Page 2 of 10 FirstFirst 12345678910 LastLast
Results 11 to 20 of 99
Thread: Windows Mobile Phone Control
  1. #11
    Feb 2007
    Quote Originally Posted by goosey2099 View Post
    Hmmm, very nice idea. Now if we can only remove the actual screen that would solve all the problems
    Why would removing the screen solve all the problems?
  2. #12
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Subscribed. I use WM 6.1 on my Blackjack. Looks like a good phone solution.
    Edit* Up and running, perfect app to integrate wm phone to RR. Thank you for sharing.
  3. #13
    Constant Bitrate aperali's Avatar
    Aug 2007
    Rio de Janeiro, Brazil
    On Mtux manual says "Doesn't Work: ActiveSync Via Bluetooth (WM 5.0/WM 6.0)". It'll only works on wifi or cabled connection!
    How do you are using it?
  4. #14
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Cable connection, then use Bluetooth to headset or other device.
    Another question: Anyone figure out how to map the Speakerphone button on the phone? My Mot Q9h has such a button and I'd like to activate it with the touchscreen rather than fumble to press the button on the phone.
    Z
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  5. #15
    Constant Bitrate smp4488's Avatar
    Oct 2007
    Louisville, KY
    If this worked over BT my life would be complete.
  6. #16
    Aug 2007
  7. #17
    May 2007
    looks interesting but not exactly what I wanted. Hmm.
  8. #18
    Nov 2008
    great program.
    can i use a bluetooth headset as the mic and the car speakers as the speaker?
    also, long shot, but would it connect with my blackberry bold? jus to make and receive calls
  9. #19
    Jan 2008
    My mobiler Embedded in Road Runner BMW E46 italian version
    Hi all!
    I've modified my mobiler own skin to fit in road runner, Robby BMW version (E46)
    I've seen that all commands that my mobiler send to the mobile are in english, so it does'nt work at all for the other languages systems.
    for example:
    the command "messaging" work in the italian version mobiles only if translated in "messaggi" and so on...
    Anyway after a lot of testing ('cause i'm a newbie) i've modified the package for the community (expecially for the BMWers one)
    just substitute the "phoco" line in the menu.skin with this line:
    "LOAD;HTC.SKIN;TELEFONO;C:\MYMOBILE\MyMobiler. exe -OPEN;!My Mobiler"
    "TELEFONO" is the voice option in my language
    write me a line if someone need a further help....
    here the preview:
    Attached Files Attached Files
  10. #20
    Apr 2005
    Plano, TX
    Davidbraund, don't think you can separate the mic audio and the speaker audio in the bluetooth connection. It's all or none.
    Okay, a MyMobiler question. Has anyone figured out how to map a speakerphone key? My Motorola Q9h has a speakerphone button on the keypad and I'd like to be able to enable it from the touchscreen.
    Thanks,
    Z
