Results 1 to 10 of 11
Thread: ASIO VST Plug-in Audio Tuning Method
    Car Audio Moderator durwood's Avatar
    Sep 2006
    Chicagoland (St. Charles,IL)
    Discussion thread for ASIO VST Plug-in Audio Tuning Method. If you would like to add a comment, click the Post Reply button
    _
    Mar 2004
    Little Elm, Texas
    Yes! Please discuss!
    Jan Bennett
    Sep 2006
    Console Guide added
    _
    Mar 2004
    Little Elm, Texas
    Sweet!
    Jan Bennett
    Clover Grayscale's Avatar
    May 2004
    Arkansas
    This looks very cool. I've been wanting to time align my system but I don't have a head unit. I might try using that Voxengo Time Delay plugin. Also, does anyone know of any good VST equalizers? And, I've used ASIO4ALL before but not on a EPIA SP-1300. Do you guys think that board will be powerful enough to run EQ and Time Alignment VST plugins? I'm almost positive that board supports 5.1 sound. I have been wayyyy out of the CarPC loop for a while, but I'm just now getting back to installing my PC in my new car, and I just got my sound system installed and waiting for a PC to run it
    CarPC install is starting to come along again...
    Sep 2006
    I think you might be ok running just the EQ and the time delays using the Console program. If you try to use the crossover plugin you will need a new computer. Check out the Wiki because all the software is linked there.
    _
    Mar 2004
    Little Elm, Texas
    There's a full list of plug-ins avaliable here: http://www.mp3car.com/wiki/index.php...g_via_Software
    as well as the thread that started it all here: Software options for Tuning
    Jan Bennett
    Sep 2006
    I FINALLY tested this in my car with all my amps and speakers and such. I took my settings from the Alpine H701 and punched the values into Frequency ALlocator and adjusted the time delays to exactly what I had before. I must say it worked perfectly. Everything appeared to work as it did before. I have used other brands before for time correction and crossovers, and it never seems the same. This seemed accurate in regards to how Alpine does it all. I did not take any measurements but based on subjectively listening to it I was happy. I will have to really sit down and take mroe time to listen to see how this compares. My soundcard voltage is lower then the Alpine so I will need to adjust my gains to allow for 1V input rather than 4V input. Here are my notes/hints/tips:
    1) No turn on noise from what I could tell but this will probably be soundcard related.
    2) Major turn off pop, which of course there is no tweeter protection. So this is BAD, will probably kill tweeters in no time at all. You will have to find a way to turn your amps off before the computer powers off.
    3) Console appeared to hibernate just fine.
    4) If you do a cold boot, don't just put a shortcut to Console in your startup folder since it will not retain your settings when closing it. Instead, save your settings to a file and put a shortcut to that file in your startup folder.
    _
    Mar 2004
    Little Elm, Texas
    #2 is bad...really bad...
    #4 - so then, you have to manually open it up every time you start-up the computer?
    Those are some pretty major issues. Good to hear that it works though! That's at least a step in the right direction!
    Jan Bennett
    Sep 2006
    As far as #2, I talked with my expert installer buddy to come up with a solution.
    My first Idea is to use 2k1toaster's USB relay control board. It would be perfect to fix it I think. It won't turn anything on until computer is on and the software loads up or whatever they are dreaming up to control it. Then, it should turn everything off before there computer shuts off. At least this is what I hope.
    My second idea, or my buddies idea is that he has a two relay solution. The turn part is triggered by 12V (Use 12V from PSU for trigger) and it will turn off when it sees a ground pulse (Use the turn on/turn off pulse/momentary button from the PSU used to turn on off the PC). He is supposed to get me a wiring diagram for it soon. He has used it before for something else and claims it will do what I need it to do.
    As far as #4 this is minor. Console has to run in the background anyway to process the sound. Like I said, it's just a matter of putting a shortcut in the WIndows startup folder just like you would for Frontends, Winamp or whatever else loads up at boot.
  1. Toyota Matrix 2006 Neo Car Audio System
    By tallteleboarder in forum Show off your project
    Last Post: 04-20-2009, 10:25 AM
  2. Software options for Tuning
    By RedGTiVR6 in forum High End Solutions
    Last Post: 01-23-2009, 09:56 AM
  3. Tuning line driver audio levels
    By akula169 in forum Car Audio
    Last Post: 08-21-2006, 11:52 PM
  4. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  5. Connect external audio source to Clarion unit via cd changer plug
    By vpapanik in forum General Hardware Discussion
    Last Post: 09-21-2005, 06:55 PM
