Results 1 to 10 of 12
Thread: Windows Mobile-based Phones
    Jan 2006
    One can easily connect their car PC to the internet could with many Windows Mobile-based phones. There is an internet sharing application and you can select whether you want to share your GPRS/3G connection either via USB if your phone is connected to your car PC with a USB cable, or via Bluetooth if you have a Bluetooth-enabled car PC.
    Bear in mind that such a setup will reduce the battery life of your phone because of the relatively high density of data with internet usage, as opposed to the lower density of phone calls/SMS. Also, the speed and bandwidth will be limited to those of your phone's connection, and then possibly further restricted by the connection you choose (USB or Bluetooth).
    There is some more info about internet sharing on Windows Mobile on xda-developers.com. I'll post the thread links when I find them
    Hope this helps. Perhaps it could be turned into a sticky thread.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Are you referring to WMWifirouter? I use it, good stuff.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by Machinehead View Post
    No, he is literally talking about a program in WM6.1 called Internet Sharing. As a note though you have to have tethering on the phone otherwise companies like Sprint will charge you extra. There is a hack to disable them being able to track whether or not they can track it.
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Jun 2007
    Whoops. I forgot about the integrated Internet Sharing. The tracking by the provider was part of the reason I've never used that option.
    Jun 2007
    yea you should check on www.xda-developers.com you should be able to find info on there
    Jul 2007
    Miami
    Quote Originally Posted by keland44 View Post
    I agree, its actually very simple, your just need a registry editor and change one option from 1 to 0, so simple. I would explain it, but im not sure if i would get any bad points from a moderator.
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Jun 2007
    I'm registered at XDA. WMWifiRouter started out there as well, before they went commercial with it.
    Jul 2007
    Miami
    Not to threadjack, what exactly is WMWifiRouter used for? Because my setup is, I have a Sprint Air card on the PC, but also a Wifi card. I want to be able to share the Air Card through the wifi connection. So say you and me park next to each other, you can pick up the signal to the wifi and connect that way..... is that what that program is for?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Jun 2007
    The basic premise is to share your mobile phone's data service by turning your phone into an network access point both wirelessly via wifi or bluetooth but also wired via USB. It also supports WEP encryption. They have a website, you can google it if you want to know more.
    Jan 2009
    not so hard
    i have no tethering plan and link all the time. the WMWifirouter is only for phones with wifi on them and works well but eats the battery fast. but it also means your buddy in the back seat has wifi internet as well if you let him. Im still setting up my carputer but as of now i am using a at&t tilt with a custom firmware and the "internet connection sharing" application via usb. when using the usb sharing you are also charging your phone making it the best solution for long road trips.
    if you purchase a tethering plan from any of the major companies ( Verizon, att, t mobile ) its about 60$ a month and has a 5 gig limit. that's the fair way to play. if you have unlimited internet on your phone and use a mod to allow your pc to get online using that you run the risk of getting caught and fined or having your account canceled.
