Results 1 to 2 of 2
Thread: Msgsrv32 and shutdown
    Oct 2007
    When I cycle my ignition (from on to off and then on again)and my power supply begins the shut down process and then cancels, I get an error that says “Msgsrv32 an error has occurred in your program. To keep working any way, click ignore and save your work in a new file. To quit this program, click close. You will lose information you entered since your last save.”
    This is a problem for me because I run win amp and control it from a 5 button key pad. I have no way of choosing close or ignore.
    How do I keep from getting this message?
    VoomPC-2
    M1 power supply
    Running 98lite/98se
    Winamp
    No other programs
    Elsewhere
    Go through the event log and try to determine what's causing the MSGSRV32 error and fix that problem. MSGSRV32 is a generic Windoze process that is called by lots of applications.
    Good luck.
    How about the Wiki?
