Page 8 of 10 FirstFirst 12345678910 LastLast
Results 71 to 80 of 99
Thread: Windows Mobile Phone Control
  1. #71
    May 2009
    anybody noe how to use the mymobiler to get the new sms and show it on the screen? or any other way?
  2. #72
    Oct 2008
    MyMobiler simply displays what is on your device screen. If it does not show on your device, it wont show up on the remote screen.
    If you have the Manila today screen, it shows the messages on the messaging tab on the main screen.
  3. #73
    May 2009
    any other where can bring the contact to the frontend ? and do searching can make call?
  4. #74
    Apr 2007
    Griff1, seeing your screenshot makes me feel like trying MyMobiler again.
    Do you have to orientate your blackstone to landscape/horizontal in order to show it likewise on the pc screen?
    Btw, what resolution are you running your RR?
    If it's 800x600, I would love to get a copy of your MyMobiler skin without the hardware buttons. Although I'm running Centrafuse @ 800x600, it should work fine as well.
    When I had my TyTN II, I managed to use Simplistique's skin which had hardware buttons controls in CF. The hardware buttons were useful and sizing was perfect although running MyMobiler as an embedded app in CF was not as stable as I hoped. Somehow after multiple opening and closing of MyMobiler, it goes crazy as more than 1 instance of MyMobiler could be running in the taskbar as MyMobiler already runs an instance the moment the phone is connected. Tried both with and w/o -open parameters. I'm not sure if RR embeds MyMobiler the same way as I only used RR for a short while before switching to CF due to no radio plugin for my Infill G4. Did you encounter the same issue and found a way around it? I recalled changing all possible options in MyMobiler.ini to no avail. i.e. enable/disable trayicon, autoconnect. Wonder how to get MyMobiler running only 1 instance throughout multiple opening and closing which should really be showing and hiding the 1 instance instead.
    Anyhow, after I switched to Blackstone, running the skin I posted above, I had problem with the sizing possibly due to the skin with extra hardware buttons I got from here here.
    In the end, I got a pda mount that reaches close to my steering wheel which allows me to tap the blackstone with my index finger and in the process gave up on MyMobiler.
    If someone could make a skin with hardware buttons that fit the screen, or even better write a plugin with buttons away from the MyMobiler screen it will be perfect but that will probably never gonna happen or take a long long while.
    Until then, if you could share your MyMobiler skin, I would love to rekindle my affairs with MyMobiler.
    Thanks!
  5. #75
    Apr 2007
    My bad! Just saw the skin already posted! Let me give it a spin.
  6. #76
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    The link you posted above is dead, can you send it me so i can see what your dealing with please?
    With regard to my skin....i'd hardly call it a skin really, its an 800x600 background with the MyMobiler window opened out to allow you to see all the screen instead of the 240x320 portion the standard skin allows and then in my RR skin i just clipped out the area i wanted MM to fill and thats it.
    There aren't any hardware buttons assigned in MM, its possible i'll find later that i need hardware buttons for volume and stuff but i've not got to that yet.
    So what is it you want in a skin and how big is the embedded app area in CF?
    Griff.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
  7. #77
    Maximum Bitrate tempgp's Avatar
    Jun 2007
    New York
    in reply to Griff1 PM:
    so essentually what you want me to do is:
    1. Monitoer incomming call
    2. if call detected bring up the skin of the phone or any other app
    3. when call is over close skin (if your phone send t that command) and if not just assime manual screen termination or give it avarage convo time to be on top of everyting
    I habvent ben doint RR for almost a yera but should be easy task to complte
    Acura / Honda A/V CarPC Adapter GA-NET+
    Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
    3D Tuning and Car Visualizer - Preview your car in 3D, change paint job and rims
  8. #78
    Nov 2005
    Midlands
    Yeah that pretty much sums it up.
    I was thinking of a dialogue box or 2 to handle the "on event" commands so thats its not restricted to RR, i know of a few people using other frontends that would just love this.
    Thanks for taking this project on mate.
    Griff.
  9. #79
    Jun 2007
    New York
    well i can do on event thing, but how u wnat me to output it is we dont use RR? u wnat me to launch any external program instead? So say u have phone call and we open MS Word (if u spesified path to MS Word ofcause) and wehen phone call is out we close externall app?
    PS: u should consider urself lucky as i just finish one big project so i got some extra time to play around w. cars =)
  10. #80
    Nov 2005
    Midlands
    I don't know, i was thinking sendkey or something, nevermind, i'm just complicating things.
