your guess is as good as mine...is your computer still working?
Printable View
everything seems normal, no problems or errors...ntldr is't there!!!
then why make a fuss? lol
because I'd like to get the EWF\HORM working and I need to find ntldr so I can replace it...grrr
does anyone know where I can find ntldr, or any reason I can't find it on my system?
Try this.
Go to your C: directory and then go to the Tools>Folder Options>View tab
And uncheck> "Hide protected operating system files (Recomended)"
You'll get a message box asking for the ok, Yes>Apply.
You should now see it...don't know Y someone said that its in the system32 folder :tard:
Not only enable hidden files and folders, you must also uncheck "Hide Protected System Files"
^ doesn't read very well...LOL
oops, i had this page open on another window and submitted a couple of hours late, heh sorry
Okay, I'm feeling really stupid right about now...
I found ntldr right there on the C:... There appears to be two separate options to view hidden/system files. One is a radio button that says "show hidden files and folders" the other is a little further down and is a check box that says "hide protected operating system files (recommended)"
All I did was uncheck the box, and it showed up...
