'll find that the screws used to hold the 5s in place are the same...cap heads. Only they have a groove in them to hold the grill in place. We used the cap heads in the back on the amp rack, to hold the computer in and on the fuse pannel under the hood. Same thing with the battery bracket.
It's a theme, carried throughout the car.
Oh yeah, it's the same screw used to hold the tweeter and 3" in place and it also holds the grills on those.
Jan Bennett
Centrafuse Support
Old 02-27-2007, 07:02 PM   #110
My Photos: (0)
The pic is kind of small, so I couldn't really tell. Maybe it's the color that stands out from the black?
CarPC's in F-bodies
Sponsored Links
Old 02-27-2007, 08:44 PM   #111
Ruffy's CarPC Specs
Ruffy's Avatar
Vehicle: 2000/Chrysler/300M
My Photos: (0)
can you explain what all the fuses are going to?
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 02-28-2007, 08:57 AM   #112
_
RedGTiVR6's Avatar
My Photos: (73)
From left to right:
accessory ground
+5v lead (from PC - for USB hub and CD player)
+12v lead (
remote turn on fusing (sub amp)
remote turn on fusing (mid-bass amp)
remote turn on fusing (mid-range and tweeter amp)
Remote turn on fusing (Alpine processor)
Lighting
Processor
Processor
Ignition
Constant
Jan Bennett
Centrafuse Support
Old 03-06-2007, 03:38 PM   #113
mikevsgeek's CarPC Specs
mikevsgeek's Avatar
Vehicle: 2001 Jeep Wrangler
My Photos: (0)
Quote: Originally Posted by RedGTiVR6 View Post
Modfying the sound card:
what type of connectors are those?
mikevsgeek is offline   Reply With Quote
Old 03-06-2007, 03:43 PM   #114
_
RedGTiVR6's Avatar
My Photos: (73)
you know, I don't remember the name of them, I just went down the isle at Fry's and had my card with me...
Jan Bennett
Centrafuse Support
Old 03-06-2007, 03:46 PM   #115
mikevsgeek's Avatar
My Photos: (0)
d*mn you're quick!! I they kind of look like the connectors from a 4pin power molex out of a computer but I don't think the pin from one of those would fit through the PCB like that.. did you solder the speaker wire directly to those pins or did you crimp them?
Old 03-06-2007, 03:54 PM   #116
_
RedGTiVR6's Avatar
My Photos: (73)
both.
Jan Bennett
Centrafuse Support
Old 03-07-2007, 10:06 AM   #117
mikevsgeek's Avatar
My Photos: (0)
both.
I am modding a sb live to use RCA outputs to eliminate the 3.5" to rca cables I use, and you mentioned that the 5th pin on the stereo outputs is to be ignored. I am finding that unless that 5th pin is grounded to one of the line grounds that the output from that "jack" is very low.
Did you have that issue?
Old 03-07-2007, 11:51 AM   #118
_
RedGTiVR6's Avatar
My Photos: (73)
not using it yet. Still on the Alpine right now.
Jan Bennett
Centrafuse Support
Old 03-07-2007, 05:27 PM   #119
mikevsgeek's Avatar
My Photos: (0)
you might want to test it on a separate machine before you get everything put together and tucked away... that would suck
Old 03-07-2007, 05:29 PM   #120
_
RedGTiVR6's Avatar
My Photos: (73)
already put in the car. that's why I've made it so that the enclosure can be easily removed.
I've been reading a few threads on other forums about the card that's making me think about switching to a USB or FireWire solution anyways, or making the switch back to the 1/8" splitters and having a custom, high end 1/8" splitter made that meets our expectations in terms of quality.
Jan Bennett
Centrafuse Support
Sponsored Links
vB code is On
Trackbacks are Off
MP3Car CarPC State of the Union 2006 SwapMeet General MP3Car Discussion 30 10-18-2006 08:32 PM
carpc with name brand monitor fasteddie Input Devices 5 08-25-2006 07:09 AM
CarPC audio problems aal2000 Car Audio 2 09-07-2005 08:40 PM
Will I lose sound quality going to a Carpc with my Quality System? ddotderek Car Audio 34 09-01-2005 04:14 PM
Loud noice when turning on CarPC Andreas106rally Car Audio 4 11-03-2004 11:27 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
