very interesting, what is the max output ?
I thought you might enjoy our lastest product, DCDC-USB. (see pictures at http://www.mini-box.com/DCDC-USB). This is good for single rail computers or dumb peripherals.
Accepts any input from 6-34V and outputs regulated 12V (BUCK-BOOST topology). Output can also be set to any voltage ranging from 6 to 24V by changing jumpers.
Sends ON/OFF puse to the M/B. For example, it can be used with the Intel D945GSEJT.
This design is capable of handling large amounts of power, it is based on the LTC3780 BUCK-BOOST circuit. On the USB side it is a 8 bit PIC microcontroler from Microchip.
Since this unit has a MCU on-board, the product can have many personalities, can be used a a programmable PSU, UPS unit, etc, etc. We even have a simple scripting language (not public yet, still working on it)
Best Regards,
-A
2007 Toyota Tundra Double Cab SR5
>"Say what you mean and mean what you say"<
In the manual it states it can be set to 18v. I was wondering if it can produce 18.5V for a laptop application?
Specs say 10A (so prob about 120watts)
openMobile - An open source C# Front End (why choose openMobile?)
- Always Recruiting Developers -
Like what you see? Donations are always welcome
well that makes it an excelent choice to power a laptop, and now that im planning to buy a new mobo in the next couple of days i might even get the zotac a-u instead of the d-e...concidering this PSU, what do you think i should go with ?
andrewb, does this converter operates as an inverter as well ?
if the input is 12VDC, can it output 19VDC ?
Hmmm, could be competition for the Carnetix 2140, one output voltage vs. two, but the price is definitely right.
How about an enclosure?
TruckPC - gutted, being used for test setup
BoatPC - off season - Inelmac screen needs serviced again!
BlazerPC - last vehicle PC I'll build
this looks pretty kick ***.. and not just for carpc's.
does it have timed shutdown ? for example completely cut power from battery a minute after IGN off ?
EDIT: nevermind this post, it does have timing settings
Looking awesome!! will standby mode be possible in the future? because it is a huge bonus!
