Go Back   MP3Car.com > General > Show off your project > Worklogs
Old 02-28-2007, 02:09 PM   #1
rijk is an unknown quantity at this point
cpc in volvo 440
Hi, my name is Rijk.
I discovered the cpc-concept 1 year ago, and am a member of the Dutch carputer-forum site (username dash), where i got most of the info i needed.
That username was already taken, so i use my own name
What i have done so far are to the cpc project:
- wiring in the car
- second amp underneath the passenger seat
- upgraded the front compo set
- gsp receiver mounted in the sunroof
- case of cpc
- mounting-position for the cpc case
- dvd-rom + usb mounted in glove-box
- moveable screen (self made) in the center console
- mounting cpc in the car
- mounting the new center console in the car
to do:
- software, front-end, etc.
- finish up the wiring cpc to car
- ad tv
- move antena of wifi to teh sunroof
- solve problem with powersupply (dsx12vd)
i am now looking at RR as a skin, because i have the hcq-radio unit
I wont show it in working order, because i made te screen part first, took about half a year, so best for last.
Concept of the project, facterylook and being able to park it in the city without worrys. so hide away is the name of the game
Thirst the wiring of the cpc
The position of the cpc wil be in the front of the car, for max cooling and now noice in the car.
The cpc wil be started bij the remote controle (alarm) with a bi-stabiel relais.
rijk is offline   Reply With Quote
Old 04-02-2007, 02:23 PM   #2
The mobo in the case, m2 will fit in the left part.
Case is gone be mounted upside down..
Aluminium brackets are for fixing it to the car.
Old 04-02-2007, 03:38 PM   #3
the screen arrea:
Old 04-02-2007, 04:08 PM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
sweet! You finish the screen yet?
Old 04-02-2007, 04:23 PM   #5
yes, but when the mobo came back, (no sound at all) the screen had strange spots on it:
i'll look up the picture for you
i have send it back, januari and its stil not back. But the screen movies nice, open and close at the turn of the ignition, so nothing to see in the car
Old 07-09-2007, 05:03 PM   #6
Here is the screen in action:
Home made motorized TFT-screen
You need to upgrade your Flash Player
(oh, it is not an Opel)
The shelf where the screen hides under is standard, so in the closed position you have the factory look
due to the heavy screen the gearratio was changed from a 15 to a 20 t
also the hole of the vga kabel was inlarged to take the movement.
with mod., extra ball bearing en shaft on the engin to change the load of the engine (black shaft).
Old 01-08-2008, 12:11 PM   #7
I had the cpc mounted on the air-intake of the interieur of the car, but its to cold.
Brainstem showed +5° and a minut later the cpc was off.
So a new position needs to be found.
moveable screen close-up
Air intake frame standard (left) and mod. The hols ar for nuts and bolts. If you life in a warm climate min tep ca 5° This is an ideal place to put your mobo, now noise and a lot of couling from the air passing by into the interieur of the car
Cpc was mounted under the black cover on the left
close up cpc (changed the case to a closed type aluminium)
Old 03-03-2008, 02:14 PM   #8
the U-braked for the screen:
Old 03-21-2008, 09:44 AM   #9
gps recever: in the sunroof.
the sunroof has an "inside cover" or whatever you call it, so nothing to see from the inside or outside.
Old 04-02-2008, 01:02 PM   #10
I am getting pm's for the screen area, so i'll try to anser the questions here:
The parts:
- The aluminium frame was made by myself (aluminium frame, etc.)
- the parts i bought were from conrad: www.conrad.nl in the search (zoeken) type: "tandriem" and "tandriemwiel"
- for the motor: type servo , than select (sorteren: prijs oplopend)
(servo is for a sailboot) the one i used isn't there anymore, but you want one with high torque (130Ncm), you can create more torque bij using bigger "tandriemwiels"
You want to do this, because otherwise the screen wil move to fast.
You need to modify the servo, so it works as an engin, take out the electronica
- the servo needs to be powerd with maximum 6 volts, i used a 5 volt line of the m2 / mobo
- 2 switches (to start and stop).
- a couple of magnats (for fixing the closed and opend position)
hope this gets you started in the right direction.
Making a moveable screen is a lot of work, so be sure you got the time for it.
Old 04-02-2008, 01:10 PM   #11
How to work:
- find a place for your screen.
- measure the area around the screen twice!!!
- decide how you want your screen to move.
- draw the hole area including the area needed for the moving screen.
- leave margen so you can adjust the positions.
Old 04-02-2008, 01:16 PM   #12
How the screen moves:
We can break this down in two parts:
- mechanical
- electric’s
mechanical:
- the engine powers a drive-belt, which rotates an axle. On that axle there are two aluminium L-brackets
- the L brackets control the switches.
- The movement of the second axle is transported via a belt to the top axle.
- The top axle rotates the screen
- magnets keep the screen in the closed or opened position.
Electric’s:
- needed:
- 2 switches
- 1 modified sailboat-servo
- 1 relays
On the relays you connect the + and – of a 5 volt line (i used m2)
The relays has 2 outs on each connection!
To the servo 4 wires will go from the serve.
In the two + wires that go to the servo there is a switch.
When the switch is pressed, the connection is broken and the servo stops moving.
The relays is controlled by the + of the ignition key, but that can be every other switchable +.
on the picture at the buttom the switches (black) with the magnets
close-up of the relays and servo (tape is to reduce the force of the magnet, not to hold it in place)
Old 04-02-2008, 05:59 PM   #13
zagato is an unknown quantity at this point
I would like to know what went in the manufacturing of the mechanism, and also how it's all put together....
zagato is offline   Reply With Quote
Old 04-03-2008, 03:48 PM   #14
updated mecanical part, hope it answerd your question
Old 11-09-2008, 12:24 PM   #15
moved the cpc to the inside of the car, thought that would solve the cold weather problem i had. But it didn't.
old instal under the seat:
the old tray in the car:
A new mobo was order, the dg45fc (intel) testing and install in progress.
2005 Volvo S60 1,3 GHz 120 Kw cala Show off your project 42 02-21-2009 09:26 AM
** Volvo C70 SC-805 Head Unit & AUX In ** billyb0b General Hardware Discussion 5 02-13-2007 01:04 AM
Volvo V40 2002 Rik Engine Management, OBD-II, Engine Diagnostics, etc. 1 12-31-2006 05:41 PM
Volvo S60 in-dash project JC-S60 Fabrication 41 09-10-2005 10:43 PM
Volvo 240 Sedan Questions (Super newbie) gtaubman MacCar 0 06-28-2005 02:25 PM
