======================== UPDATES 20/01/2009 ========================
New CarPC: No pictures yet, will try to update soon
HID Retrofit at Post #55:
http://www.mp3car.com/vbulletin/1285183-post55.html
======================== OLDER 24/02/2007========================
Ok, just got back from Denver area where a fellow mp3car member GoHybrid helped me out with my screen bezel. (Thanks man!)
I built the case all myself before hand using a 30W laser cutter and 4 sheets of acrylic. As of now, it is not finished. My plans are to buy some electroluminescent strips or pads in blue, and glue them between the black opaque 3mm bottom and the 3mm clear right above it. That way the entire clear section glows blue, and not just spotty like using LED's.
Still a work in progress.
So here is a picture filled worklog...
EDIT: So many pictures, so little bandwith...
If the pictures don't show up then refresh. If they load slowly, it is because they are on a computer with a processor that is over half my age old. 300Mhz with 16Mb of RAM, and a slow crappy cable connection. And I can't upload to imageshack because there are so many and I don't have that time. And it wont take any of the zip files I try, so yeah... Sorry.
EDIT #2: Ok, I got all the pictures on Imageshack's servers now and my router has finally calmed down from blinking the crazy light. It was going pretty fast for a while there! So enjoy!
EDIT #3: You need a computer with at least 1Gb of RAM or a pagefile of 1Gb to view this thread happily. Who doesn't have a 1Gb nowadays anyways?!
EDIT#4: Disregard #3. I updated the pics to be thumbnails so hopefully that lowers the strain on your computers. As always, any opinions (good or bad) are appreciated. Thanks for looking!
Case:
Here is the case sprawled out after being cut. The big hole in the back is obviously for the back panel connectors.
You can see the hard drive stands here for the 3.5" and 2.5" drives.
Here you can see the holes for the M2-ATX. There are 4 holes because I was going to put power, ignition, and ground in 3 of the holes, and then all the others like power switch and remote lead and sirius connector out the fourth. But Then I decided against that and just shoved crap out the holes as it fit!
And you can see how shiny the plastic is, because yoiu can see the clear piece in this piece's refelction.
Here are the fan grills close up.
My brand spankin' new 2.5" laptop drive. 60Gb. I am going to use this to store the OS, and then the 3.5" for the media. The 3.5" has developed some bad sectors over the past year, so I hope the 2.5" will hold up better.
