Page 7 of 10 FirstFirst 12345678910 LastLast
Results 61 to 70 of 99
Thread: Windows Mobile Phone Control
  1. #61
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    @ Greg, here's a link to the rom = http://forum.xda-developers.com/showthread.php?t=507372
    @ Kwiksilver, These files are for 800x480 only,if your phone supports that res then it should work fine (back up your Mobiler folder then paste these files)
    Attached Files Attached Files
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  2. #62
    May 2009
    Hey thanks, now I see what you got going on. Im on the Rapheal so Im waiting for xbmod to get a stable build of the rhodium/topaz port before I upgrade to it. Unlike your Blackstone, the Rapheal has a VGA screen so I gotta wait for the port so it runs right on my phone. Looks good tho, glad to see im not the only one here with an htc.
  3. #63
    Nov 2005
    Midlands
    I hope you don't have to wait too long.
    As far as phone intergration goes this looks like being as perfect as i've managed yet.
    I've been at it for years now,messing around with a Nokia 6310i,N95,SonyEricsson K800,K850i........never got the results i was after.
    The whole solution is coming together now,
    I can connect my phone via BT to activsync and get audio handled by BT but then i cant get a serial connection so it looks like i'll connect to activsync via cable,audio via BT which then leaves me a serial port i can connect to so i can get the AT+CLIP (incoming call) data.
    I've asked Tempgp to write up an app to monitor the phone to watch for an incoming call and when it see's the CLIP data to fire a command to rr to switch to the phone skin screen and pause the audio.
    In theory it all works (i've tested it now) so just wainting on the app to complete the software and then i must fix 2 hardware issues.
    The 1st is to get a new BT Dongle,the one i'm using now is running with cracked widcomm stack 5.1.0.1100 and its playing up a little (its auto answering calls when the audio gateway connects).
    So i've got my eye on an AnyCom usb 200/500 which has the Broadcom chipset so no need for cracking widcomm 6.x.x.xxxx.
    The other is the BT audio echo issue and it can only be fixed by spending £100 quid on the Pheonix Soho conference card so thats what i'll do and then i'm done with the phone part,finally.
  4. #64
    May 2009
    Hi
    i tried to get my phone to work with Digital FX4.0, but i was unable to. the command line is
    LOAD;phoco.skin;C:\Documents and Settings\georga\Desktop\My Mobile\MyMobiler.exe -open;My Mobiler
    any help is appreciated.
    Nov 2005
    Midlands
    Try it without the -open switch.
  6. #66
    May 2009
    Quote Originally Posted by Griff1 View Post
    did not work the only thing it does is open the skin!!!!
    HELP!!!!!!!!!!!
  7. #67
    Variable Bitrate Zogg's Avatar
    Apr 2005
    Plano, TX
    Quote Originally Posted by armia1 View Post
    Hi
    LOAD;phoco.skin;Phoco;C:\Documents and Settings\georga\Desktop\My Mobile\MyMobiler.exe -open;My Mobiler
    Add the above in bold, and the whole thing needs to be in quotes like the other button commands in the DFX4 exectbl.ini file.
    Also, I ran into a problem where things got confused between this and the real PHOCO. To solve I renamed the button PHONE and renamed the skin PHONE.skin. DFX4 was trying to start up PHOCO even though I had the command correct. Renaming everything fixed it for me.
    Zotac N630I-D-E M/B w/ Nvidia 7100, E5300 cpu, Xenarc 700IDT, M2-ATX, XP, RR & DFX 5.1.
  8. #68
    May 2009
    Quote Originally Posted by Zogg View Post
    if i only added "phoco" to my line as you mentioned and renamed the skin to phone it did not work, because it is looking for phoco!!!
    you are a bit hazy when you say renaming everything. please be patient with me as i am new at this. please tell me the files at which you made the changes.
    thanks you
  9. #69
    Apr 2005
    Plano, TX
    The problem I ran into was that I had a new button labeled PHONE but there was still a PHOCO button as well in the DFX4.0 Exectbl.ini file. RR was getting confused somehow because the PHONE button details were calling the PHOCO.SKIN so it wasn't working correctly. Here are the changes I made:
    1. In Exectbl.ini my command line is:
    "MyApp07","LOAD;Phone.skin;Phone;C:\Program Files\MyMobiler\MyMobiler.exe -open;My Mobiler"
    Label for MyApp07 is set to PHONE on the "SetAppLabels" line (too long to put here)
    "SetCommandLabels07","SETVAR;MyApp07LB;Phone||SetC ommandLabels08"
    2. Rename PHOCO.SKIN to PHONE.SKIN. In this file, change one line at the top:
    RRScreen Phone (was originally RRScreen "PhonoControl")
    3. Test it out
    That's all I did. You can rename the .PNG files too if you want to but I didn't bother.
    One other note. On my Motorola Q9h to toggle the speakerphone on/off during a call you press "SOFT 2"->"3". I was able to map a button to do that with the following command:
    "ACTIVATE;!My Mobiler||SENDKEY;{F2}||WAIT;0.5||SENDKEY;(3)",""
    If I didn't use the WAIT then the "3" would come too fast. Delaying it just a bit makes it work just fine.
  10. #70
    May 2009
    3. Test it out
    hi, i have followed your instruction to the letter and it still does not work. i have tried another skin 506 by Doc breezy, i can can pretty much control my phone except the numbers eg 1,2,3... buttons do not work!!!
    go figure, why one skin it works and the other does not!!!!
