Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 04-22-2007, 04:16 PM   #31
mwmcginn's Avatar
mwmcginn is an unknown quantity at this point
Its really easy to take out, First fold down the seatback, remove the two bolts from the hinge to the seatback. Take the seatback out.
Remove the one or two bolts towards the rear of the car (leave the seatbelts alone)
Pull out the T shaped clips on the bottom of the seat (towards the front of the car) and you should be set.
Mike M
2006 Accord VP Sedan
My worklog
http://www.mp3car.com/vbulletin/work...-dads-car.html
mwmcginn is offline   Reply With Quote
Old 04-23-2007, 04:59 PM   #32
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
Quote: Originally Posted by scott_fx View Post
looking good man, I agree with you, keep it simple if you can't devot the time. I dunno about everyone else but i'd much rather spend time with a newborn daughter then in the garage molding a screen in my dash
scott make a very good point. Spend time with your new born instead of staying in the garage sanding off bondo.
mwmcginn great job you did mate. Simple and effective. Now aday, I don't see the point of having the screen fab into the dask kit. If you do it right, it look just as good as anyother "built in" fab which you did a very good job.
When I did my Matrix, I was hurry to finish before my little boy is born cuz I want to spend time with him.
Now when I redo my Supra, I have to go the easy route cuz I have no time. I was able to do the Supra job only when my little boy sleep, or not at home. Imagine you son imitated almost every step you did as he almost used a screw driver and screwing into the car No, he did want to play with his toy, instead he uses my toys.
My next project is the 2K Accord so I can alternate with the Matrix for long trip. I'll go exact same route you did. Work on the lcd bezel and attach to the factory piece. No sanding, nothing to be done with the factory bezel exept the back side which will be couple drops of epxy and/or supporting brackets.
Enjoy the baby man, once she grow up, you won't be able to hold her with just 1 arm. My boy (18months) already don't want me to hold him, he wants to run.
Welcome to the day of no more 2 seaters, sport car, autocross, crazy sound. Say hello to a smooth, quiet driving sedan .
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 05-23-2007, 10:04 AM   #33
buggout is an unknown quantity at this point
hey, did u find a hole to feed the power wire thru in the firewall? or did you drill one....? nice install btw..
buggout is offline   Reply With Quote
Old 05-23-2007, 09:07 PM   #34
mwmcginn's Avatar
Yeah, I took it out next to the factory harness next to the drivers foot area. There is a tight loom of wires going through a wide rubber grommet thing. I punched a small hole next to that in the grommet, and pushed the wire right through. It worked very well. Some others use one that is behind the center stack, and they say it is better. This worked for me though.
Mike M
My worklog
Old 12-05-2008, 09:56 AM   #35
jassimann is an unknown quantity at this point
nice
Hello i have 2003 honda accord .can you explain how you use the power for laptop and monitor
jassimann is offline   Reply With Quote
Old 04-11-2009, 03:56 AM   #36
Ironprophet is an unknown quantity at this point
Mounting Bracket?
Quote: Originally Posted by mwmcginn View Post
Here is the match up of the screen to the Honda attachment kit.
What that attachment called? I think I want to order one like this. Also, I was wondering if a screen could be mounted inside the cubby-hole so the flap could cover it?
Ironprophet is offline   Reply With Quote
Old 04-17-2009, 08:33 AM   #37
mwmcginn's Avatar
Its a mount kit for their tape, mp3 player, or 6 disc in dash player.
Mike M
My worklog
What's your dream car? Aaron Cake Off Topic 172 10-02-2007 08:34 AM
$15k damaged caused because of a "joy ride" Tx_Cat Off Topic 12 12-29-2006 07:09 PM
New to CarPCs? Don't know where to start? RedGTiVR6 Newbie 12 06-15-2006 11:08 AM
Car Stereo Installation Video's for Sale johnram Classified Archive 2 09-05-2002 11:27 PM
