Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Kyocera KR1
    Aug 1999
    Washington D.C.
    Kyocera KR1
    I got my hands on a pre-production Kyocera KR1. I did a little write up over at http://www.mp3car.com/vbulletin/general-mp3car-discussion/66078-pandora-streaming-music-kyocera-kr1-evdo-router-test-post704475.html
    It should make my wireless Internet (and GPS tracking) easier and more reliable!
    Now I just need that webcam.
    tz1
    tz1 is offline
    Mar 2006
    Lightbulb KR1 with GPS
    The "diagnostic" port on the KR1 is actually a serial port, and the KR1 itself is a Linux box. I was able to modify the firmware to add gpsd (the standard unix/linux gps server) and connect a standard 4800 baud NMEA GPS unit, so my position goes out over the internet (or wirelessly to my laptop or PDA).
    http://www.evdoforums.com/viewtopic....d30b44edeb785f
    Aug 1999
    Washington D.C.
    Quote Originally Posted by tz1
    That's sweet! Thanks for the tip. I'm going to give it a try on mine.
    tz1
    tz1 is offline
    Mar 2006
    Please wait or PM me if you want to beta test.
    Kyocera/DLink is about to release a major bugfix update to the firmware and I'm not going to make the GPS (plus a few other things) firmware generally available until that release. Kyocera has even suspended shipments.
    When I have a release of enhanced firmware I'll probably post at evdo-info first, and probably here too.
    (If the protocols or other info were available for the other GPS applications, I might be able to integrate support for those too, though I might try a google maps page).
    You can move NMEA over a network connection to a windows serial port with something like:
    http://www.hw-group.com/products/hw_vsp/index_en.html
    so many windows com-port only applications will work.
    Oct 2004
    NY
    tz1, I read the whole thread that you linked in your first post, & I can honestly say that, although I know the language was definatley english, that has the be one of the most un-understood things I have ever read
    I have a kr1 in my car now, & for it to be able to transmit it's location without being dependant on a winxp machine would be awsome, but just from reading that thread I can tell that what you are doing is way beyond my abilities, when the new firmware is out, would you consider doing my router for me? I would ship it to you & I can pay you of course to do this..... this sounds like an awsome security system..... kinda like a your own personal private lojack..., at least this would be my main interest in having this...
    no one else drives my car & I wouldn't want anyone else tracking it.... but if I ever got up one day & the car was gone, I'd be real glad I did this.... I would wire an activated pager to trigger the router to power up so I can call it & power up the router if the ign is off at the time.....
    tz1
    tz1 is offline
    Mar 2006
    Actually you will just have to do the firmware upgrade, but use my image instead of the one from Dlink or Kyocera.
    If you look under the tools browser window, there will be a "firmware" page where you can do the upgrade.
    The cabling might be something harder, but I'll try to come up with an easier solution there - perhaps someone would like to build the USB to DB9 adapter (and you would need a "PC" type GPS that went into a serial port, not USB).
    I currently don't have a password or other protection for the gps, and you would need a dyndns account to get the data from the KR1 since the IP address changes.
    _
    Mar 2004
    Little Elm, Texas
    I'd just like to chime in on this thread.
    How strong is the signal from this unit? How far does it broad cast and would it be possible to add a range booster?
    I'm interested in it for the car when we're on road trips to shows. Usually we're all in a caravan. People in other cars with their laptops would love to be able to access the wireless network I could set-up and check their email briefly. I'm aware that it probably wouldn't be fast enough for multiple people to check graphic intense pages or anything, but enough to keep up on some things and pass the time while driving across the country maybe?
    Also, once you take the board apart, are the PCMCIA slot and the network ports on separate boards or are they all connected on the same board? Would it be possible for me to mount the ports one place and the slot in another?
    also, does anyone know what the wallwart says? does this unit need 5v or 12v or what? Trying to figure out how we're going to wire it up in the car to power it.
    and turbo - I agree, that's one hard thread to follow....in english even!
    Jan Bennett
    Aug 1999
    Washington D.C.
    Quote Originally Posted by Red GTi VR6
    It's average, but to be honest I've never done a distance test. Typically outside of buildings the WiFi signal goes much further. I have mine on the rear deck, and it works well. It has a standard antenna connector so there's no reason why you couldn't connect it to a better antenna mounted externally or add a signal booster.
    _
    Mar 2004
    Little Elm, Texas
    sweet!
    I should be picking one of these up soon then.
    the manaul states 5v 3a for power...so that's possible on the M1!
    Jan Bennett
  1. Pandora (streaming music) + Kyocera KR1 (EVDO router) test
    By Zip-Lock in forum General MP3Car Discussion
    Last Post: 08-19-2008, 11:40 PM
  2. Kyocera KR1 EVDO Router - First Look
    By EVDOguy in forum Wireless Communications
    Last Post: 01-01-2007, 11:28 PM
  3. FS: New VERIZON KYOCERA KOI KX2 phone!
    By baller in forum Classified Archive
    Last Post: 12-01-2005, 03:56 AM
  4. EBAY: Kyocera SE47 Verizon Wireless
    By djXternal in forum Classified Archive
    Last Post: 08-29-2005, 08:52 AM
  5. FS: Kyocera 6035 PalmOS Phone
    By Rafster in forum Classified Archive
    Last Post: 07-04-2005, 10:58 PM
