Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 02-20-2007, 06:46 AM   #16
tigergibb's Avatar
tigergibb is an unknown quantity at this point
Ah, okay. I'm not quite sure what to do with my hazard light switch yet. I am still fixing all the bugs with the software. The only problem I have now is that the Power Switch won't shut down the computer. It doesn't work with WinLogon or MinLogon and I'm not quite sure why.
2003 Nissan Xterra Worklog
Total amount spent so far: $1196.64
You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
2003 Nissan Xterra - Modifications
tigergibb is offline   Reply With Quote
Old 02-26-2007, 12:17 PM   #17
tigergibb's Avatar
I finally got the power switch working with the WinLogon. WinLogon is taking the exact same time to bootup as MinLogon did so I'm just going to use WinLogon.
Motherboard(VIA EPIA-CN13000G) and Power Supply(M2-ATX) Mounted to Plexiglass with #6-32 x 1" Zinc Machine Screws and #6 Spacers. The Screws came with the nuts we needed in the package already. We had to predrill holes in the Plexiglass to get the screws in.
It fits very nicely in my glovebox. There's room to spare too .
Old 03-03-2007, 05:05 PM   #18
tigergibb's Avatar
The lilliput bezel was stuck to the dash peice with superglue and held for about 60 seconds. It was then clamped down. We then expoxied the bezel to the dash peice and left it for a few hours to cure.
It stuck in perfectly behind the dash peice... no sanding or anything was needed.
Old 03-03-2007, 05:20 PM   #19
esachs's Avatar
esachs is an unknown quantity at this point
looks nice..... keep up the good work!
esachs is offline   Reply With Quote
Old 03-04-2007, 09:41 PM   #20
tigergibb's Avatar
Boxes were cut out of 1/4" MDF for the Slot-Load DVD-ROM/CDRW and the Fan controllor. The slot load was two peices of 5"x5" and two peices of 1"x5". Gorilla glue was used to hold them together.
This drive is removable. The box was built before it was stuck in there, so it can be pulled in and out if needed at a later time.
The fan controllor was just glued in there. The peices of MDF were glued around it and it won't come out now, but that's fine.
Here's them after the glue cured:
Old 03-08-2007, 06:44 AM   #21
tigergibb's Avatar
I sanded off the top of 6 of my Blue 5000-7000mcd LEDs so when they shine down from the top of my glovebox the light spreads out. If I didn't sand the tops off, the light would be uneven with bright spots right under the LEDs.
Old 03-13-2007, 10:36 PM   #22
tigergibb's Avatar
An angle grinder was used to cut the middle hazard light piece to fit back into the dash. It is not secured with anything yet. We cut off the tabs that secured it earlier, thinking we would put the CD-RW/DVD-ROM there. The plans changed, so now we will have to Epoxy it in too. Putty will fill in the cracks/gaps and smooth everything out later.
The cubby in the bottom was screwed back in for test fitting.
Old 03-24-2007, 06:19 PM   #23
tigergibb's Avatar
The screen was held in with Epoxy. It broke and fell out while we were messing with it. I would not recommend using Epoxy for ABS at all. To fix that, we bought this stuff at Wal-mart called "Plastic Weld." It works much, much better. Everything seems to be held in solid. You can also glob it in around the back of everything for extra support.
We bought some 3M Putty and Hardener to start making everything look flush.
We also started sanding some of it... it looks as though this will take a lot of sanding to finish.
Old 03-26-2007, 11:16 AM   #24
tigergibb's Avatar
The LEDs in the glovebox will be wired as follows:
There will be two paralell circuits. Each paralell circuit will be wired with a series of 3 LEDs. This is a total of 6 Blue LEDs. They will come on as soon as the glovebox is opened and turn off as soon as it closes. To simplify this, I bought a refrigerator switch.
If you are thinking about doing something like this... if you want the circuit to close(on) when the button is not pushed and the circuit to open(off) when the button is pushed, you want a normally-closed momentary switch.
Old 04-16-2007, 08:14 PM   #25
tigergibb's Avatar
I haven't updated this in awhile so here's what I've been doing lately:
We wired all 6 LED's... The connectors at the top left plug into the refrigerator switch.
A hole was drilled in the back of the glovebox and the refrigerator switch was put in.
We used some very strong Scotch-brand tape to stick the Plexiglass with the computer to the glovebox. I then proceeded to wire everything in there. When the glovebox opens, the lights turns on. When it closes, the lights turn off.
The case fan was screwed in with four 1 & 1/4" screws. We drilled holes for the air flow. In the top right, you can see where we drilled the holes in the glovebox and put the LEDs in.
We soldered the M-Size Barrel Plug to the Yellow(+12v) and Black(-12v) wires on the power supply. The outside is negative and the inside is positive. This will plug into the lilliput to power it.
We had to extend eight wires to go to the front to power the DVD-ROM drive and Fan Controllor. Here's the picture of one of the connectors extended:
We brought a 12V battery in the house to test everything and it works great .
Old 04-16-2007, 08:30 PM   #26
tigergibb's Avatar
We spent quite a bit of time adding more putty and sanding it off. Here's what it looks like as of now(we still have some work to do):
Old 04-24-2007, 11:09 AM   #27
tigergibb's Avatar
Well, we finished sanding it. At first we tried using Krylon Fusion Satin Black No-prep paint, but it looked horrible. It was way too shiny, so we sanded it off. We then primed it using Krylon sandable primer and sanded the whole thing down a couple times. We then painted it with Krylon Ultra-Flat black paint. After that was completely dry, we put the boxes for the fan controller and the DVD-ROM/CD-RW drive in the cubby and used the "Great Stuff" expandable foam to get them to stay. We will have a faceplate made out of wood for those. There are a few imperfections, but I can live with those. Overall, I think it looks great, especially for it being our first time doing this.
The paint seems to be VERY easy to scratch, so we are going to coat it with some sort of Matte spray protective coating.
Old 04-26-2007, 09:44 PM   #28
tigergibb's Avatar
On the RadioShark, we soldered the FM Antenna to a copper wire, which was connected to the solderless inline motorla jack from RadioShack. The FM Antenna is the one closest to the edge of the case. It is labled "FM" on the circuit board. I don't use AM Radio, so I didn't even bother with it. When we were done, we routed the wire out of the bottom where the hole was from the screw and put the RadioShark back together.
To open the RadioShark: There's a screw hidden on the bottom of the base. I used a knife to tear up the bottom part to access the screw. It's under one of the f's in the word Griffin. Then you have to unscrew and remove the base. After that, I set it flat on the counter and put the knife in the hole where the screw was and pushed upwards to start seperating the case. I then put a credit card in and started moving around it prying it apart.
I have not tested this in the car yet, but on my desk, the RadioShark used to get kind of staticy, especially if I moved it. Now, with this external antenna, the reception is crystal clear. I think it will be great when I plug it into the car's antenna.
Old 04-29-2007, 09:23 PM   #29
tigergibb's Avatar
We wired the amp up to the speakers and wired it to the battery. I wrapped the power wire in black loom tubing. The amp is located under the passenger seat.
Old 05-03-2007, 10:41 AM   #30
tigergibb's Avatar
Well, we got everything in, but we still have some work to do.
The bottom right button for the lilliput is stuck in, so the screen brightness keeps changing and the touchscreen doesn't always work as it should, especially when it's cold. We are going to have to drill that out some.
Off
Main Screen
Navi
GPS Gauges
Radio
We still need to have the faceplate for the drives fabricated. We can't decide if we want to have it be staind wood or just paint it black to match yet.
2003 nissan altima trunk adapter? gameboy Newbie 12 08-12-2009 09:55 AM
2003 Nissan Altima Custom Liliput Dash CJ8501 Fabrication 25 05-08-2008 12:37 AM
2003 nissan altima gameboy Newbie 8 11-28-2006 09:25 PM
2003 Nissan 350Z CarPC paulpv Show off your project 39 04-29-2005 04:46 AM
Nissan Xterra XPuter Stage 1 OKC-X Show off your project 10 04-02-2003 12:00 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
